Hi Everyone, I am trying to add an esp8266MOD node MCU Amica v1 to my home assistant
procedure i am using:
I go to ESP home
I select + New Device
then esp home web
press connect
select the device
then click connect
select prepare for first use
then click install
wheel counts to 100%
it says configuration installed
click close
it says connecting
then I get the hazard symbol and “An error occurred. Port is not ready”
I have tried this with a normal boot up of the esp,
with a boot up holding the flash button for 2 seconds,
with a boot up holding the flash button for 5 seconds and
with a boot up holding the flash button for the duration of the install up to the error
I used the following driver:
Silicon Labs Virtual COM Port (VCP) Universal Driver for Windows 10 version 1803 and later, windows 11
Package version: 11.3.0
Release date: 2023-05-26
I installed an esp32 last week, that I eventually got working, but I cant get this 8266 to work.
Hi
If you show the esphome yaml it’ll help. It sounds like port not ready is part of the esphome installer and not the logs you see on the esphome app under your new device. Your device should be in boot mode after installation then powe cycling.
Hi Spiro, thanks for the reply.
I am using “the prepare for first use” button, so I do not believe I am loading any yaml onto the ESP8266. If the “the prepare for first use” button sends some sort of bare yaml code to the esp, i cannot work out where or how to view it.
I am not familiar with that board, but I am old-school. I find the default install procedure somewhere between useless and confusing and I manually flash the compiled bin file to the device the first time. (Useless because my Home Assistant server is in the basement and I can’t “connect to this computer”).
Here is my process:
ESPHome
New Device
Continue
Give the device a name → next
Select ESP8266
Skip
Now, in the ESPHome window you will find the starter yaml for the new device. Edit the configuration as needed and the first time, flash the device manually using ESPHome Flasher. When the device reboots it will show in the ESPHome page as online. From there, edit the configuration as needed and install the new configuration wirelessly.
I wait for blue circle to stop spinning the select download and save the bin file then select open esphome web. Im doing this from phone so cant show any more steps but select to install from file. Not prepare for first time.
Your board uses a esp12f chip. I mostly set board as esp01_1m
thank you for the suggestions guys, really appreciated
Stevemann: i seem to be able to follow your instructions up to the ESPHome flasher, is this a software for linux?
Spiro: I think I followed your instructions correctly, however the device never comes online, I cant see it on the router.
yaml code:
after trying to install wirelessly i get the following:
INFO ESPHome 2024.8.1
INFO Reading configuration /config/esphome/gk3.yaml…
INFO Generating C++ source…
INFO Compiling app…
Processing gk3 (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- noise-c @ 0.1.6
RAM: [==== ] 41.7% (used 34128 bytes from 81920 bytes)
Flash: [===== ] 47.6% (used 487461 bytes from 1023984 bytes)
========================= [SUCCESS] Took 2.39 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of gk3.local
ERROR Error resolving IP address of gk3.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: WiFi Component — ESPHome)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
Try setting wifi with manual ip to your own network.
Any chance your setting 2.8 and 5 ghz to same ssid on your router? Some routers cause a problem. Not mine so far. Also check correct spelling of ssid and password in secrets.
Esphome flasher is a program. I run it in win11. Dont use it as much now but has a nice feel to it and you see how install is going.
champion thank you, it is working
I had not put any wifi credentials in at all! as my other esp32 didnt have this in it’s yaml code… weird.
Anyway happy days, thanks for your patience.
