I am trying to use firebeetle ESP82266 with BME280 I2C and SPI color display 320x240 with ST7789. When i compile without display and load the binary, everything works. But when i add display and i load the binary the board is not connected as you can see in the log file :
INFO ESPHome 2024.11.2
INFO Reading configuration /config/esphome/test.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing test (board: esp01_1m; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- ESPAsyncTCP-esphome @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.2.2
|-- DNSServer @ 1.1.1
|-- ESP8266WiFi @ 1.0
|-- ESP8266mDNS @ 1.2
|-- Wire @ 1.0
|-- SPI @ 1.0
|-- ArduinoJson @ 6.18.5
Compiling .pioenvs/test/src/main.cpp.o
Linking .pioenvs/test/firmware.elf
RAM: [==== ] 43.3% (used 35472 bytes from 81920 bytes)
Flash: [==== ] 44.1% (used 451433 bytes from 1023984 bytes)
Building .pioenvs/test/firmware.bin
esp8266_copy_factory_bin([".pioenvs/test/firmware.bin"], [".pioenvs/test/firmware.elf"])
esp8266_copy_ota_bin([".pioenvs/test/firmware.bin"], [".pioenvs/test/firmware.elf"])
========================= [SUCCESS] Took 18.49 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.0.110 port 8266...
INFO Connected to 192.168.0.110
INFO Uploading /data/build/test/.pioenvs/test/firmware.bin (455584 bytes)
INFO Compressed to 318264 bytes
Uploading: [============================================================] 100% Done...
INFO Upload took 5.33 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.0.110 using esphome API
WARNING Can't connect to ESPHome API for test @ 192.168.0.110: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.0.110', port=6053))]: [Errno 111] Connect call failed ('192.168.0.110', 6053) (SocketAPIError)
INFO Trying to connect to test @ 192.168.0.110 in the background
My code is as follows :
esphome:
friendly_name: test
project:
version: dev
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
i2c:
sda: GPIO4
scl: GPIO5
scan: true
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
interface: hardware
- platform: bme280_i2c
temperature:
oversampling: 16x
pressure:
humidity:
address: 0x77
update_interval: 60s
display:
- platform: st7789v
model: CUSTOM
height: 240
width: 320
offset_height: 0
offset_width: 0
dc_pin: GPIO0
reset_pin: GPIO2
ota:
- platform: esphome
wifi:
ssid: !secret wifi_ssid
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp8266.yaml@main
import_full_config: true
# To have a "next url" for improv serial
web_server:
I tried many options but nothing works. Can you help me please.
