EspHome 2022.12.8 Appears to have killed DHT sensor on Sonoff
Had taken me a while but managed to get a DHT22/AM2302 working on my Sonoff TH10. Has worked perfectly for weeks. After the upgrade to EspHome 2022.12.8 tonight I see this…
This is really frustrating… and not the first time something has imploded after an EspHome update.
I am almost at the stage now where I feel I need to backup all the binaries on my ESP32’s before upgrading. I took a backup before the upgrade, and restored it, but that doesn’t seem to work.
I can only assume there is something I need to change in the code? Ideas greatly appreciated.
Show your DHT sensor config.
Here you go…
substitutions:
  off_hour: '3'
esphome:
  platform: ESP8266
  board: esp01_1m
  on_boot:
  - wait_until:
      condition: api.connected
  - delay: 2s
  - if:
      condition:
        and:
        - sun.is_below_horizon:
        - lambda: |-
            auto hour = id(ha_time).now().hour;
            return hour > 12 || hour < ${off_hour};
      then:
      - light.turn_on:
wifi:
  ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      mode: INPUT_PULLUP
      inverted: True
  - platform: status
    name: "Outside Light Controller Status"
output:
  - platform: gpio
    pin: GPIO12
  # Register the blue LED as a dimmable output ....
  - platform: esp8266_pwm
    pin: GPIO13
    inverted: True
light:
# ... and then make a light out of it.
  - platform: monochromatic
    name: "Outside Light Controller Blue LED"
    output: blue_led
  - platform: binary
    output: relay
  - platform: dht
    model: am2302
    pin: GPIO14
    temperature:
      name: "Sonoff Outside Temperature"
    humidity:
      name: "Sonoff Outside Humidity"
    update_interval: 30s
time:
  platform: homeassistant
  timezone: !secret timezone
  on_time:
  - hours: ${off_hour}
    minutes: 0
    seconds: 0
    then:
    - light.turn_off:
sun:
  latitude: !secret latitude
  longitude: !secret longitude
  on_sunset:
  - elevation: -10°
    then:
    - light.turn_on:
switch:
  - platform: restart
    name: "Outside Lights Restart"
Hasn’t changed in a long time.
Ok, I was looking to see if you had the model defined (auto can be problematic). You do so that’s not it.
You could try specifying DHT22 and see if that changes anything.
Tried DHT22 as part of troubleshooting… but no good. Opened a ticket on github, so will see what advice comes back.
I usually don’t bother updating my ESPHome devices unless there is a new feature I want.
Good advice, thanks Tom.
