ESPhome api to ESPhome mqtt conversion
Hi Guys,
I am absolutely new to HA and everything related. I just flashed my sonoff with a ESPhome bin and got some basic functionality. but i just realized api is not something good at retaining state and now need to convert my yaml for mqtt.
I know tasmota would be a better option but I am kind of hesitant bcoz ill need a custom bin. Not very sure on compiling that.
I am even open to getting on a zoom session to get this done if required.
i also have a few questions about using the automation on HA and somethings related to mdi:icons
Rishab
all you need to change is to remove api: and put in a section mqtt: (with your broker details) in the yaml file for that device. However what do you mean regarding retain state? what are you trying to retain?
esphome:
  platform: ESP8266
  board: esp8285
  includes:
    - ifan02.h
  on_boot:
    priority: 225
    # turn off the light as early as possible
    then:
      - light.turn_off: ifan02_light
wifi:
  ssid:
  password:
  manual_ip:
    static_ip:
    gateway:
    subnet:
    dns1:
    dns2: 1.1.1.1
api:
#mqtt:
#  broker:
logger:
ota:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO0
      inverted: True
    on_press:
      then:
        - light.toggle: ifan02_light
  - platform: gpio
    pin:
      number: GPIO9
      inverted: True
    on_press:
      then:
        - switch.toggle: fan_relay1
        - switch.turn_on: update_fan_speed
  - platform: gpio
    pin:
      number: GPIO10
      inverted: True
    on_press:
      then:
        - switch.toggle: fan_relay2
  - platform: gpio
    pin:
      number: GPIO14
      inverted: True
    on_press:
      then:
        - switch.toggle: fan_relay3
  - platform: gpio
    pin:
      number: GPIO1
      inverted: True
    on_press:
      then:
  - platform: gpio
    pin:
      number: GPIO3
      inverted: true
    on_multi_click:
      - timing:
        - ON for 0.5s to 2s
        then:
          - fan.turn_off: ifan02_fan
      - timing:
        - ON for 050ms to 350ms
        then:
          - fan.turn_on:
              speed: LOW
      - timing:
        - OFF for 050ms to 200ms
        then:
          - fan.turn_on:
              speed: MEDIUM
      - timing:
        then:
          - fan.turn_on:
              speed: HIGH
output:
  - platform: custom
    type: float
    outputs:
    lambda: |-
      auto ifan02_fan = new IFan02Output();
      App.register_component(ifan02_fan);
      return {ifan02_fan};
  - platform: gpio
    pin: GPIO12
light:
  - platform: binary
    output: light_output
switch:
    optimistic: True
    turn_on_action:
      then:
        - delay: 200ms
        - if:
            condition:
              and:
                - switch.is_off: fan_relay1
                - switch.is_off: fan_relay2
                - switch.is_off: fan_relay3
            then:
        - if:
            condition:
              and:
                - switch.is_on: fan_relay1
            then:
              - fan.turn_on:
                  speed: LOW
        - if:
            condition:
              and:
                - switch.is_on: fan_relay2
            then:
              - fan.turn_on:
                  speed: MEDIUM
        - if:
            condition:
              and:
                - switch.is_on: fan_relay3
            then:
              - fan.turn_on:
                  speed: HIGH
        - switch.turn_off: update_fan_speed
  - platform: gpio
    pin: GPIO5
  - platform: gpio
    pin: GPIO4
  - platform: gpio
    pin: GPIO15
fan:
  - platform: speed
    output: fanoutput
This is my yaml, I am using a Sonoff iFan02 and have added touch buttons on Rx and Tx pin to be used for light and fan control. I need the speed and the state of light and fan retained after a power failure.
i tried commenting the api and adding the mqtt server details (I have a Pi4 where i run Hassio with mqtt) but the device never got detected.
PS the initial yaml is from @quazzie
How often are you expecting power failures? There are actually settings in ESPhome for restore_mode
Also, the fan component should restore after reboot
Do you have mqtt discovery turned on in HA?
We see a lot of power failures. That will also reboot the Pi. I am not sure if that will then allow a power state restore.
Any clue on how mqtt discovery has to be enabled?
So does it mean, if i comment the api and add the mqtt details the yaml works as is?
It’s an option in your mqtt integration settings:
It should do
Yes its enabled.
Let me experiment with the restore state and get back.
thanks :slight_smile:
Hey so this is wat i see on the logs
I rebooted the HA and my MQTT discovery is on, I still cant find the device. :frowning:
Not sure if i am missing a step maybe…
Rishab
In my point view you should try to eliminate these pi power failure by adding an UPS to your pi. It could help avoiding a lot of future issues.
I could do that. Thanks :slight_smile:
@sparkydave any clue on the device discovery?
Rishab
Sorry, no. I don’t use MQTT much, only for an alarm interface. All of my ESPhome devices use the API. Is there not a way to manually add the device by MQTT? Perhaps try asking on the ESPhome Discord channel
So reinstalling hassio and then enabling the mqtt add on worked :slight_smile:
