ESPHome 1.14.4 breaks Dallas Sensor [Errno 111] Connection refused
ESPHome 1.14.4 not working with Dallas sensor.
Wifi is connecting and wifi sensor working but if you have dallas: in your config your node will not work anymore and you got [Errno 111] Connection refused.
I have the same problem
I have exactly the same problem.
I thought I was doing something wrong, but turns out I have the same problem as well
Ok - appears to be known about on ESPHome Github, only affects ESP32 and is supposedly fixed in ESPHome 1.15.0.dev, which I have installed and am about to try.
Edit: can confirm dev version is working.
Thanks @zoogara, the dev release fixed my issue as well.
For anyone that doesn’t know how to install it like I didn’t:
pip uninstall esphome
pip install https://github.com/esphome/esphome/archive/dev.zip
