ESPHome and simple LED
Hello everyone!
I would like to integrate a simple monochromatic LED (like this: https://www.amazon.com/eBoot-Pieces-Emitting-Diodes-Assorted/dp/B06XPV4CSH – of course attached with a 200 ohm resistor) in my ESPHome to show the status (via MQTT?) of the alarm in homeassistant (actually is just the status of an automation!)… any idea of what can I do?
Any suggestions?
seems simple enough… You dont need MQTT because esphome already has a native integration with HA. Using a esp8266 and something like this as the code (see the docs how to use the wizard, then add the led specific configuration):
output:
- platform: esp8266_pwm
  pin: GPIO13
light:
- platform: monochromatic
  output: my_led
It works!!
Thanks a lot
Hi
How you do it?
I have esp8266 and simple led on the bord pin D7.
What the code you used in Arduino burn device?
is there a way to do this on esp32?
I think so. But instead of using the esp8266_pwm platform you should use ledc platform. Check this:
This worked for me
output:
  - platform: ledc
    pin: GPIO32
light:
    output: gpio_32
