ESPHome and MAX7219
I am trying to get the MAX7219 to do what I want, but without succes.
I want to display a text when the doorbell is ringing and I am home. The part that is not working:
binary_sensor:
  - platform: homeassistant
    entity_id: input_boolean.coming
    internal: true
display:
  - platform: max7219digit
    cs_pin: GPIO15
    num_chips: 8
    intensity: 5
    lambda: |-
      if (id(coming).state) {
        it.turn_on_off(true);
        it.print(2,0, id(pixelmix8), "I am Coming!");
      } else{
        it.turn_on_off(false);
When I only use the it.print and not the if-else then the text is displayed. But with the if-else statements it is not responding to any changes in the input_boolean.coming from home assistant. The display stays blank. What am I doing wrong?
Maybe I should be lambda like this:
lambda: ! lambda | -
Did you add the device as an integration in HA? And can you post your complete yaml and the log from the device?
You can also add the following line to the lambda above the if statement, to see the value of the binary sensor you are testing in the if.
    lambda: |-
      ESP_LOGD("display", "Value coming: %d", id(coming).state);
How stupid of me! I didn’t add the device as an Integration. Now it is working!
And also thanks for the tip to add a line so you can see in the logs what happens.
Many thanks Jos!
Hello Gert,
Your funtion for your doorbel should help me to use a max7219 dotmatrix.
So I copied your xxx.yaml file into my esphome xx.yaml file and uploaded it.
error could not find pixelmix8???
It is a great help if you can explain howe you arranged your pixelmix8 file font?
Like to hear.
Theo
ps. the example max7219 7 segment seems like to work. Some leds are light up at least the combination esp wemos d1 print and matrix are working and integrated in HA
Hallo Gert,
INFO Reading configuration /config/esphome/max.yaml…
Failed config
font: [source /config/esphome/max.yaml:39]
  • [source /config/esphome/max.yaml:40]
    Could not find file ‘/local/pixelmix8.ttf’. Please make sure it exists (full path: /local/pixelmix8.ttf).
    file: /local/pixelmix8.ttf [source /config/esphome/max.yaml:40]
This is the log.
Hallo Gert,
‘utf-8’ codec can’t decode byte 0x80 in position 7: invalid start byte
This error if I,am arranging the pixelmix.ttf file in the folder.
btw this happends always no matther what I try?
Where am I going wrong?
Here is the complete file:
# LED MAX7219 display via ESP32 "Kom er aan!"
# This configuration is for the ESP-WROOM-32D board.
# with ESP32_DEVKITC_V4 on the back
esphome:
esp32:
  board: nodemcu-32s #esp32doit-devkit-v1
wifi:
  ssid: "<name>"
  password: "<password>"
  ap:
    ssid: "Matrix-Led Fallback Hotspot"
captive_portal:
logger:
ota:
# Enable Home Assistant API
api:
  encryption:
    key: "<key>"
spi:
  clk_pin: GPIO18
  mosi_pin: GPIO23
font:
  - file: "pixelmix.ttf"
  - file: "Helvetica.ttf"
binary_sensor:
    internal: true
display:
    cs_pin: GPIO0
    num_chips: 8
    intensity: 5
    lambda: |-
      if (id(iamcoming).state) {
        it.print(2, 0, id(pixelmix8), "Kom er aan!");
      } else{
The pixelmix.ttf and other ttf files are in the directory /config/esphome/.
