Hi all - I’m a bit lost. Normally I know my way around ESPHome and all the different peripherals like sensor, relays, … , but not today.
I’m now trying to create a wakeup light with some components I had lying around:
- Wemos Lolin D32 Pro microcontroller (see pinout below)
- A 12V RGB led strip
- an RGB LED Strip Driver Module based on the P9813 led driver
I’m using the following ESPHome configuration:
light:
- platform: neopixelbus
type: RGB
variant: P9813
data_pin: GPIO12
clock_pin: GPIO13
num_leds: 132
I’ve wired the Lolin D32 Pro as follows:
- GND D32 Pro => GND Led Driver
- 3.3V => Vcc Led Driver
- Pin 12 => Din
- Pin 13 => Cin
I triple checked my wiring and yet I cannot control anything from HA (logs from the device in ESPHome shows that it’s well connected to HA). Does anybody have an idea of what I did wrong?
