rdehuyss
(Ronald Dehuysser)
September 17, 2020, 11:31pm
1
I’m trying to combine Android Beacon Simulator, ESPHome and ble_presence for presence detection.
The Android Beacon Simulator emits an IBeacon with a UUID. I’m trying to capture that UUID with esphome as follows:
binary_sensor:
- platform: ble_presence
service_uuid: '50B04BBB-7B26-06AC-7441-92140A6A9E2b'
name: "Ronald BLE GSM"
If I turn on very_verbose logging, I see the UUID passing by but it is not yet recognized by ESPHome.
So, I think there still is a bug… see https://github.com/esphome/issues/issues/1486
Is there anybody with some C++ knowledge and BLE knowledge who can chip in?
rdehuyss
(Ronald Dehuysser)
September 17, 2020, 11:49pm
2
Mmm, I might be able to get it to work using
rdehuyss
(Ronald Dehuysser)
September 18, 2020, 12:29am
3
Bingo:
[00:24:29][D][ble_adv:404]: New BLE device
[00:24:29][D][ble_adv:415]: Advertised manufacturer data:
[00:24:29][D][ble_adv:417]: - 02.15.2B.9E.6A.0A.14.92.41.74.AC.06.26.7B.BB.4B.B0.50.00.00.00.00.BF (23)
This is broadcasted every 15sec or so. I hope I can finally make my presence detection working!
pepe59
(Pepe59)
September 23, 2020, 7:32pm
5
You can share the code in ESP32. I’m not wise how to set it. Mac address is tracked phone? Service uuid id is uuid what creates Beacon Simulator? If I set up scan esp32 ble tracker won’t find mac phone.Thank you
pepe59
(Pepe59)
September 24, 2020, 9:27am
6
I tried the nrfConnect app and it works well for rssi ESP32, but I didn’t find how to let it run in the background so it’s not very useful.
rdehuyss
(Ronald Dehuysser)
September 24, 2020, 10:58am
7
Not yet - not enough time
Are you able to share your esphome.yaml file showing how you used
on_ble_manufacturer_data_advertise
and possibly your beacon simulator settings?
I can’t figure out how to get it working.
Thank you!
rdehuyss
(Ronald Dehuysser)
September 30, 2020, 9:17pm
9
Here you go… if you make it happen, please share back
esp32_ble_tracker:
on_ble_advertise:
- then:
# - if:
# condition:
# lambda: |-
# for (auto data : x.get_manufacturer_datas()) {
# return (strcmp(hexencode(data.data).c_str(), "02.15.2B.9E.6A.0A.14.92.41.74.AC.06.26.7B.BB.4B.B0.50.00.00.00.00.BF (23)") == 0);
# return false;
# then:
- lambda: |-
ESP_LOGD("ble_adv", "New BLE device");
ESP_LOGD("ble_adv", " rssi: %d", x.get_rssi());
ESP_LOGD("ble_adv", " Advertised manufacturer data:");
ESP_LOGD("ble_adv", " - %s", hexencode(data.data).c_str());
if (strcmp(hexencode(data.data).c_str(), "02.15.2B.9E.6A.0A.14.92.41.74.AC.06.26.7B.BB.4B.B0.50.00.00.00.00.BF (23)") == 0) {
ESP_LOGD("ble_adv", "in if");
carlosatta
(Carlo Satta)
November 14, 2020, 11:32am
10
I think this works
esp32_ble_tracker:
on_ble_advertise:
- then:
- lambda: |-
bool redmi_note_9_pro_status = false;
if (strcmp(hexencode(data.data).c_str(), "02.15.49.01.F3.6B.E9.1A.44.B7.B3.62.FF.2E.B6.43.05.04.00.00.00.00.BF (23)") == 0) {
ESP_LOGD("ble_adv", "redmi_note_9_pro found");
redmi_note_9_pro_status = true;
id(redmi_note_9_pro).publish_state(redmi_note_9_pro_status);
binary_sensor:
device_class: presence
name: "Redmi Note 9 Pro BLE presence"
filters:
- delayed_off: 3s
whit this code (thank @rdehuyss ) I can track my android phone with the app beacon simulator
stast
(Stanislav)
November 14, 2020, 4:41pm
11
That’s better:
binary_sensor:
name: "Lenovo P2 BLE"
script:
- id: ble_off_script
mode: restart
then:
- binary_sensor.template.publish:
state: true
- delay: 60s
state: false
esp32_ble_tracker:
on_ble_advertise:
- then:
- lambda: |-
if (strcmp(hexencode(data.data).c_str(), "02.15.1A.D3.91.06.87.AC.4D.35.A3.60.5A.96.49.FC.E7.2E.00.00.00.00.BF (23)") == 0) {
ESP_LOGD("ble_adv", "Lenovo P2 found");
id(ble_off_script).execute();
else
nontijt
(nontijt)
November 14, 2020, 6:18pm
12
thanks, and thank you to the original poster for this. I just got it working myself. I find the range is a bit limited to usefull for me… It is really only for one room around 5-6 m away from the ESP32 device.
how would this look for two devices?
This part I have figured out ofc.
- id: ble_off_script_phone1
mode: restart
then:
state: true
- delay: 60s
state: false
- id: ble_off_script_phone2
mode: restart
then:
state: true
- delay: 60s
state: false
- id: etc
But what part needs to be copied in the “on_ble_advertise:” part?
stast
(Stanislav)
November 14, 2020, 6:50pm
13
Try this
esp32_ble_tracker:
on_ble_advertise:
- then:
- lambda: |-
id(ble_off_script_phone1).execute();
else if (strcmp(hexencode(data.data).c_str(), "02.15.1A.D3.91.06.87.AC.4D.35.A3.60.5A.96.49.FC.E7.2E.00.00.00.00.BF (23)") == 0)
ESP_LOGD("ble_adv", "Lenovo P3 found");
id(ble_off_script_phone2).execute();
else
nontijt
(nontijt)
November 14, 2020, 7:18pm
14
Thanks. that looks nice and logical as well
stast
(Stanislav)
November 14, 2020, 7:36pm
15
You may also need to increase the delay. I stopped at 120s for now.
nontijt
(nontijt)
November 14, 2020, 7:39pm
16
If you go with the if, else if, else solution, I get a multiline warning.
Compiling /data/wemos_d1_mini_1/.pioenvs/wemos_d1_mini_1/src/main.cpp.o
src/main.cpp:331:3: warning: multi-line comment [-Wcomment]
// - lambda: !lambda "for (auto data : x.get_manufacturer_datas()) \n{\n if (strcmp(hexencode(data.data).c_str(),\
but the code works anyway. So I dont bother too much about it.
PS, what is the range you guys get with this BLE solution?
stast
(Stanislav)
November 15, 2020, 11:54am
17
Somewhere 5 meters. You can increase the power in Android Beacon Simulator, but that’s enough for me.
josemsubcn
(josemsubcn)
February 14, 2021, 10:09am
18
Is there any posibility to send to HA the RSSI power by a sensor addiotionally to send Home/Not Home binary sensor?.
I want to mix this functionnality with Room Assistant, but I don’t know how to do it…
Thanks,
Jose
nontijt
(nontijt)
February 20, 2021, 8:55am
19
Should be possible
Create a binary sensor and have it turn on off above of below a threshold. You can do inside ESPHOME code.
If you dont know how, i can look tonight
lunaras
(Mike Farwell)
March 5, 2021, 1:49am
20
Thank you to everyone on this thread. I was finally able to get an RSSI sensor set up using Beacon Simulator. Until I came across this I couldn’t figure out why I could never find the beacon via UUID.
For anyone else that is trying to do the same, here’s the relevant yaml I used to get it to work, where C3:D1:26:E2:7E:B1:43:EF:AE:59:82:48:D5:33:17:1C
is the UUID entered in the Beacon Simulator app:
esp32_ble_tracker:
on_ble_advertise:
- then:
- lambda: |-
if(x.get_ibeacon().has_value()) {
auto ibeacon = x.get_ibeacon().value();
if(strcmp(ibeacon.get_uuid().to_string().c_str(), "C3:D1:26:E2:7E:B1:43:EF:AE:59:82:48:D5:33:17:1C") == 0) {
id(my_rssi).publish_state(x.get_rssi());
name: "$friendlyname My RSSI"
icon: "mdi:mdi-signal-distance-variant"
update_interval: never
unit_of_measurement: "dBm"
filters:
- sliding_window_moving_average:
window_size: 5
send_every: 1
