I am getting the following error in the logs when ESPHome tries to connect to wifi. The problem started appearing after I switched the network my ESP32-dev is connected to. When the device tries to connect for the first time it throws the ‘Association refused temporarily’ error. It then waits for around 26 seconds before trying to connect to wifi again. The problem seems to be the wifi adapter on the ESP. Since I use the device with deep sleep to save power, I cannot afford to have to wait for 26 seconds just to connect to wifi.
Here is a piece of the log that shows the error:
[I][logger:258]: Log initialized
[C][ota:469]: There have been 0 suspected unsuccessful boot attempts.
[D][esp32.preferences:113]: Saving 1 preferences to flash...
[D][esp32.preferences:142]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[I][app:029]: Running through setup()...
[I][i2c.arduino:175]: Performing I2C bus recovery
[C][dht:011]: Setting up DHT...
[C][bmp280.sensor:060]: Setting up BMP280...
[C][wifi:037]: Setting up WiFi...
[C][wifi:038]: Local MAC: C8:F0:9E:F1:C8:84
[I][wifi:257]: WiFi Connecting to 'T-2_E799B9'...
[D][esp-idf:000]: E (6963) wifi:
[D][esp-idf:000]: Association refused temporarily, comeback time 268435 mSec
[D][esp-idf:000]:
[W][wifi:543]: Timeout while connecting to WiFi.
[W][wifi_esp32:494]: Event: Disconnected ssid='T-2_E799B9' bssid=[redacted] reason='Association Failed'
[W][wifi:549]: Error while connecting to network.
[W][wifi:585]: Restarting WiFi adapter...
[I][wifi:518]: WiFi Connected!
And this is the config I use. I removed some unnecessary code I use otherwise, to make it more clear, but the error is present no matter the code.
substitutions:
devicename: esp32-inside
max_run_duration: 60s
sleep_duration: 60s
esp32:
board: esp32dev
framework:
type: arduino
esphome:
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
ota:
wifi:
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.64.51
gateway: 192.168.64.1
subnet: 255.255.255.0
ap:
ssid: "Esphome-Web-F1C884"
password: "SioVN9kp2gvp"
captive_portal:
i2c:
sda: 21
scl: 22
scan: true
deep_sleep:
run_duration: $max_run_duration
sleep_duration: $sleep_duration
# DHT11 - temperature, humidity
- platform: dht
model: DHT11
pin: 15
update_interval: never
temperature:
name: "Inside temperature DHT"
humidity:
name: "Inside humidity DHT"
# BMP280 - temperature, pressure
- platform: bmp280
address: 0x76
temperature:
name: "Inside temperature BMP"
oversampling: 16x
filters:
- offset: -1.5
pressure:
name: "Inside pressure BMP"
Also what I find interesting is that once wifi is connected I am getting the following output in the logs:
[D][api:102]: Accepted ::FFFF:192.168.64.50
[W][api.connection:081]: Home Assistant 2023.2.5 (::FFFF:192.168.64.50): Connection reset
[D][api.connection:918]: Home Assistant 2023.2.5 (::FFFF:192.168.64.50): Connected successfully
Looks like HomeAssistant connects and then disconnects and that process keeps repeating. Is this something that is considered problematic?
Did anyone have a similar problem in the past?
Thank you!
