Here is my updated schematic, which is working for me !
I also made the yaml code ready:
esphome:
friendly_name: GarageDoorOpener
#on_boot:
# priority: -100
# then:
# - light.turn_on:
# id: onboard_led_pwm
# effect: "slow"
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "Zq+TzloCQg+YcgnPaEWxTBUMpajQWV4dy254F9cfhZ4="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-9750B8"
password: "NCYi9k0FE2CH"
captive_portal:
#esp32_camera: #NOT WORKING IF ANYTHING ELSE IS IN YAML CODE
# name: My ESP32-CAM
# external_clock:
# pin: GPIO0
# frequency: 20MHz
# i2c_pins:
# sda: GPIO26
# scl: GPIO27
# data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
# vsync_pin: GPIO25
# href_pin: GPIO23
# pixel_clock_pin: GPIO22
# power_down_pin: GPIO32
# #contrast: 0
# #brightness: 0
# #saturation: 0
# resolution: 1600x1200
#esp32_camera_web_server:
# - port: 8080
# mode: stream
# - port: 8081
# mode: snapshot
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: WiFi Signal dB
update_interval: 10s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
#on_value:
# then:
# - light.turn_on:
# id: onboard_led
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
- platform: uptime
binary_sensor:
- platform: status
- platform: gpio
device_class: light
pin:
number: GPIO13
mode:
input: true
pulldown: true
on_press:
output.turn_on:
on_release:
output.turn_off:
#- platform: gpio
# pin:
# number: GPIO14
# inverted: true
# mode:
# input: true
# pulldown: true
# name: "OPEN"
button:
- platform: output
output: gpio_16
duration: 1000ms
# Optional variables:
icon: "mdi:garage"
on_press:
# - logger.log: "Impuls Button pressed"
# - light.turn_on:
# effect: flashfast
# - delay: 500ms
# - if:
# condition:
# light.is_on: onboard_led
# then:
# - light.turn_on:
# #id: onboard_led
# effect: "constant_on"
# else:
# - light.turn_on:
# effect: "slow"
- output.turn_on:
# - delay: 500ms
# - output.turn_off:
# id: gpio_33
light:
# GPIO_4 is the flashlight pin
- platform: binary
output: gpio_4
# GPIO_33 is the onboard led
#- platform: binary
# output: gpio_33
# id: onboard_led
# name: onboard_led
# on_turn_on:
# - light.turn_on:
# #id: onboard_led
# on_turn_off:
# - light.turn_on:
# effect: "slow"
## On-Board LED PWM
#- platform: monochromatic
# output: gpio_33_pwm
# effects:
# - pulse:
# name: flashfast
# transition_length: 0.0s
# update_interval: 0.04s
# - pulse:
# name: fast
# transition_length: 0.5s
# update_interval: 0.5s
# - pulse:
# name: "slow"
# #transition_length: 1s # defaults to 1s
# update_interval: 2s
# - pulse:
# name: "constant_on"
# #transition_length: 0.5s
# #update_interval: 0.5s
# min_brightness: 100%
# max_brightness: 100%
# Example configuration entry
status_led:
pin:
number: GPIO33
inverted: true
output:
# Flashlight
- platform: gpio
pin: GPIO4
- platform: gpio
pin: GPIO16
# onboard led
- platform: gpio
pin:
number: GPIO33
inverted: true
#- platform: ledc
# id: gpio_33_pwm
# pin:
# number: GPIO33
# inverted: true
If somebody want to order a pcb I made oneâŚ:
Unfortunately I canât upload the gerber files because zip files are not allowed.
Anyhow here is the project:
This also is the true for stl files of my printed housing I designed, so here is the project:
The wifi signal is not strong but still working, we will see how reliable it is:
Edit:
Just like I expected wifi signal isnât reliable enough so it happens that the door opener isnât available.
This especially happens if the (metal) door is closed, so it canât be opened again.
I already used an external antenna for the esp.
Also I tried a repeater but also the repeater doesnât receive a signal which is strong enoughâŚ
At the beginning my idea was to use a 433MHz transmitter / receiver but this seems not a good idea.
What else can I do to get the garage door opener working reliable ?
