ESPhome and AS3935 wiring
Hello.
I plan to buy an as3935 sensor and search the web for wiring and proper lightning sensor configuration. But I found different involvement and also different problems.
Is this the correct connection and configuration (I2C)?
wiring on web (AS3935 Franklin Lightning sensor - Tasmota):
esphome yaml:
i2c:
  scl: D1
  sda: D2
  scan: True
as3935_i2c:
  irq_pin: GPIO13
  indoor: False
  spike_rejection: 5
  - platform: as3935
    lightning_energy:
    distance:
binary_sensor:
  - platform: as3935
Yes the wiring looks correct according to the datasheet.
And the ESPHome config is good too (assuming you are using a Wemos D1 mini).
