Espeasy pushbutton status via mqtt
I’m trying to migrate from domoticz to homeassistant with my standalone gate controller, I have only this device left.
Everything works on ESP_Easy_mega_20201016_test_ESP32_4M316k (since newer version they put gpio into core and my config is not working on it)
Devices:
ButtonA is set as Push Button Active High
Rules:
on System#Boot do
    TaskValueSet,1,2,1
    timerSet,3,5
endon
on ButtonA#State=0 do
  if [Task#Block]=0 and [Foto#State]=0
   event,gateclose
else
  gpio,23,0
  timerSet,2,1
endif
endon
on ButtonA#State=1 do
   if [Task#Block]=0
   event,gateopen
endif
endon
on gateclose do
   gpio,13,1
   gpio,15,1
   timerSet,4,1
   delay,1000
   longpulse,12,0,160
   delay,1500
   longpulse,14,0,160
   timerSet,1,70  //disable barrier
endon
on gateopen do
   TaskValueSet,1,1,1
   timerSet,4,1
   gpio,12,1
   gpio,14,1
   delay,1000
   longpulse,15,0,160
   delay,1300
   longpulse,13,0,160
endon
on Foto#State=1 do  //Foto
if  [ButtonA#State]=0 and [Task#Dummy]=1
   gpio,23,0
   timerSet,2,1
endif
endon
on Rules#Timer=1 do
   TaskValueSet,1,1,0
endon
on Rules#Timer=2 do
   gpio,23,1
endon
on Rules#Timer=3 do
   TaskValueSet,1,2,0
endon
On GPIO 23 I have physical button in push button active high mode, when I press him gate is closing or opening and reporting that state to domoticz, and when I’m doing that same in domoticz, always I have press button only once to change gate state. When gate is closing and something cross photo barier, rules immediately open gate and reporting state to domoticz.
I spent few days to move it to HA but unsuccessfully. I just need to have synced gpio23 with entity in HA with possibility to execute events, it would be nice if it would works like in domoticz as one icon.
I tried a lot of varation as:
switch:
- platform: mqtt
  command_topic: "ESP/cmd"
  payload_on: "event,gateopen"
  payload_off: "event,gateclose"
In that case I can execute events and it works when I’m pressing buttons in HA.
- platform: mqtt
  state_topic: "ESP/ButtonA/State"
  state_on: "1"
  state_off: "0"
  retain: true
In this case I can read state of button.
- platform: mqtt
  state_topic: "ESP/GateSt"
  state_on: "close"
  state_off: "open"
  device_class: garage_door
and I tried to put Publish to send state in rules
   Publish ESP/GateSt,close
   event,gateclose
else
  gpio,23,0
  timerSet,2,1
endif
endon
   if [Task#Block]=0
   Publish ESP/GateSt,open
   event,gateopen
endif
endon
Other problem is on reboot esp, on beginning in rules I put dummy device with 5s timer to prevent to open gate at boot, it works with domoticz mqtt but not when I selected HA as controller it won’t.
