I wanted to build a plant sensor with espeasy, but it is not publishing any data to the Mosquitto MQTT Broker on the rpi. The garage doors are working over mqtt. I‘ll attach some screenshots from the configuration, hopefully someone can help me.
Thanks in advance
Great, thanks for the screenshot. That looks promising.
I can see that you hard-coded the topic in “Controller Publish”. If you have more devices you probably want to change that to %sysname%/%valname% instead, and ESPEasy will automatically populate the correct values from the device configuration.
I’ve migrated to ESPHome, and only have 1 ESPEasy device left at the moment, but in my configuration I am not using a leading / for “Subscribe” or “Publish”. Likewise the state_topic value then wouldn’t need a leading / either. I honestly can’t remember if this fixed it, but worth a try.
