So, as far as I know esphome 2024.7.0 comes with the micro_wake_word support. I use M5 Stack Echo 5 with the ready made projects from esp home website. As I had problems with the update from inside home assistant I removed my M5 from esp home and from HA and installed it new from the website. But when I want to add it it asks for the encryption key so I need to update it via cable.
But after that it does not start anymore and see error in logs
[08:52:45]E (823) esp_image: Image length 1835664 doesn't fit in partition length 1835008
[08:52:45]E (823) boot: OTA app partition slot 0 is not bootable
[08:52:45]E (825) esp_image: image at 0x1d0000 has invalid magic byte (nothing flashed here?)
[08:52:45]E (833) boot: OTA app partition slot 1 is not bootable
[08:52:45]E (839) boot: No bootable app partitions in the partition table
Latest version I used was the one before the timer released.
My next step was now to check the code on GitHub and here I saw I can not find the micro_wake_word in the code, latest update on GitHub was 2 weeks ago. Has that not been added yet?
But more important, why can I not install and run the m5 stack code anymore.
So the main problem seems to be when I try to adopt it, after installing it works and can be added to Home Assistant, but adapting into esp home breaks it what I see.
Same here. Tried out 2024.7.1 from both the Settings tab and ESP Home dashboard both seem to fail. I have this same result from the ESP Home dashboard gives me this extra detail.
RAM: [== ] 18.4% (used 60348 bytes from 327680 bytes)
Flash: [==========] 99.7% (used 1829021 bytes from 1835008 bytes)
Building .pioenvs/m5stack-atom-echo-0f9fc8/firmware.bin
Creating esp32 image…
Successfully created esp32 image.
esp32_create_combined_bin([“.pioenvs/m5stack-atom-echo-0f9fc8/firmware.bin”], [“.pioenvs/m5stack-atom-echo-0f9fc8/firmware.elf”])
Wrote 0x1d0250 bytes to file /data/build/m5stack-atom-echo-0f9fc8/.pioenvs/m5stack-atom-echo-0f9fc8/firmware.factory.bin, ready to flash to offset 0x0
esp32_copy_ota_bin([“.pioenvs/m5stack-atom-echo-0f9fc8/firmware.bin”], [“.pioenvs/m5stack-atom-echo-0f9fc8/firmware.elf”])
========================= [SUCCESS] Took 68.45 seconds =========================
INFO Successfully compiled program.
INFO Resolving IP address of m5stack-atom-echo-0f9fc8.local
ERROR Error resolving IP address of m5stack-atom-echo-0f9fc8.local. Is it connected to WiFi?
ERROR (If this error persists, please set a static IP address: WiFi Component — ESPHome)
ERROR Error resolving IP address: Error resolving address with mDNS: Did not respond. Maybe the device is offline., [Errno -5] No address associated with hostname
My only indication that it’s connecting at all is that I can turn on and off the listen light. Trying to pull up the logs in ESP Home Dashboard give sthis error.
WARNING Can’t connect to ESPHome API for m5stack-atom-echo-0f9fc8.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
But I think I am connected to it, since I can change the light. I’m not really sure.
I had been having some similar issues with my Atom Echo, which I described here:
Basically, I was out of flash, and had to disable the newly added OTA http_request platform. I also had to remove BLE Improv to make my device work as a proxy.
