ESP8266 SR04 M-2 ultrasonic Problem
hi,
I have a ESP8266 and a SR04 ultrasonic sensor, but i can’t get them to work.
My Conections
5v - Vin
RX | Trig - D5
TX | Echo - D6
GND - GND
My Code:
esphome:
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Esphome-Web-887B4A"
    password: "YQA708yGImRg"
captive_portal:
    # Water Level Sensor
  - platform: wifi_signal
    name: "WiFi Signal Sensor"
    update_interval: 60s
  - platform: ultrasonic
    trigger_pin: GPIO14
    echo_pin: GPIO12
    unit_of_measurement: "%"
    icon: "mdi:water-percent"
    accuracy_decimals: 0
    update_interval: 300000ms
    name: "Sweet Water storage"
    filters:
      - lambda: return (1-((x-.10)/1.10))*100;
      - filter_out: nan
    trigger_pin: GPIO14
    echo_pin: GPIO12
    update_interval: 20000ms
    name: "Remaining Water in Tank"
    unit_of_measurement: "l"
    filters:
      - lambda: return (1-((x-.10)/1.10))*1000;
      - filter_out: nan
And get this log
INFO Reading configuration /config/esphome/esphome-web-887b4a.yaml...
INFO Starting log output from esphome-web-887b4a.local using esphome API
INFO Successfully connected to esphome-web-887b4a.local
[16:51:05][I][app:102]: ESPHome version 2022.10.0 compiled on Oct 24 2022, 16:40:19
[16:51:05][C][wifi:502]: WiFi:
[16:51:05][C][wifi:360]:   Local MAC: E8:9F:6D:88:7B:4A
[16:51:05][C][wifi:361]:   SSID: 'POCO F3_plus_2'[redacted]
[16:51:05][C][wifi:362]:   IP Address: 192.168.1.40
[16:51:05][C][wifi:363]:   BSSID: C0:9F:E1:8A:1D:4F[redacted]
[16:51:05][C][wifi:365]:   Hostname: 'esphome-web-887b4a'
[16:51:05][C][wifi:367]:   Signal strength: -50 dB ▂▄▆█
[16:51:05][C][wifi:371]:   Channel: 2
[16:51:05][C][wifi:372]:   Subnet: 255.255.255.0
[16:51:05][C][wifi:373]:   Gateway: 192.168.1.1
[16:51:05][C][wifi:374]:   DNS1: 213.228.128.99
[16:51:05][C][wifi:375]:   DNS2: 213.228.129.67
[16:51:05][C][logger:275]: Logger:
[16:51:05][C][logger:276]:   Level: DEBUG
[16:51:05][C][logger:277]:   Log Baud Rate: 115200
[16:51:05][C][logger:278]:   Hardware UART: UART0
[16:51:05][C][ultrasonic.sensor:045]: Ultrasonic Sensor 'Sweet Water storage'
[16:51:05][C][ultrasonic.sensor:045]:   State Class: 'measurement'
[16:51:05][C][ultrasonic.sensor:045]:   Unit of Measurement: '%'
[16:51:05][C][ultrasonic.sensor:045]:   Accuracy Decimals: 0
[16:51:05][C][ultrasonic.sensor:045]:   Icon: 'mdi:water-percent'
[16:51:05][C][ultrasonic.sensor:046]:   Echo Pin: GPIO12
[16:51:05][C][ultrasonic.sensor:047]:   Trigger Pin: GPIO14
[16:51:05][C][ultrasonic.sensor:048]:   Pulse time: 10 µs
[16:51:05][C][ultrasonic.sensor:049]:   Timeout: 11661 µs
[16:51:05][C][ultrasonic.sensor:050]:   Update Interval: 300.0s
[16:51:05][C][ultrasonic.sensor:045]: Ultrasonic Sensor 'Remaining Water in Tank'
[16:51:05][C][ultrasonic.sensor:045]:   Unit of Measurement: 'l'
[16:51:05][C][ultrasonic.sensor:045]:   Icon: 'mdi:arrow-expand-vertical'
[16:51:05][C][ultrasonic.sensor:050]:   Update Interval: 20.0s
[16:51:05][C][captive_portal:088]: Captive Portal:
[16:51:05][C][mdns:100]: mDNS:
[16:51:05][C][mdns:101]:   Hostname: esphome-web-887b4a
[16:51:05][C][ota:089]: Over-The-Air Updates:
[16:51:05][C][ota:090]:   Address: esphome-web-887b4a.local:8266
[16:51:05][C][api:138]: API Server:
[16:51:05][C][api:139]:   Address: esphome-web-887b4a.local:6053
[16:51:05][C][api:143]:   Using noise encryption: NO
[16:51:05][C][wifi_signal.sensor:009]: WiFi Signal 'WiFi Signal Sensor'
[16:51:05][C][wifi_signal.sensor:009]:   Device Class: 'signal_strength'
[16:51:05][C][wifi_signal.sensor:009]:   State Class: 'measurement'
[16:51:05][C][wifi_signal.sensor:009]:   Unit of Measurement: 'dBm'
[16:51:05][C][wifi_signal.sensor:009]:   Accuracy Decimals: 0
[16:51:24][D][ultrasonic.sensor:036]: 'Remaining Water in Tank' - Distance measurement timed out!
[16:51:44][D][ultrasonic.sensor:036]: 'Remaining Water in Tank' - Distance measurement timed out!
[16:52:00][D][sensor:126]: 'WiFi Signal Sensor': Sending state -44.00000 dBm with 0 decimals of accuracy
[16:52:04][D][ultrasonic.sensor:036]: 'Remaining Water in Tank' - Distance measurement timed out!
Anyone able to help me solve the problem?
i got same problem. did you resolve it? can you give me some advices?
Have the exact same sensor and exact same problem. I think this particular sensor is crap, will try another make,
I read somewhere that the default pulse interval doesn’t work well with this sensor. Unfortunately, I am not able to recover the source for this information. However a pulse interval of 20 us works for me.
    trigger_pin: GPIO17
    echo_pin: GPIO 16
    pulse_time: 20 us
    update_interval: 10s
Still I often get wrong distance measurements which seems to be connected wit not having the sensor positioned perfectly. Any ideas how to best position the sensor for accurate readings?
Best regards,
Dominik
I stumbled upon this while configuring the very same sensor (SR04M-2). After a lot of trial and error my solution was to configure it (also the resistor) as it if were a JSN_SR04T)
Reference documentation: JSN-SR04T Waterproof Ultrasonic Range Finder — ESPHome
My YAML:
uart:
  tx_pin: GPIO14
  rx_pin: GPIO12
  baud_rate: 9600
  - platform: "jsn_sr04t"
    name: "Livello Intercapedine"
    filters:
      - quantile:
          window_size: 10
          send_every: 50
          send_first_at: 1
          quantile: .9
