Esphome 2023-4-0 update appears to break MAX7219Digit implementation
After updating to the new 2023-4-0 edition of ESPHome, all four of my ESP devices using the MAX7219 Matrix are displaying gibberish…backward characters, uneven scrolling. It’s a total mess. The update documentation doesn’t mention any changes to the MAX7219 implementation so I can only assume it’s anu unintended bug.
I can confirm that, same behavior here.
I have the same problem…
Looks like there is an open issue for it, which is the way to get it fixed.
Someone’s temporary fix.
Adding myself to the thread with the same issue.
Is there any option to go back to the old firmware? Put the new firmware somewhere… :frowning:
I had taken a backup before updating. I restored the system and re installed the esphome devices. That works for me. I don’t know of a way to save the firmware. I wouldn’t think that’s possible since the the firmware is rebuilt on every install for the device.
I don’t get it… according to PR #4727 it should be fixed since Apr 22, 9:59AM GMT+2
But I don’t understand what to do … :disappointed_relieved:
When will we be able to repair our MAX7219 displays ??
:sob:
This was my simple setup…
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "REDACTED"
ota:
  password: "REDACTED"
wifi:
  ssid: !secret wifi_ssid
  domain: REDACTED
  manual_ip:
    static_ip: 10.13.4.51
    gateway: 10.13.4.100
    subnet: 255.255.255.0
    dns1: 10.13.4.100
  ap:
    ssid: "Matrix-Display Fallback Hotspot"
    password: !secret hotspot_password
captive_portal:
time:
- platform: homeassistant
  timezone: Europe/Berlin
spi:
  clk_pin: D3
  mosi_pin: D1
status_led:
  pin: D4
font:
  - file: "fonts/pixelmix.ttf"
globals:
  - id: new_text
    type: int
    initial_value: "3"
  - id: txt_cycles
    type: int
    initial_value: "1"
text_sensor:
    entity_id: input_text.afficheur_txt
    on_value:
      then:
        lambda: |-
                    id(new_text) = 0;
display:
  - platform: max7219digit
    cs_pin: D2
    num_chips: 4
    intensity: 1
    scroll_speed: 50ms
    scroll_mode: STOP
    update_interval: 3s
    lambda: |-
      if (id(new_text) <= id(txt_cycles)) {
        if(id(new_text) == 0) {
          id(txt_cycles) = ceil(strlen(id(txt).state.c_str()) / 6);
        it.printf(0, 0, id(digit_font), "%s", id(txt).state.c_str());
        id(new_text)++;
      } else {
        it.strftime(0, 0, id(digit_font), " %H:%M", id(ha_time).now());
I don’t think this resolves my issue with the new release. I don’t use flip_x, reverse or any of the other options.
I think 2023.4.1 which is now released has a bug fix for this.
