So using the esphome flasher tool;
[2020-07-13 17:05:23,881][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:400][INFO]: ************
[2020-07-13 17:05:23,884][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:401][INFO]: check_res: (True, [[u’C:\\Users\\sam.williams\\Downloads\\kitchen001.bin’, 65536]])
[2020-07-13 17:05:23,887][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:402][INFO]: is running : False
[2020-07-13 17:05:23,888][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:403][INFO]: ************
[2020-07-13 17:05:23,888][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
[2020-07-13 17:05:23,891][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/IDLE_S.bmp
[2020-07-13 17:05:23,891][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
[2020-07-13 17:05:23,941][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:706][INFO]: rep_path: C:\Users\sam.williams\Desktop\flash_download_tool_v3.8.5\dl_temp/bin_tmp\downloadPanel1
[2020-07-13 17:05:23,944][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:713][INFO]: offset: 65536
[2020-07-13 17:05:23,944][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:714][INFO]: filename: C:\Users\sam.williams\Downloads\kitchen001.bin
[2020-07-13 17:05:23,944][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:715][INFO]: self.cp.disable_change_bin: 1
[2020-07-13 17:05:23,946][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:716][INFO]: ----------------
[2020-07-13 17:05:23,950][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:434][INFO]: TEST!!!
[2020-07-13 17:05:23,951][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:435][INFO]: SELF.COMSTR: COM3
[2020-07-13 17:05:23,953][EspDownloadThread][download_panel_info.py][line:788][INFO]: test running: False
CONNECT BAUD: 115200
[2020-07-13 17:05:24,279][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
[2020-07-13 17:05:24,279][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/SYNC_S.bmp
[2020-07-13 17:05:24,280][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
………………………………………………………………………………………………………………………………………………………………………_____[2020-07-13 17:09:43,019][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:494][INFO]: *********************
[2020-07-13 17:09:43,019][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:495][INFO]: pic path: ./RESOURCE/IDLE_S.bmp
[2020-07-13 17:09:43,022][EspDownloadPanel_ESP32_spi(1)][download_panel_info.py][line:496][INFO]: ***********************
…[2020-07-13 17:09:44,201][ESP8266Loader_spi[1]][espDownloader.py][line:391][ERROR]: Chip sync error: Failed to connect to ESP32: Timed out waiting for packet header
[2020-07-13 17:09:44,201][ESP8266Loader_spi[1]][espDownloader.py][line:550][ERROR]: ESP32 Chip sync error esp_sync_blocking.
no log file output …
With this setup;
When using hassio addon;
INFO Reading configuration /config/esphome/kitchen001.yaml…
INFO Generating C++ source…
INFO Compiling app…
INFO Running: platformio run -d /config/esphome/kitchen001
Processing kitchen001 (board: esp32doit-devkit-v1; framework: arduino; platform: [email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
PACKAGES:
- framework-arduinoespressif32 3.10004.200129 (1.0.4)
- tool-esptoolpy 1.20600.0 (2.6.0)
- toolchain-xtensa32 2.50200.80 (5.2.0)
Dependency Graph
|-- 1.1.1
|-- 1.0
| |-- 1.0
|-- 1.0
|-- 1.2.6
| |-- 1.1.1
| |-- 1.0
| |-- 1.0
|-- 1.1.0
| |-- 1.0
|-- 1.0
|-- 1.0
Compiling /data/kitchen001/.pioenvs/kitchen001/src/main.cpp.o
Linking /data/kitchen001/.pioenvs/kitchen001/firmware.elf
Retrieving maximum program size /data/kitchen001/.pioenvs/kitchen001/firmware.elf
Checking size /data/kitchen001/.pioenvs/kitchen001/firmware.elf
Building /data/kitchen001/.pioenvs/kitchen001/firmware.bin
Advanced Memory Usage is available via “PlatformIO Home > Project Inspect”
RAM: [= ] 12.9% (used 42320 bytes from 327680 bytes)
Flash: [===== ] 53.1% (used 870262 bytes from 1638400 bytes)
========================= [SUCCESS] Took 6.91 seconds =========================
INFO Successfully compiled program.
INFO Running: platformio run -d /config/esphome/kitchen001 -t upload --upload-port /dev/ttyUSB0
PACKAGES:
- tool-mkspiffs 2.230.0 (2.30)
Dependency Graph
|-- 1.1.1
|-- 1.0
| |-- 1.0
|-- 1.0
|-- 1.2.6
| |-- 1.1.1
| |-- 1.0
| |-- 1.0
|-- 1.1.0
| |-- 1.0
|-- 1.0
|-- 1.0
Configuring upload protocol…
AVAILABLE: esp-prog, espota, esptool, iot-bus-jtag, jlink, minimodule, olimex-arm-usb-ocd, olimex-arm-usb-ocd-h, olimex-arm-usb-tiny-h, olimex-jtag-tiny, tumpa
CURRENT: upload_protocol = esptool
Looking for upload port…
Use manually specified: /dev/ttyUSB0
Uploading /data/kitchen001/.pioenvs/kitchen001/firmware.bin
Serial port /dev/ttyUSB0
Connecting…………………_____
A fatal error occurred: Failed to connect to ESP32: Timed out waiting for packet header
*** [upload] Error 2
========================= [FAILED] Took 26.62 seconds =========================
with this setup:
This is the yaml i’m compiling;
esphome:
platform: ESP32
wifi:
ssid: "Home"
password: "<REMOVED>"
ap:
ssid: "Kitchen001 Fallback Hotspot"
password: "LO1XyjS08GbF"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
I’ve tried with NodeMCU board as well.
I’ve tried holding the boot button and the EN button, but nothing works
