Hello.
I have a batterybank for my homestorage and i have 5x Daly bms that i want to have on my HA site.
I am getting everything to work with my AZ-Delivery ESP32 but when i use my AZ ESP8266 12F i get it online and everything. But it doesnt give me any values.
I am connected via Uart on these pins.
Daly RX - Gpio1
Daly TX - Gpio3
Daly Gnd - G
Daly 3.3v - 3.3v
Exact the same configuration on esp32.
Someone have a clue!?
I did 5 of them and no one works so its not bad hardware.
Also did new test and did a I2C connection. And then i get values from a different sensor.
So its Uart on 8266 that dont work. HOW!?
Would you post the code you are using in full and I will help with troubleshooting I have a board of each free. I am assuming that you are using ESPhome?
It is quite late here so I may have to continue in the morning.
I also have noticed that your post is in the uncategorized category?
You probably will get more direct assistance by moving it to the esphome category.
