1593795462: New connection from 192.168.1.8 on port 1883.
1593795482: New connection from 192.168.1.8 on port 1883.
1593795503: New connection from 192.168.1.8 on port 1883.
[WARN] Not found homeassistant on local database
1593795522: New connection from 192.168.1.8 on port 1883.
1593795542: New connection from 192.168.1.8 on port 1883.
1593795562: New connection from 192.168.1.8 on port 1883.
1593795582: New connection from 192.168.1.8 on port 1883.
1593795600: Saving in-memory database to /data/mosquitto.db.
1593795605: New connection from 192.168.1.8 on port 1883.
1593795622: New connection from 192.168.1.8 on port 1883.
I don’t know what mosquitto you are using, but if it is the mosquitto add-on for homeassistant OS or homeassistant supervised, it is clearly written in the docs that the user can’t be homeassistant.
BTW: the name hassio was retired months ago.
It’s working.
I change username in MQTT settings and in ESP CONTROLLER (same username and password). And now ESP is connected to MQTT.
Thanks a lot francisp
But sensor didn’t appear automatically in MQTT addon, do i have to fill configuration.yaml ?
ESPeasy it not sending discovery. Im was try that many times.
Im using ESP wall switches and in rules I control MQTT publish action to do something in HA.
In devices i have “Generic - MQTT Import” to it listen to changes of a MQTT Topic and in rules I have actions based on those changes
I have archived all rules on Github:
Here a screenshot of one of the generic MQTT import:
Nice solution. I created same way for my wall switches based on ESPeasy. Can use them manual, will update in HA. Can use them in HA and will update in ESPeasy. Nice colors for every action I created in the switch…
