ESPHome 3ch relay and switch
Hi Guys,
i using NodeMCU with 3 ch relay with external wall switch control and temperature sensor connected to it with Tosmata on it. I have used following GPIOS.
Relay 1 GPIO4 D2
Relay 2 GPIO12 D6
Relay 3 GPIO14 D5
Switch 1 GPIO5 D1
Switch 2 GPIO3 RX
Switch 3 GPIO13 D7
DHT11 GPIO01 TX
It works very well, all the switches connected to external wall switch which acts a 2 way switch.
  • Retains power state on boot
  • Control via existing wall switches as toggle and update status correctly on home assistant
  • Running on MQTT
Only problem with tosmata is everyday it stops responding and i need to restart them to work.
i have tried setting rule in tosmata but its still stop responding. Is there a way i can get this fixed? i will be more than happy if someone could help me out here.
if that’s not fixed then:
I am planning to move them to ESPhome but i have very limited knowledge in coding. i have managed to get the below code.
I have tried searching online but couldn’t get much information about how to proceed. I need the same features how its configured in tosmata. Please help if anyone know the coding.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxxxxxxxx"
  password: "xxxxxxxx"
  ap:
    ssid: "Living Room Esp Fallback Hotspot"
    password: "wo6sAy9HS7WY"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: "esphome"
ota:
  password: "esphome"
switch:
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D5
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxxxxxxxx"
  ap:
captive_portal:
# Enable logging
logger:
api:
  password: "esphome"
ota:
  password: "esphome"
switch:
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D5
  - platform: restart
    name: "Device Restart" # optional device restart switch, change the name
binary_sensor:
  - platform: gpio
    restore_mode: RESTORE_DEFAULT_OFF # Attempt to restore state and default to OFF if not possible to restore. Can also be RESTORE_DEFAULT_ON
    pin:
      number: D1
      mode: INPUT_PULLUP # if needed
    on_press:
      then:
        - switch.turn_on: relay1
    on_release:
      then:
        - switch.turn_off: relay1
  - platform: gpio
    pin:
      number: GPIO3
    on_press:
      then:
        - switch.turn_on: relay2
    on_release:
      then:
        - switch.turn_off: relay2
  - platform: gpio
    pin:
      number: D7
    on_press:
      then:
        - switch.turn_on: relay3
    on_release:
      then:
        - switch.turn_off: relay3
  - platform: status
    name: "Device Connection Status" # optional useful sensor, change the name
  - platform: dht
    pin: GPIO01
    model: DHT11
    temperature:
      name: "Whatever Temperature"
    humidity:
      name: "Whatever Humidity"
    update_interval: 60
  - platform: wifi_signal # optional useful sensor, change the name
    name: "WiFi Signal Sensor"
    update_interval: 60s
Thanks Tom for the quick reply.
I tried pasting this code but there seems to be some issue on line it give a red cross.
Errors on line number:
47, 59, 71, 93
error
This
update_interval: 60
Should be this:
Not sure how that happened, I copied it directly from the ESPHome example. Must have just missed the last character.
What are the errors on lines 47, 59, and 71?
EDIT: never mind, I see it. I put the restore option in the binary sensors instead of the relays, try this:
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxxxxxxxx"
  ap:
captive_portal:
# Enable logging
logger:
api:
  password: "esphome"
ota:
  password: "esphome"
switch:
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D5
  - platform: restart
binary_sensor:
  - platform: gpio
    pin:
      number: D1
    on_press:
      then:
    on_release:
      then:
  - platform: gpio
    pin:
      number: GPIO3
    on_press:
      then:
    on_release:
      then:
  - platform: gpio
    pin:
      number: D7
    on_press:
      then:
    on_release:
      then:
  - platform: status
  - platform: dht
    pin: GPIO01
    model: DHT11
    temperature:
    humidity:
Wow thanks again.
Everything works fine but just on power failure its goes to OFF state, its not restoring the last state on power failure.
I read something about this but don’t know how to add it.
Yeah that’s the issue. As long as you have read the warning and don’t expect the device to lose power that often:
esphome:
  platform: ESP8266
  board: nodemcuv2
  esp8266_restore_from_flash: true ### <-----Add it here ###
Great!!! its working like charm. Thank you Tom.
Here is the final code. I modified the toggle action.
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: "xxxx" # Enter the SSID here
  password: "xxxx" # Enter your password
  ap:
captive_portal:
# Enable logging
logger:
api:
  password: "esphome"
ota:
  password: "esphome"
switch:
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D6
  - platform: gpio
    pin: D5
  - platform: restart
binary_sensor:
  - platform: gpio
    pin:
      number: D1
  #    mode: INPUT_PULLUP # if needed
    on_press:
      then:
        - switch.toggle: relay1
    on_release:
      then:
  - platform: gpio
    pin:
      number: GPIO3
    on_press:
      then:
        - switch.toggle: relay2
    on_release:
      then:
  - platform: gpio
    pin:
      number: D7
    on_press:
      then:
        - switch.toggle: relay3
    on_release:
      then:
  - platform: status
  - platform: dht
    pin: GPIO01
    model: DHT11
    temperature:
    humidity:
Can I ask why?
This has the possibilty of getting out of sync. Before you were guaranteed that the relay would turn on when the binary sensor was on, and off when the binary sensor is off.
If you are using momentary switches instead of toggle switches you can simplify the code to just this for the binary sensors:
binary_sensor:
  - platform: gpio
    pin:
      number: D1
    on_press:
      then:
  - platform: gpio
    pin:
      number: GPIO3
    on_press:
      then:
  - platform: gpio
    pin:
      number: D7
    on_press:
      then:
I am using the following button.
switch
Its not a push button. It will stay in same state until we switch it back and when the circuit is closed it needs to toggle and when its released.
