Anybody else having problems accessing the ESP logs after updating to 2021.10.0 and recompiling the firmware of an ESP?
Error message is:
WARNING Can't connect to ESPHome API for XYZ.local: Error resolving IP address: [Errno -2] Name or service not known
YAML is unchanged.
I can in fact access the logs of all ESPs that have not been recompiled with the new ESPHome version.
And when I update OTA for the first time the logs are shown too just after the upload (as usual).
But from there one there is no way to see the logs again. Another upload is possible but also does not show the logs again.
Beside that the updated ESPs seem to work fine. They connect to HA and can be flashed again OTA. So the “Can’t connect…” seems to be an issue specific to the logging connection.
