Hello together,
I have a new project that I’m unfortunately stuck on and need your help. I want to make my Hörmann garage door smart. I use the Hörmann adapter board (UAP1) which can show the state of the door (open / closed), the state of the light (on?) and control the door (up, down, ventilation position) and the light (on / off).
To control that with HA I have ordered an Board based on a ESP8266MOD with wich all the functions can be done and all the states can be shown.
Now the problem: The board is based on ESPEasy. I want to migrate it to ESPHome but there are some topics I don’t know how to handle it.
1) I created an project in ESPHome but here I just could choose ESP8266. In the yaml-file is the following written. Is that correct? I don’t know the exact type, vendor,… But in ESPEasy is written “Espressif Generic ESP8266 ESPEasy 4M Flash 1M FS”
In another thread here in the community a user has written “nodemcu” at board.
esp8266:
board: esp01_1m
2) In ESPEasy are 7 Swicht inputs. The states (door open, door closed, light on) are no problem. They I can set as a binary sensor like:
binary_sensor:
- platform: gpio
pin: 1
name: "garage door opened"
device_class: garage
But how can the switches be written? Here the rules in ESPEasy:
on up do
gpio,12,1
timerSet,1,1
endon
on down do
gpio,15,1
timerSet,1,1
endon
on part do
gpio,13,1
timerSet,1,1
endon
on light do
gpio,14,1
timerSet,1,1
endon
on Rules#Timer=1 do
gpio,12,0
gpio,13,0
gpio,14,0
gpio,15,0
endon
Am I right with the following example-code?
switch:
- platform: gpio
pin: 12
icon: "mdi:gate"
on_turn_on:
- delay: 200ms
- switch.turn_off: relay
If yes, do I have to set different id’s for the different switches (e.g. relay1, relay2,…)?
3) A generell question: In ESPEasy is written for example “GPIO-1 (D10)”. Fo I have to use for pin: “1” or “D10”?
4) The big problem I have is that there is no USB-port at the ESP. Because of have to flash the ESPHome firmware via ESPEasy and it has to work directly at the first time (except the sensors / switches).
Thank you in advance!!
Best regards
Andreas
