Hello everybody,
I’m using an ESP32 (WROOM version) with many items attached (4 relais 2 physical interruptors and one NFC reader)
The NFC reader is a pn532 on the i2c bus, previously it was attached to a memos d1 mini, and was working great. I have had to change the Wemod due the pins number for the items I needed to attach, so that’s the reason of the ESP…
This is the current whole configuration:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: "XXXXXXXXXX"
wifi:
ssid: !secret wifi_ssid
manual_ip: # Optional if you want a static IP
static_ip: 1XX.XXX.XXX.XXXX
gateway: 1XX.XXX.XXX.XXX
subnet: 255.255.255.0
dns1: 1XXX.XXX.XXX.XXX
dns2: 8.8.8.8
reboot_timeout: 5min
captive_portal:
########## MQTT ###############
mqtt:
broker: XXX.XXX.XXX.XXX
username: !secret mqtt_username
password: !secret mqtt_password
light:
######## led verde ########
- platform: binary
output: relay_led_verde
######## led rosso ########
- platform: binary
output: relay_led_rosso
output:
- platform: gpio
pin: GPIO14
- platform: gpio
pin: GPIO05
i2c:
######## i2c per NFC ########
sda: GPIO13
scl: GPIO22
scan: false
pn532_i2c:
######## pn532_i2c per NFC ########
update_interval: 1s
on_tag:
then:
- mqtt.publish:
topic: "nfc-garage/reader/SENSOR"
payload: !lambda 'return x;'
switch:
######## rele ########
- platform: gpio
name: "Relè scala seminterrato"
pin: GPIO17
inverted: true
on_turn_on:
- delay: 200ms
- switch.turn_off: relay_illuminazione_scala
- platform: gpio
name: "Relè illuminazione garage"
pin: GPIO16
inverted: true
- platform: gpio
pin: GPIO19
on_turn_on:
- delay: 500ms
- switch.turn_off: apri_cancello
- platform: gpio
pin: GPIO18
on_turn_on:
- delay: 500ms
- switch.turn_off: basculante_garage
binary_sensor:
######## interruttori ########
- platform: gpio
pin:
number: GPIO26
mode: INPUT_PULLUP
inverted: True
name: "Interruttore luce garage"
filters:
- delayed_on: 10ms
on_state:
then:
- switch.toggle: relay_illuminazione_garage
- platform: gpio
pin:
number: GPIO27
mode: INPUT_PULLUP
inverted: True
filters:
- delayed_on_off: 10ms
name: "Interruttore luce scala seminterrato"
on_click:
then:
- switch.toggle: relay_illuminazione_scala
Anyway, on the ESP the ESPHome log returns tons of errors and seems to be unable to read an NFC tag, it returns:
[21:11:40][I][app:102]: ESPHome version 2022.4.0 compiled on Apr 29 2022, 21:10:55
[21:11:40][C][wifi:491]: WiFi:
[21:11:40][C][wifi:353]: Local MAC: XX.XX..XX..XX.XX
[21:11:40][C][wifi:354]: SSID: [redacted]
[21:11:40][C][wifi:355]: IP Address: XXX.XXX.XXX.XXX
[21:11:40][C][wifi:357]: BSSID: [redacted]
[21:11:40][C][wifi:358]: Hostname: 'esp32-nfc-garage'
[21:11:40][C][wifi:360]: Signal strength: -53 dB ▂▄▆█
[21:11:40][C][wifi:364]: Channel: 9
[21:11:40][C][wifi:365]: Subnet: 255.255.255.0
[21:11:40][C][wifi:366]: Gateway: XXX.XXX.XXX.XXX
[21:11:40][C][wifi:367]: DNS1: XXX.XXX.XXX.XXX
[21:11:40][C][wifi:368]: DNS2: 8.8.8.8
[21:11:40][C][logger:233]: Logger:
[21:11:40][C][logger:234]: Level: DEBUG
[21:11:40][C][logger:235]: Log Baud Rate: 115200
[21:11:40][C][logger:236]: Hardware UART: UART0
[21:11:40][C][i2c.arduino:038]: I2C Bus:
[21:11:40][C][i2c.arduino:039]: SDA Pin: GPIO13
[21:11:40][C][i2c.arduino:040]: SCL Pin: GPIO22
[21:11:40][C][i2c.arduino:041]: Frequency: 50000 Hz
[21:11:40][C][i2c.arduino:044]: Recovery: bus successfully recovered
[21:11:40][I][i2c.arduino:054]: Results from i2c bus scan:
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x08
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x0A
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x0D
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x0E
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x10
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x11
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x12
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x13
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x17
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x18
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x19
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x1A
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x1F
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x20
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x21
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x22
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x24
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x25
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x26
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x27
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x2B
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x2E
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x2F
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x30
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x31
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x33
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x35
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x36
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x37
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x38
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x39
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x3A
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x3F
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x43
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x44
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x47
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x4C
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x50
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x52
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x53
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x55
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x57
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x5A
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x5C
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x5D
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x5E
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x60
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x65
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x66
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x69
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x6A
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x6B
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x6C
[21:11:40][I][i2c.arduino:060]: Found i2c device at address 0x6F
[21:11:41][I][i2c.arduino:060]: Found i2c device at address 0x70
[21:11:41][I][i2c.arduino:060]: Found i2c device at address 0x73
[21:11:41][I][i2c.arduino:060]: Found i2c device at address 0x74
[21:11:41][I][i2c.arduino:060]: Found i2c device at address 0x75
[21:11:41][I][i2c.arduino:060]: Found i2c device at address 0x76
[21:11:41][C][gpio.output:010]: GPIO Binary Output:
[21:11:41][C][gpio.output:011]: Pin: GPIO14
[21:11:41][C][gpio.output:011]: Pin: GPIO5
[21:11:41][C][switch.gpio:050]: GPIO Switch 'Relè scala seminterrato'
[21:11:41][C][switch.gpio:050]: Inverted: YES
[21:11:41][C][switch.gpio:051]: Pin: GPIO17
[21:11:41][C][switch.gpio:073]: Restore Mode: Restore (Defaults to OFF)
[21:11:41][C][switch.gpio:050]: GPIO Switch 'Relè illuminazione garage'
[21:11:41][C][switch.gpio:051]: Pin: GPIO16
[21:11:41][C][switch.gpio:050]: GPIO Switch 'Apricancello'
[21:11:41][C][switch.gpio:051]: Pin: GPIO19
[21:11:41][C][switch.gpio:050]: GPIO Switch 'Basculante garage'
[21:11:41][C][switch.gpio:051]: Pin: GPIO18
[21:11:41][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Interruttore luce garage'
[21:11:41][C][gpio.binary_sensor:016]: Pin: GPIO26
[21:11:41][C][gpio.binary_sensor:015]: GPIO Binary Sensor 'Interruttore luce scala seminterrato'
[21:11:41][C][gpio.binary_sensor:016]: Pin: GPIO27
[21:11:41][C][light:104]: Light 'Green led'
[21:11:41][C][light:104]: Light 'Red led'
[21:11:41][C][pn532:347]: PN532:
[21:11:41][C][pn532:359]: Update Interval: 1.0s
[21:11:41][C][pn532_i2c:128]: Address: 0x24
[21:11:41][C][captive_portal:088]: Captive Portal:
[21:11:41][C][mdns:084]: mDNS:
[21:11:41][C][mdns:085]: Hostname: esp32-nfc-garage
[21:11:41][C][ota:085]: Over-The-Air Updates:
[21:11:41][C][ota:086]: Address: 192.168.68.5:3232
[21:11:41][C][ota:089]: Using Password.
[21:11:41][C][api:138]: API Server:
[21:11:41][C][api:139]: Address: 192.168.68.5:6053
[21:11:41][C][api:143]: Using noise encryption: NO
[21:11:41][C][mqtt:065]: MQTT:
[21:11:41][C][mqtt:067]: Server Address: 192.168.68.123:1883 (192.168.68.123)
[21:11:41][C][mqtt:068]: Username: [redacted]
[21:11:41][C][mqtt:069]: Client ID: [redacted]
[21:11:41][C][mqtt:071]: Discovery prefix: 'homeassistant'
[21:11:41][C][mqtt:072]: Discovery retain: YES
[21:11:41][C][mqtt:074]: Topic Prefix: 'esp32-nfc-garage'
[21:11:41][C][mqtt:076]: Log Topic: 'esp32-nfc-garage/debug'
[21:11:41][C][mqtt:079]: Availability: 'esp32-nfc-garage/status'
[21:11:41][C][mqtt.light:077]: MQTT Light 'Green led':
[21:11:41][C][mqtt.light:078]: State Topic: 'esp32-nfc-garage/light/green_led/state'
[21:11:41][C][mqtt.light:078]: Command Topic: 'esp32-nfc-garage/light/green_led/command'
[21:11:41][C][mqtt.light:077]: MQTT Light 'Red led':
[21:11:41][C][mqtt.light:078]: State Topic: 'esp32-nfc-garage/light/red_led/state'
[21:11:41][C][mqtt.light:078]: Command Topic: 'esp32-nfc-garage/light/red_led/command'
[21:11:41][C][mqtt.switch:041]: MQTT Switch 'Relè scala seminterrato':
[21:11:41][C][mqtt.switch:042]: State Topic: 'esp32-nfc-garage/switch/rel_scala_seminterrato/state'
[21:11:41][C][mqtt.switch:042]: Command Topic: 'esp32-nfc-garage/switch/rel_scala_seminterrato/command'
[21:11:41][C][mqtt.switch:041]: MQTT Switch 'Relè illuminazione garage':
[21:11:41][C][mqtt.switch:042]: State Topic: 'esp32-nfc-garage/switch/rel_illuminazione_garage/state'
[21:11:41][C][mqtt.switch:042]: Command Topic: 'esp32-nfc-garage/switch/rel_illuminazione_garage/command'
[21:11:41][C][mqtt.switch:041]: MQTT Switch 'Apricancello':
[21:11:41][C][mqtt.switch:042]: State Topic: 'esp32-nfc-garage/switch/apricancello/state'
[21:11:41][C][mqtt.switch:042]: Command Topic: 'esp32-nfc-garage/switch/apricancello/command'
[21:11:41][C][mqtt.switch:041]: MQTT Switch 'Basculante garage':
[21:11:41][C][mqtt.switch:042]: State Topic: 'esp32-nfc-garage/switch/basculante_garage/state'
[21:11:41][C][mqtt.switch:042]: Command Topic: 'esp32-nfc-garage/switch/basculante_garage/command'
[21:11:42][C][mqtt.binary_sensor:022]: MQTT Binary Sensor 'Interruttore luce garage':
[21:11:42][C][mqtt.binary_sensor:023]: State Topic: 'esp32-nfc-garage/binary_sensor/interruttore_luce_garage/state'
[21:11:42][C][mqtt.binary_sensor:022]: MQTT Binary Sensor 'Interruttore luce scala seminterrato':
[21:11:42][C][mqtt.binary_sensor:023]: State Topic: 'esp32-nfc-garage/binary_sensor/interruttore_luce_scala_seminterrato/state'
Additionally, sometimes when booting up it returns an infinite list of this errors
[20:52:16][W][pn532:090]: Requesting tag read failed!
[20:52:17][W][pn532:090]: Requesting tag read failed!
[20:52:18][W][pn532:090]: Requesting tag read failed!
[20:52:19][W][pn532:090]: Requesting tag read failed!
[20:52:20][W][pn532:090]: Requesting tag read failed!
[20:52:21][W][pn532:090]: Requesting tag read failed!
[20:52:22][W][pn532:090]: Requesting tag read failed!
[20:52:23][W][pn532:090]: Requesting tag read failed!
[20:52:24][W][pn532:090]: Requesting tag read failed!
[20:52:25][W][pn532:090]: Requesting tag read failed!
[20:52:26][W][pn532:090]: Requesting tag read failed!
[20:52:27][W][pn532:090]: Requesting tag read failed!
[20:52:28][W][pn532:090]: Requesting tag read failed!
[20:52:29][W][pn532:090]: Requesting tag read failed!
[20:52:30][W][pn532:090]: Requesting tag read failed!
[20:52:31][W][pn532:090]: Requesting tag read failed!
[20:52:32][W][pn532:090]: Requesting tag read failed!
[20:52:33][W][pn532:090]: Requesting tag read failed!
[20:52:34][W][pn532:090]: Requesting tag read failed!
[20:52:35][W][pn532:090]: Requesting tag read failed!
[20:52:36][W][pn532:090]: Requesting tag read failed!
[20:52:37][W][pn532:090]: Requesting tag read failed!
[20:52:38][W][pn532:090]: Requesting tag read failed!
[20:52:39][W][pn532:090]: Requesting tag read failed!
[20:52:40][W][pn532:090]: Requesting tag read failed!
[20:52:42][W][pn532:090]: Requesting tag read failed!
[20:52:43][W][pn532:090]: Requesting tag read failed!
[20:52:44][W][pn532:090]: Requesting tag read failed!
[20:52:45][W][pn532:090]: Requesting tag read failed!
[20:52:46][W][pn532:090]: Requesting tag read failed!
[20:52:47][W][pn532:090]: Requesting tag read failed!
[20:52:48][W][pn532:090]: Requesting tag read failed!
[20:52:49][W][pn532:090]: Requesting tag read failed!
[20:52:50][W][pn532:090]: Requesting tag read failed!
[20:52:51][W][pn532:090]: Requesting tag read failed!
[20:52:52][W][pn532:090]: Requesting tag read failed!
[20:52:53][W][pn532:090]: Requesting tag read failed!
[20:52:54][W][pn532:090]: Requesting tag read failed!
[20:52:55][W][pn532:090]: Requesting tag read failed!
What could be the reason of the inability to scan?
Thanks!
