Hi all,
I moved a few months ago and I’m just starting to redo my Home Assistant setup.
My setup has been the same for a while so I seemed to have either forgotten stuff or it has changed.
I’ve set this up repeatedly and I’m not getting the desired result.
A Wemos D1 mini clone and a bme280. I’ve set this up the legacy way, as it wouldn’t work with my ssid and secrets for some reason and I constantly got an error.
The next issue is, the following script works in a sence, in that I can subscribe through the test panel and see the results but when I add the esp to the MQTT integration, it is found but the results are blank.
Any idea’s. This seems rather odd.
MQTT was working before but maybe it has changed since I last added a node, which was a while ago.
I just have the integration set up and nothing in my yaml. But will double check when home. I don’t currently have remote access, due to not having enough on there currently
Using the MQTT integration config, I can subscribe to the topic and see the result that way. So it it processing the script, so to speak.
Thinking about it, my Shelly MQTT integrations broke just before I moved house a few months ago. I’ll go through my config file again and see if I’m missing something, as in not removed.
Not sure what happened but when I plugged the esp back in, Home Assistant found it. Didn’t change anything from when we last messaged on here.
On another note, normally I like to monitor RSSI andhave a reset switch to an esp device but with WIFI. This doesn’t seem to work with this MQTT module. Is this due to it being MQTT? Or should this work too?
