Hello, at the moment I paused this “project” since I am very busy at work and I don’t have the “head” to continue with it when I come back home.
…anyway
For the first part I think that we are “locked” to the esphome developers.
I think that they have to add the “custom modes” on the main code, so we can use it on our projects.
For the second part instead, I partially solved using variables and a button.
the problem
At the moment to find which sensor triggered the alarm is very hard, because you have to check in every sensors’ history if at the moment of the alarm, the sensor has been triggered or not and if it was the main cause or if it was triggered few seconds later by you when entering home to disarm the alarm.
So, I created a set of variables directly on the esp, so when a sensor is triggered its status is immediately copied into the variable and visualized on HA.
To reset these variables to the default state I have added a button.
what it does
Basically I defined an array of bool to reflect the number of input on the Konnect alarm pro
globals:
- id: zone_alm_pre_set
type: bool[13]
restore_value: no
initial_value: '{false, false, false, false, false, false, false, false, false, false, false, false, false}'
then I created a button template for the variables’ reset.
button:
icon: mdi:restart
on_press:
then:
- lambda: |-
for (int i = 0; i < 13; i++) {
if (i == 7 || i == 8) { continue; }
id(zone_alm_pre_set)[i] = false;
Now for each sensor I added an “on_press” action, to set the variable on TRUE if some conditions are met.
So, for example, when motion is detected on living room and the alarm is armed (state 3, 4 or 5), it set the variable to true.
- id: !extend zone10 # radar 1 - piano terra - soggiorno
device_class: motion
on_press:
then:
- lambda: |-
if ((id(zone10).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[10] = true;
Now the variable’s value remains true until the state of the alarm panel is not 7 or when the reset button is pressed on Home Assistant.
device_class: problem
lambda: |-
if (id(zone_alm_pre_set)[10] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[10] && id(stato_antifurto).state != 7) {
return false;
return id(zone10_alm).state;
As you can see below, the alarm is triggered and on the right column I have the cause (input A10 my living room radar).
Below, a warning related to the power supply (it is ok since the battery is not connected) and finally the “azzera” button that reset the variables.
the code
This the code of the Konnected master, my last update was on Jan 11…
Please note that this is still raw code and need to be optimized and polished…
# KONNECTED - MASTER
# info
# versione. 1.0
# data ultima modifica. 11.01.2024
# indirizzo ip. 192.168.207.64
substitutions:
friendly_name: konnected-pro-master
packages:
konnected.alarm-panel-pro-ethernet: github://konnected-io/konnected-esphome/alarm-panel-pro-v1.8-ethernet.yaml@master
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: !secret master_api
# UDP: configurazione
udp:
encryption: !secret master_upd
rolling_code_enable: true
update_interval: 5s
addresses:
- 192.168.207.65 # sec 1
- 192.168.207.66 # sec 2
sensors:
- stato_antifurto
providers:
- name: konnected-sec-1 # secondaria 1
encryption: !secret sec_1_udp
- name: konnected-8d4324 # secondaria 2
encryption: !secret sec_2_udp
# ANTIFURTO: pannello allarme
# note.
# bypass_armed_home - escluse finestre terra e camere
# bypass_armed_night - esclusi radar terra e camere
alarm_control_panel:
requires_code_to_arm: false
arming_away_time: 5s
arming_home_time: 5s
arming_night_time: 5s
pending_time: 30s
restore_mode: RESTORE_DEFAULT_DISARMED
codes:
- "0000"
on_arming:
then:
- lambda: 'id(stato_antifurto).publish_state(1);'
on_pending:
then:
- lambda: 'id(stato_antifurto).publish_state(2);'
on_armed_home:
then:
- lambda: 'id(stato_antifurto).publish_state(3);'
on_armed_night:
then:
- lambda: 'id(stato_antifurto).publish_state(4);'
on_armed_away:
then:
- lambda: 'id(stato_antifurto).publish_state(5);'
on_disarmed:
then:
- lambda: 'id(stato_antifurto).publish_state(6);'
on_triggered:
then:
- switch.turn_on: alarm1
- lambda: 'id(stato_antifurto).publish_state(7);'
on_cleared:
then:
- switch.turn_off: alarm1
- lambda: 'id(stato_antifurto).publish_state(8);'
on_ready:
then:
- lambda: 'id(stato_antifurto).publish_state(9);'
binary_sensors:
# liberi
# - input: zone6 #
# bypass_armed_home: false
# bypass_armed_night: false
# trigger_mode: instant
# - input: zone7 # alimentatore - batteria bassa
# - input: zone8 # alimentatore - mancanca AC
# - input: zone9 #
# non escludibili
- input: zone4 # gruppo sempre [rele da sec 1] - radar taverna, gruppo velux e porta-finestra portico
# notte
- input: zone1 # gruppo escludi [rele da sec 1] - radar camere e piano terra
bypass_armed_night: true
# via con taparelle aperte
- input: zone2 # gruppo escludi [rele da sec 2] - finestre piano terra
bypass_armed_home: true
- input: zone3 # gruppo escludi [rele da sec 2] - finestre/porte-finestre piano superiore
# con ritardo
- input: zone5 # gruppo inizio ritardo [rele da sec 2] porta ingresso o basculante box
chime: true
trigger_mode: delayed
- input: zone10 # radar 1 - terra - soggiorno
bypass_armed_home: false # escluso se se va via con finestre aperte
bypass_armed_night: true #
trigger_mode: delayed_follower
- input: zone11 # radar 4 - terra - box
bypass_armed_night: true # posso andare nel box di notte
- input: zone12 # sensore - terra - porta - box/soggiorno
# OUTPUT: configurazione
globals:
type: bool[13]
restore_value: no
button:
icon: mdi:restart
on_press:
then:
- lambda: |-
icon: mdi:restart
on_press:
then:
- lambda: |-
id(zone_alm_pre_set)[7] = false;
id(zone_alm_pre_set)[8] = false;
# note.
# stato dell'antifurto da inviare alle schede secondarie per lo storico, indicare quale sensore sulla secondaria ha fatto suonare l'antifurto
# 0 -
# 1 - antifurto in attivazione (inserito)
# 2 - pending
# 3 - modo a casa (radar on e resto su ma finestre piano e camere escluse)
# 4 - modo notte (tutto su tranne i radar)
# 5 - modo fuori casa (tutto su, niente escluso)
# 6 - antifurto tolto
# 7 - antifurto scattato
# 8 - antifurto tolto dopo aver suonato
# 9 - pronto all'avvio o dopo il disarmed
update_interval: never
internal: true
#switch:
binary_sensor:
# liberi
- id: !extend zone6 # -
on_press:
then:
- lambda: |-
if ((id(zone6).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[6] = true;
- id: !extend zone9 # -
on_press:
then:
- lambda: |-
if ((id(zone9).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[9] = true;
# alimentatore
- id: !extend zone7 # alimentatore - batteria bassa
device_class: battery
# on_press:
# then:
# - lambda: |-
# if ((id(zone7).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
# id(zone_alm_pre_set)[7] = true;
- id: !extend zone8 # alimentatore - AC ok
device_class: power
pin:
inverted: true
# on_press:
# then:
# - lambda: |-
# if ((id(zone8).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
# id(zone_alm_pre_set)[8] = true;
# radar
- id: !extend zone1 # radar - [da sec 1] gruppo radar piano superiore e terra (cucina e bagno)
on_press:
then:
- lambda: |-
if ((id(zone11).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[11] = true;
on_press:
then:
- lambda: |-
- id: !extend zone11 # radar 4 - terra - box
on_press:
then:
- lambda: |-
# finestre
- id: !extend zone2 # sensore - [da sec 2] gruppo finestre piano terra
device_class: window
on_press:
then:
- lambda: |-
if ((id(zone2).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[2] = true;
- id: !extend zone3 # sensore - [da sec 2] gruppo finestre e porte finestre piano superiore
on_press:
then:
- lambda: |-
if ((id(zone3).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[3] = true;
# varie
- id: !extend zone4 # sensore/radar - [da sec 1] gruppo: velux, radar taverna e porta-finestra portico
on_press:
then:
- lambda: |-
if ((id(zone4).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[4] = true;
# porte
- id: !extend zone5 # sensore - terra - [da sec 2] porta ingresso o basculante
device_class: door
on_press:
then:
- lambda: |-
if ((id(zone5).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[5] = true;
- id: !extend zone12 # sensore - terra - porta box-soggiorno
device_class: door
on_press:
then:
- lambda: |-
if ((id(zone12).state) && (id(stato_antifurto).state == 3 || id(stato_antifurto).state == 4 || id(stato_antifurto).state == 5)) {
id(zone_alm_pre_set)[12] = true;
# basculante box
# virtuali - storico attivazione
lambda: |-
if (id(zone_alm_pre_set)[1] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[1] && id(stato_antifurto).state != 7) {
return false;
return id(zone01_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[2] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[2] && id(stato_antifurto).state != 7) {
return false;
return id(zone02_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[3] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[3] && id(stato_antifurto).state != 7) {
return false;
return id(zone03_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[4] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[4] && id(stato_antifurto).state != 7) {
return false;
return id(zone04_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[5] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[5] && id(stato_antifurto).state != 7) {
return false;
return id(zone05_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[6] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[6] && id(stato_antifurto).state != 7) {
return false;
return id(zone06_alm).state;
lambda: |-
if (id(zone7).state) {
return id(zone_alm_pre_set)[7];
lambda: |-
if (!id(zone8).state) {
return id(zone_alm_pre_set)[8];
lambda: |-
if (id(zone_alm_pre_set)[9] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[9] && id(stato_antifurto).state != 7) {
return false;
return id(zone09_alm).state;
lambda: |-
return true;
return false;
lambda: |-
if (id(zone_alm_pre_set)[11] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[11] && id(stato_antifurto).state != 7) {
return false;
return id(zone11_alm).state;
lambda: |-
if (id(zone_alm_pre_set)[12] && id(stato_antifurto).state == 7) {
return true;
} else if (!id(zone_alm_pre_set)[12] && id(stato_antifurto).state != 7) {
return false;
return id(zone12_alm).state;
I connected 3 Konneted
using wires (grouping floor sensors, like motion on upper floor) so the alarm can work even when the network is down.
Something like this:
If a radar detect motion on the upper floor, the alarm panel on the master will be triggered by the “upper floor motion sensors”, and on HA I will have the right sensor on the history (since the code with variable is even on the secondary Konnected)
but now it live on my desk covered by stuff and dust… ![]()
Sorry, I wrote it in hurry so maybe there will be a lot of typo and grammar errors (as you probably noticed English is not my main language).
