ESP8266 Wemos D1 Mini fails to connect
I am having an issue with my Wemos D1 mini’s failing to connect on reboot.
I have removed everything bar the 5V and G, incase it didn’t like the PIN I was using, however the issue still continues.
The only way I can get it to connect is by pushing the RST button.
Any ideas on this one?
The error output is
INFO ESPHome 2024.3.1
INFO Reading configuration /config/esphome/playbulb-candle-1.yaml...
INFO Starting log output from 192.168.1.100 using esphome API
WARNING Can't connect to ESPHome API for playbulb-candle-1 @ 192.168.1.100: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.100', port=6053))]: [Errno 113] Connect call failed ('192.168.1.100', 6053) (SocketAPIError)
INFO Trying to connect to playbulb-candle-1 @ 192.168.1.100 in the background
Full YAML
esphome:
  friendly_name: playbulb-candle-1
  platform: ESP8266
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ""
ota:
  password: ""
wifi:
  networks:
  - ssid: !secret wifi_ssid
    bssid:
  fast_connect: true
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.1.100
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: "Playbulb-Candle-1"
    password: ""
captive_portal:
globals:
  - id: actual_effect
    type: int
    restore_value: yes
    initial_value: '0'
light:
  - platform: neopixelbus
    type: GRB
    variant: WS2811
    pin: GPIO0
    num_leds: 60
    name: "Entity Status Indicator"
    effects:
      # Use default parameters:
      - random:
      # Customize parameters
      - random:
          name: "My Slow Random Effect"
          transition_length: 30s
          update_interval: 30s
      - random:
          name: "My Fast Random Effect"
          transition_length: 4s
          update_interval: 5s
      - random:
          name: Random Effect With Custom Values
          transition_length: 5s
          update_interval: 7s
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
          min_brightness: 0%
          max_brightness: 100%
      - pulse:
          # transition_length: 1s      # defaults to 1s
          update_interval: 2s
      - strobe:
          name: Strobe Effect With Custom Values
          colors:
            - state: true
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: false
              duration: 250ms
            - state: true
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 1.5%
      - addressable_rainbow:
          name: Rainbow Effect With Custom Values
          speed: 10
          width: 50
      - addressable_color_wipe:
          name: Color Wipe Effect With Custom Values
          colors:
            - red: 100%
              green: 100%
              blue: 100%
              num_leds: 1
            - red: 0%
              green: 0%
              blue: 0%
              num_leds: 1
          add_led_interval: 100ms
          reverse: false
      - addressable_scan:
          name: Scan Effect With Custom Values
          move_interval: 100ms
          scan_width: 1
      - addressable_twinkle:
          name: Twinkle Effect With Custom Values
          twinkle_probability: 5%
          progress_interval: 4ms
      - addressable_random_twinkle:
          name: Random Twinkle Effect With Custom Values
          progress_interval: 32ms
      - addressable_fireworks:
          name: Fireworks Effect With Custom Values
          update_interval: 32ms
          spark_probability: 10%
          use_random_color: false
          fade_out_rate: 120
      - addressable_lambda:
          update_interval: 50ms
          lambda: |-
            static int x = 40;
            static int y = 0;
            if (initial_run) {
              x = 40;
              y = 0;
              it.all() = ESPColor::BLACK;
            if (x < it.size(), (y < it.size())) {
              it[x, y] = current_color;
              y += 1;
              x += 1;
          update_interval: 16ms
          lambda: |-
            static int x = -400;
            float y = 0.35+0.65*exp(-pow(x, 2)/49000);
            int8_t r = ceil(current_color.r * y);
            int8_t g = ceil(current_color.g * y);
            int8_t b = ceil(current_color.b * y);
            it.all() = ESPColor(r,g,b);
            x += 1;
            if (x == 400)
              x = -400;
          update_interval: 12ms
          lambda: |-
            static int x = 0;
            if (initial_run) {
              x = it.size();
            if (x > 0) {
              x -= 1;
              it[x] = ESPColor::BLACK;
Can you ping it?
No I cant,
I connected USB and pulled logs via USB, it is simply failing to boot 5 out of 6 times.
Boot on completes if I push the RST button.
Sometimes, like I say 1 out of the 6 times, it will boot on its own.
You have placed this without MAC code needed to identify it, but have also included ssid. What about just deleting bssid.
wifi:
  fast_connect: true
  manual_ip:
Try the above. As not other networks included no need to use network.
[19:20:53][C][wifi:580]: WiFi:
[19:20:53][C][wifi:408]:   Local MAC: 0C:B3:14:C3:80:80
[19:20:53][C][wifi:413]:   SSID: [redacted]
[19:20:53][C][wifi:416]:   IP Address: 192.168.2.58
[19:20:53][C][wifi:420]:   BSSID: [redacted]
[19:20:53][C][wifi:421]:   Hostname: 'backroom'
[19:20:53][C][wifi:423]:   Signal strength: -37 dB ▂▄▆█
[19:20:53][C][wifi:427]:   Channel: 11
[19:20:53][C][wifi:428]:   Subnet: 255.255.255.0
[19:20:53][C][wifi:429]:   Gateway: 192.168.2.1
[19:20:53][C][wifi:430]:   DNS1: 192.168.2.1
[19:20:53][C][wifi:431]:   DNS2: 8.8.8.8
[19:20:53][C][logger:166]: Logger:
[19:20:53][C][logger:167]:   Level: DEBUG
If that didn’t work you can narrow it down by looking at log and see if you get a signal strength or if it’s just not connecting to api. Don’t forget to turn logger on to debug.
Thank, but I redacted the BSSID,
The BSSID is required when using fast_connect to connect to a specific AP.
I’ve had the same problem with one esphome device that once connected worked fine but if restarted could take up to an hour to reconnect if left alone . Logging in with serial gave the same WARNING Can’t connect to ESPHome API and network scan showed it hadn’t connected to router. I did a clean build and uploaded it by serial and so far seems to connect if restarted. Time will tell.
Thanks, was this a 8266?
I’ve actually just migrated over to an ESP32 for all 3 of these projects which is unfortunately a complete overkill,
But, they work flawlessly.
No it was a esp32. Haven’t had the problem with any of the 8266s which use deep sleep.
Hmm yea, that’s weird as I have a esp8266 deep sleeping too and when it wakes, no issues at all connecting.
