I have set up an Esp8266 board with a motion sensor and it works with EspEasy ( it shows a one when I refresh the page whilst waving my hand in front of it ). I have tried linking it to home assistant using MQTT but for some reason, it only says “unavailable”. I could really use some help. Thanks!
Here are some screenshots:
You don’t have to bother obscuring 192.168… addresses as they are not route-able over the internet.
Please don’t post screenshots of your config. It makes it difficult to re-use in a reply. See point 11 here for how to format pasted code correctly.
Now on to your problem:
I suspect your binary sensor mqtt state topic is incorrect but you don’t show what %sysname% or %tskname% or %valname% resolve to in your ESPEasy. So I can’t tell you anything other than it should be:
state_topic: "%sysname%/%tskname%/%valname%" (replace %...name% with the actual names in your ESPEasy)
Where did you get sensor/MotionSensor/Motion ?
You can use a client like MQTT.Fx to see what your sensor topic is if you are not sure what these values are.
