can someone help me integrate mqtt and figure out why my servo is not responding. this is to get a project to build automated blinds using a esp8266, button and 20kg analog servo.
thank you!
*************Arduino sketch ********************
#include <ESP8266WiFi.h>
#include <DNSServer.h> //Local DNS Server used for redirecting all requests to the configuration portal
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include <WiFiManager.h> //https://github.com/tzapu/WiFiManager WiFi Configuration Magic
#include <ESP8266mDNS.h>
#include <Servo.h>
#define WLAN_SSID "********" //change to your Wifi SSID
#define WLAN_PASS "********" //change to your Wifi Password
MDNSResponder mdns;
ESP8266WebServer server(80);
int servoPin = 0; //Servo on GPIO0 or NODEMCU pin D3
const int buttonPin = 12; //manual button on GPIO12 or NODEMCU pin D6
int buttonState = 0;
int direction = 0;
int setting = 0; //Startup with blinds closed
int position = 90;
Servo servoA;
String webPage = "";
void setup(void) {
WiFi.mode(WIFI_STA);
webPage += "<body onload='la()'><div style='text-align:left;display:inline-block;min-width:340px;'><div style='text-align:center;'><h1>ESP8266 Web Server</h1><p><h2>Blinds</h2><br></div>";
webPage += "<br/><style>div,fieldset,input,select{padding:5px;font-size:1em;}input{width:100%;box-sizing:border-box;-webkit-box-sizing:border-box;-moz-box-sizing:border-box;}select{width:100%;}textarea{resize:none;width:98%;height:318px;padding:5px;overflow:auto;}body{text-align:center;font-family:verdana;}td{padding:0px;}button{border:0;border-radius:0.3rem;background-color:#1fa3ec;color:#fff;line-height:2.4rem;font-size:1.2rem;width:100%;;cursor:pointer;}button:hover{background-color:#006cba;}a{text-decoration:none;}.p{float:left;text-align:left;}.q{float:right;text-align:right;}</style><a href=\"0\"><button>0</button></a><br>";
webPage += "<br/><a href=\"10\"><button>10</button></a><br>";
webPage += "<br/><a href=\"20\"><button>20</button></a><br>";
webPage += "<br/><a href=\"30\"><button>30</button></a><br>";
webPage += "<br/><a href=\"40\"><button>40</button></a><br>";
webPage += "<br/><a href=\"50\"><button>50</button></a><br>";
webPage += "<br/><a href=\"60\"><button>60</button></a><br>";
webPage += "<br/><a href=\"70\"><button>70</button></a><br>";
webPage += "<br/><a href=\"80\"><button>80</button></a><br>";
webPage += "<br/><a href=\"90\"><button>90</button></a><br>";
webPage += "<br/><a href=\"100\"><button>100</button></a><br></body>";
delay(5000);
pinMode(buttonPin, INPUT_PULLUP);
Serial.begin(115200);
delay(500);
Serial.println("Blind Startup Sequence");
delay(500);
Serial.println();
Serial.print("Connecting to ");
Serial.println(WLAN_SSID);
WiFi.begin(WLAN_SSID, WLAN_PASS);
// Set a static IP (optional)
//IPAddress ip(10,0,1,50);
//IPAddress gateway(10,0,1,1);
//IPAddress subnet(255, 255, 255, 0);
//WiFi.config(ip, gateway, subnet);
// End of set a static IP (optional)
delay(2000);
int i = 0;
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
ESP.wdtFeed();
if (i > 10) // Try 40 times to connect to Wifi
Serial.print("Restarting Wifi"); ESP.reset(); // Reset Wifi stack if more than 40 trys
i++;
Serial.println();
Serial.println("WiFi connected");
Serial.println("IP address: "); Serial.println(WiFi.localIP());
if (mdns.begin("esp8266", WiFi.localIP())) {
Serial.println("MDNS responder started");
server.on("/", []() { server.send(200, "text/html", webPage); });
server.on("/100", []() { server.send(200, "text/html", webPage); setting = 180; });
server.on("/99", []() { server.send(200, "text/html", webPage); setting = 180; });
server.on("/98", []() { server.send(200, "text/html", webPage); setting = 180; });
server.on("/97", []() { server.send(200, "text/html", webPage); setting = 171; });
server.on("/96", []() { server.send(200, "text/html", webPage); setting = 171; });
server.on("/95", []() { server.send(200, "text/html", webPage); setting = 171; });
server.on("/94", []() { server.send(200, "text/html", webPage); setting = 171; });
server.on("/93", []() { server.send(200, "text/html", webPage); setting = 171; });
server.on("/92", []() { server.send(200, "text/html", webPage); setting = 162; });
server.on("/91", []() { server.send(200, "text/html", webPage); setting = 162; });
server.on("/90", []() { server.send(200, "text/html", webPage); setting = 162; });
server.on("/89", []() { server.send(200, "text/html", webPage); setting = 162; });
server.on("/88", []() { server.send(200, "text/html", webPage); setting = 162; });
server.on("/87", []() { server.send(200, "text/html", webPage); setting = 153; });
server.on("/86", []() { server.send(200, "text/html", webPage); setting = 153; });
server.on("/85", []() { server.send(200, "text/html", webPage); setting = 153; });
server.on("/84", []() { server.send(200, "text/html", webPage); setting = 153; });
server.on("/83", []() { server.send(200, "text/html", webPage); setting = 153; });
server.on("/82", []() { server.send(200, "text/html", webPage); setting = 144; });
server.on("/81", []() { server.send(200, "text/html", webPage); setting = 144; });
server.on("/80", []() { server.send(200, "text/html", webPage); setting = 144; });
server.on("/79", []() { server.send(200, "text/html", webPage); setting = 144; });
server.on("/78", []() { server.send(200, "text/html", webPage); setting = 144; });
server.on("/77", []() { server.send(200, "text/html", webPage); setting = 135; });
server.on("/76", []() { server.send(200, "text/html", webPage); setting = 135; });
server.on("/75", []() { server.send(200, "text/html", webPage); setting = 135; });
server.on("/74", []() { server.send(200, "text/html", webPage); setting = 135; });
server.on("/73", []() { server.send(200, "text/html", webPage); setting = 135; });
server.on("/72", []() { server.send(200, "text/html", webPage); setting = 126; });
server.on("/71", []() { server.send(200, "text/html", webPage); setting = 126; });
server.on("/70", []() { server.send(200, "text/html", webPage); setting = 126; });
server.on("/69", []() { server.send(200, "text/html", webPage); setting = 126; });
server.on("/68", []() { server.send(200, "text/html", webPage); setting = 126; });
server.on("/67", []() { server.send(200, "text/html", webPage); setting = 117; });
server.on("/66", []() { server.send(200, "text/html", webPage); setting = 117; });
server.on("/65", []() { server.send(200, "text/html", webPage); setting = 117; });
server.on("/64", []() { server.send(200, "text/html", webPage); setting = 117; });
server.on("/63", []() { server.send(200, "text/html", webPage); setting = 117; });
server.on("/62", []() { server.send(200, "text/html", webPage); setting = 108; });
server.on("/61", []() { server.send(200, "text/html", webPage); setting = 108; });
server.on("/60", []() { server.send(200, "text/html", webPage); setting = 108; });
server.on("/59", []() { server.send(200, "text/html", webPage); setting = 108; });
server.on("/58", []() { server.send(200, "text/html", webPage); setting = 108; });
server.on("/57", []() { server.send(200, "text/html", webPage); setting = 99; });
server.on("/56", []() { server.send(200, "text/html", webPage); setting = 99; });
server.on("/55", []() { server.send(200, "text/html", webPage); setting = 99; });
server.on("/54", []() { server.send(200, "text/html", webPage); setting = 99; });
server.on("/53", []() { server.send(200, "text/html", webPage); setting = 99; });
server.on("/52", []() { server.send(200, "text/html", webPage); setting = 90; });
server.on("/51", []() { server.send(200, "text/html", webPage); setting = 90; });
server.on("/50", []() { server.send(200, "text/html", webPage); setting = 90; });
server.on("/49", []() { server.send(200, "text/html", webPage); setting = 90; });
server.on("/48", []() { server.send(200, "text/html", webPage); setting = 90; });
server.on("/47", []() { server.send(200, "text/html", webPage); setting = 81; });
server.on("/46", []() { server.send(200, "text/html", webPage); setting = 81; });
server.on("/45", []() { server.send(200, "text/html", webPage); setting = 81; });
server.on("/44", []() { server.send(200, "text/html", webPage); setting = 81; });
server.on("/43", []() { server.send(200, "text/html", webPage); setting = 81; });
server.on("/42", []() { server.send(200, "text/html", webPage); setting = 72; });
server.on("/41", []() { server.send(200, "text/html", webPage); setting = 72; });
server.on("/40", []() { server.send(200, "text/html", webPage); setting = 72; });
server.on("/39", []() { server.send(200, "text/html", webPage); setting = 72; });
server.on("/38", []() { server.send(200, "text/html", webPage); setting = 72; });
server.on("/37", []() { server.send(200, "text/html", webPage); setting = 63; });
server.on("/36", []() { server.send(200, "text/html", webPage); setting = 63; });
server.on("/35", []() { server.send(200, "text/html", webPage); setting = 63; });
server.on("/34", []() { server.send(200, "text/html", webPage); setting = 63; });
server.on("/33", []() { server.send(200, "text/html", webPage); setting = 63; });
server.on("/32", []() { server.send(200, "text/html", webPage); setting = 54; });
server.on("/31", []() { server.send(200, "text/html", webPage); setting = 54; });
server.on("/30", []() { server.send(200, "text/html", webPage); setting = 54; });
server.on("/29", []() { server.send(200, "text/html", webPage); setting = 54; });
server.on("/28", []() { server.send(200, "text/html", webPage); setting = 54; });
server.on("/27", []() { server.send(200, "text/html", webPage); setting = 45; });
server.on("/26", []() { server.send(200, "text/html", webPage); setting = 45; });
server.on("/25", []() { server.send(200, "text/html", webPage); setting = 45; });
server.on("/24", []() { server.send(200, "text/html", webPage); setting = 45; });
server.on("/23", []() { server.send(200, "text/html", webPage); setting = 45; });
server.on("/22", []() { server.send(200, "text/html", webPage); setting = 36; });
server.on("/21", []() { server.send(200, "text/html", webPage); setting = 36; });
server.on("/20", []() { server.send(200, "text/html", webPage); setting = 36; });
server.on("/19", []() { server.send(200, "text/html", webPage); setting = 36; });
server.on("/18", []() { server.send(200, "text/html", webPage); setting = 36; });
server.on("/17", []() { server.send(200, "text/html", webPage); setting = 27; });
server.on("/16", []() { server.send(200, "text/html", webPage); setting = 27; });
server.on("/15", []() { server.send(200, "text/html", webPage); setting = 27; });
server.on("/14", []() { server.send(200, "text/html", webPage); setting = 27; });
server.on("/13", []() { server.send(200, "text/html", webPage); setting = 27; });
server.on("/12", []() { server.send(200, "text/html", webPage); setting = 18; });
server.on("/11", []() { server.send(200, "text/html", webPage); setting = 18; });
server.on("/10", []() { server.send(200, "text/html", webPage); setting = 18; });
server.on("/9", []() { server.send(200, "text/html", webPage); setting = 18; });
server.on("/8", []() { server.send(200, "text/html", webPage); setting = 18; });
server.on("/7", []() { server.send(200, "text/html", webPage); setting = 9; });
server.on("/6", []() { server.send(200, "text/html", webPage); setting = 9; });
server.on("/5", []() { server.send(200, "text/html", webPage); setting = 9; });
server.on("/4", []() { server.send(200, "text/html", webPage); setting = 9; });
server.on("/3", []() { server.send(200, "text/html", webPage); setting = 9; });
server.on("/2", []() { server.send(200, "text/html", webPage); setting = 0; });
server.on("/1", []() { server.send(200, "text/html", webPage); setting = 0; });
server.on("/0", []() { server.send(200, "text/html", webPage); setting = 0; });
server.begin();
Serial.println("HTTP server started");
void loop() {
buttonState = digitalRead(buttonPin);
if(buttonState == LOW && setting < 180 && direction == 0){
setting++;
delay(0);
if(setting == 180){
direction = 1;
if(buttonState == LOW && setting > 0 && direction == 1){
setting--;
delay(0);
if(setting == 0){
direction = 0;
if(buttonState == LOW && setting == 180 && direction == 0){
setting--;
delay(0);
if(buttonState == LOW && setting == 0 && direction == 1){
setting++;
delay(0);
if(position < setting){
servoA.attach(servoPin);
servoA.write(position++);
delay(5);
Serial.print("Setting: ");
Serial.println(setting);
Serial.print("Position: ");
Serial.println(position);
if(position > setting){
servoA.write(position--);
delay(5);
if(position == setting){
servoA.detach();
server.handleClient();
