lboue
(Ludovic)
July 8, 2024, 9:25pm
1
ESPHome and Elecrow CrowPanel 7.0"
I’ve finally managed to display something using ESPHome on my Elecrow CrowPanel 7.0" hardware version 2.1:
# Touchscreen gt911 i2c
touchscreen:
platform: gt911
display: my_display
interrupt_pin: 38
i2c:
sda: 19
scl: 20
scan: true
display:
- platform: rpi_dpi_rgb
data_pins:
red:
- 14
- 21
- 47
- 48
- 45
green:
- 9
- 46
- 3
- 8
- 16
- 1
blue:
- 15
- 7
- 6
- 5
- 4
de_pin: 41
hsync_pin: 39
vsync_pin: 40
pclk_pin: 0
hsync_front_porch: 40
hsync_pulse_width: 48
hsync_back_porch: 13
vsync_front_porch: 1
vsync_pulse_width: 31
vsync_back_porch: 13
pclk_inverted: true
pclk_frequency: 8500000
color_order: RGB
auto_clear_enabled: false
update_interval: 5s
dimensions:
width: 800
height: 480
lambda: |-
auto black = Color(0, 0, 0);
auto red = Color(255, 0, 0);
auto green = Color(0, 255, 0);
auto blue = Color(0, 0, 255);
auto white = Color(255, 255, 255);
it.filled_circle(20, 32, 15, black);
it.filled_circle(40, 32, 15, red);
it.filled_circle(60, 32, 15, green);
it.filled_circle(80, 32, 15, blue);
it.filled_circle(100, 32, 15, white);
Doc preview: RPI_DPI_RGB Display Driver, section Elecrow CrowPanel 7.0” 800x480
nog3
(Brendan Halliday)
July 13, 2024, 12:43pm
2
Is there any chance you could please share the rest of the YAML for your testing?
I’ve successfully compiled and uploaded, but blank screen on the display still. I suspect my board type is set wrong or the backlight isn’t being turned on.
goosecrew
(Paulstrong)
July 18, 2024, 4:59pm
3
I have a similar problem. the screen is black and nothing is displayed.
I think it might be important - I have version v3.0, and you?
goosecrew
(Paulstrong)
July 18, 2024, 6:14pm
4
I tried to install open hasp and I succeeded, some kind of night release, https://nightly.openhasp.com
lboue
(Ludovic)
July 21, 2024, 8:12pm
6
I have hardware version 2.1.
goosecrew
(Paulstrong)
July 21, 2024, 9:33pm
7
Apparently, there are some features in v3.0. Anyway, I’m glad that I came across OpenHASP, a cool thing.
nog3
(Brendan Halliday)
July 21, 2024, 11:40pm
8
I also have 2.1. Can you please share the full yaml with the esp32/platform version you are using?
lboue
(Ludovic)
July 23, 2024, 7:53am
9
The display is not stable. You have to wait a long time. It doesn’t work every time.
esphome:
friendly_name: Elecrow CrowPanel 7.0 RGB
platformio_options:
# see https://community.home-assistant.io/t/esp32-with-esp-idf-framework-running-into-a-boot-loop/567305/11
board_build.flash_mode: dio
# see https://community.home-assistant.io/t/esp32-s3-devkitc-1-n16r8-using-psram-howto/652601
build_flags: "-DBOARD_HAS_PSRAM"
esp32:
board: esp32-s3-devkitc-1
framework:
#type: arduino
type: esp-idf
psram:
mode: octal
speed: 80MHz
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "*************"
ota:
- platform: esphome
password: "***********"
wifi:
ssid: !secret wifi_ssid
# see https://www.reddit.com/r/Esphome/comments/13ee5n8/comment/jjptvux/
power_save_mode: none
ap:
ssid: "Elecrow-Crowpanel-70-Rgb"
password: "vPeb0A44Lpq1"
captive_portal:
i2c:
sda: 19
scl: 20
scan: true
display:
data_pins:
red:
- 14
- 21
- 47
- 48
- 45
green:
- 9
- 46
- 3
- 8
- 16
- 1
blue:
- 15
- 7
- 6
- 5
- 4
de_pin: 41
hsync_pin: 39
vsync_pin: 40
pclk_pin: 0
pclk_inverted: true
color_order: RGB
update_interval: 5s
dimensions:
width: 800
height: 480
show_test_card: true
lambda: |-
touchscreen:
platform: gt911
display: disp0
interrupt_pin: 38
output:
- platform: ledc
pin: 2
light:
- platform: monochromatic
output: backlight_pin
restore_mode: RESTORE_DEFAULT_ON
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
@lboue Is it still unstable?
lboue
(Ludovic)
September 2, 2024, 8:30pm
11
Yes, it’s always unstable. I’ve given up.
RyanEwen
(Ryan Ewen)
October 10, 2024, 8:36pm
12
I have a different device using the same display driver and it is also unstable… except I found someone using specific / older versions which helped a lot with my device. Maybe try this on yours:
esp32:
framework:
type: esp-idf
# these versions prevent artifacting
version: 5.1.2
platform_version: 6.5.0
clydebarrow
(Clyde Stubbs)
October 15, 2024, 10:42pm
13
enjoysap
(Oliver Hepp)
November 18, 2024, 10:48pm
14
Hi
i also tried to use openHASP wtih my Crowpanel 7.0 Version 3
everything works, but not the touch
then I built my own build here, but unfortunately without success.
Touch didn’t work with my own build either.
Touchsettings in crowpanel-hmi.ini
see openHASP/user_setups/esp32s3/crowpanel-hmi.ini at 355e1dbddaf65b555de4c2ee94b627760b9e9e45 · HASwitchPlate/openHASP · GitHub
But I have the exact values as in ESPHome where the same touchpanel works
; Touch Settings
-D HASP_USE_LGFX_TOUCH=1
-D TOUCH_WIDTH=800
-D TOUCH_HEIGHT=480
-D TOUCH_DRIVER=0x911
-D TOUCH_SCL=20
-D TOUCH_SDA=19
-D TOUCH_IRQ=-1
-D TOUCH_RST=-1
-D I2C_TOUCH_ADDRESS=0x5D
-D I2C_TOUCH_FREQUENCY=400000
are similar to ESPHome Settings
for Touch
i2c:
sda: 19
scl: 20
touchscreen:
platform: gt911
display: main_display
update_interval: 50ms
address: 0x5D
if i run mqtt publish to the device
hasp/crowpanel_7/state/statusupdate
the rsponse is
“tftDriver”: “Other”,
Do you have success with the touch ?
Regards Oliver
#openhasp
Hello, for anyone still trying to setup the Elecrow CrowPanel 7" with the ESPHome, after some debugging and research, we have written an article on how to make it work
The culprit is mostly that i needs additional configuration for vsync and hsync, which is not provided in the official documentation.
The touch screen is also functioning properly and I am able to adjust the screen backlight’s brightness. In case anyone’s interested, you can read here .
So it’s not necessary to fall back to openHASP.
Olivier974
(Electronlibre)
March 4, 2025, 2:00pm
16
Thanks for your nice work, it helps a lot!
In case someone else finds this thread while looking for info on the CrowPanel Advance 7.0-HMI ESP32 AI Display. The v1.3 and v1.4 of this display use different settings from what most people are sharing. Here are the settings that worked for me:
i2c:
sda: 15
scl: 16
scan: true
touchscreen:
- platform: gt911
i2c_id: bus_a
address: 0x5D # Try 0x14 if touch doesn't work
display: my_display
display:
- platform: mipi_rgb
model: RPI
invert_colors: true
dimensions:
width: 800
height: 480
de_pin: 42
hsync_pin: 40
vsync_pin: 41
pclk_pin: 39
pclk_frequency: 20MHz
hsync_front_porch: 8
hsync_back_porch: 8
vsync_front_porch: 8
vsync_pulse_width: 4
vsync_back_porch: 8
data_pins:
red: [7, 17, 18, 3, 46]
green: [9, 10, 11, 12, 13, 14]
blue: [21, 47, 48, 45, 38]
color_order: RGB
update_interval: never
