This release brings two new data driven components to ESPHome.
The first is the UDP Component which allows direct communication between ESPHome devices over the local network. To start off, only sensor and binary sensor data can be transmitted, and hopefully more entity types will be supported in the future.
Next is the StatsD Component which allows you to send sensor data directly to a statsd server for monitoring.
There are a few breaking changes this release that will require changes in YAML if you are using the affected components. Please make sure to check the list below for details about each one. The documentation is always the best place to find the most up-to-date information on configuration for any given component found in ESPHome.
Did you know that Jesse and Keith both are employed at Nabu Casa to work full-time on ESPHome? Yep, that’s possible thanks to everyone who subscribes to Home Assistant Cloud. Thank you!
For the complete list of every merged pull request in this release, see the full 2024.9.0 changelog.
This is a companion discussion topic for the original entry at https://esphome.io/blog/2024/09/18/esphome-2024-9/
