I have a esp8266 board connected with a dc motor (relay) which can move forwards and backwards for 30 seconds. So my plan is to have a input_number slider in HA from 0 to 30 and the motor should change the position.
Now I have some problems persisting the current position on the esp. I tried to solve that with mqtt with less effort.
My questions:
- How can I react on “target-state” changes from HA?
- How can I subscribe the “current state” from mqtt?
- How can I publish the “new state” from mqtt (retained message)?
my current solution (it’s working a little bit but the communication with mqtt is very bad):
soll… target state
ist… current state
mqtt:
# broker: homeassistant.local
broker: 10.0.0.223
port: 1883
username: mqtt
password: *******
# topic_prefix: fbh
discovery: false
discovery_prefix: homeassistant
- platform: homeassistant
entity_id: sensor.fbh_soll
- platform: mqtt_subscribe
topic: fbh/sensor/fbh_ist/state
name: "FBH IST Kreis 1"
retain: true
globals:
- id: fbh_diff
type: int
restore_value: no
initial_value: '0'
- id: fbh_ist_intern
type: int
restore_value: yes
initial_value: '0'
switch:
- platform: gpio
pin:
number: GPIO5
inverted : False
mode: OUTPUT
restore_mode : ALWAYS_OFF
- platform: gpio
pin:
number: GPIO4
inverted : False
mode: OUTPUT
interval:
- interval: 10s
then:
# moving up
- if:
condition:
lambda: 'id(fbh_ist_intern) = (int)(id(fbh_ist).state); return (((int)id(fbh_soll).state - (int)id(fbh_ist_intern)) > 0);'
then:
- logger.log: "more!"
- switch.turn_off: relay2
- switch.turn_on: relay1
- delay: !lambda "id(fbh_diff) = (int)id(fbh_soll).state - (int)id(fbh_ist_intern); return 0;"
- delay: !lambda "return id(fbh_diff)*1000;"
- switch.turn_off: relay1
- delay: !lambda "id(fbh_ist_intern) = (int)id(fbh_ist_intern)+(int)id(fbh_diff); return 0;"
- delay: !lambda "id(fbh_ist).publish_state(id(fbh_ist_intern)); return 0;"
- mqtt.publish:
payload: !lambda |-
return esphome::to_string(id(fbh_ist_intern))+"a";
retain: true
# moving down
- if:
condition:
lambda: 'id(fbh_ist_intern) = (int)id(fbh_ist).state; return (((int)id(fbh_ist_intern) - (int)id(fbh_soll).state) > 0);'
then:
- logger.log: "less!"
- switch.turn_on: relay2
- delay: !lambda "id(fbh_diff) = (int)id(fbh_ist_intern) - (int)id(fbh_soll).state; return 0;"
- delay: !lambda "id(fbh_ist_intern) = (int)id(fbh_ist_intern)-(int)id(fbh_diff); return 0;"
- mqtt.publish:
payload: !lambda |-
return esphome::to_string(id(fbh_ist_intern))+"b";
retain: true
Maybe someone can help me with a simple bidirectional mqtt example.
Thanks!
