geidorei
(geidorei)
February 16, 2024, 3:57pm
1
I have 2 of these plugs and an update is available, but when I click update it fails. Log as below. Any help appreciated. FYI I have completely reset them
Config file:
substitutions:
…name: work-laptop-athom-smart-plug-v2-f143e6
packages:
…athom.smart-plug-v2: github://athom-tech/athom-configs/athom-smart-plug-v2.yaml
esphome:
…name_add_mac_suffix: false
wifi:
…ssid: !secret wifi_ssid
…password: !secret wifi_password
Output after trying to update:
NFO Reading configuration /config/esphome/athom-smart-plug-v2-f143e6.yaml…
INFO Detected timezone ‘Europe/London’
Failed config
esphome: None
…[friendly_name] is an invalid option for [esphome]. Please check the indentation.
…friendly_name: Smart Plug V2 None
…name_add_mac_suffix: False
…project:
…name: Athom Technology.Smart Plug V2
…version: 2.0
…build_path: .esphome/build/work-laptop-athom-smart-plug-v2-f143e6
button.factory_reset: [source /config/esphome/.esphome/packages/43f53298/athom-smart-plug-v2.yaml:140]
…Platform not found: ‘button.factory_reset’.
…platform: factory_reset
…name: Restart with Factory Default Settings
…id: Reset
geidorei
(geidorei)
February 18, 2024, 12:12pm
2
FYI - I have updated config to that on github, but I now get the following errors. Note indentation is correct.
INFO Reading configuration /config/esphome/athom-smart-plug-v2-f143e6.yaml…
Failed config
esphome: None
…name: athom-smart-plug-v2
…name_add_mac_suffix: True
…project:
…version: 2.0
…build_path: .esphome/build/athom-smart-plug-v2
button.factory_reset: [source /config/esphome/athom-smart-plug-v2-f143e6.yaml:140]
…id: Reset
geidorei
(geidorei)
February 18, 2024, 1:05pm
3
Update: I have moded the config to the following as below, and the update installed. However, If I click Adopt if fails to adopt the device.
substitutions:
room: “”
device_description: “athom smart plug v2”
project_name: “Athom Technology.Smart Plug V2”
project_version: “2.0”
relay_restore_mode: RESTORE_DEFAULT_OFF
esphome:
name_add_mac_suffix: true
project:
version: “${project_version}”
esp8266:
board: esp8285
restore_from_flash: true
preferences:
flash_write_interval: 1min
api:
ota:
logger:
baud_rate: 0
mdns:
disabled: false
web_server:
port: 80
wifi:
ap: {} # This spawns an AP with the device name and mac address with no password.
captive_portal:
dashboard_import:
package_import_url: github://athom-tech/athom-configs/athom-smart-plug-v2.yaml
uart:
rx_pin: RX
baud_rate: 4800
globals:
type: float
restore_value: yes
initial_value: ‘0.0’
platform: uptime
platform: wifi_signal
update_interval: 60s
platform: cse7766
update_interval: 10s
current:
filters:
- lambda: if (x < 0.060) return 0.0; else return x; #For the chip will report less than 3w power when no load is connected
voltage:
power:
filters:
- lambda: if (x < 3.0) return 0.0; else return x; #For the chip will report less than 3w power when no load is connected
energy:
unit_of_measurement: kWh
filters:
# Multiplication factor from W to kW is 0.001
- multiply: 0.001
on_value:
then:
- lambda: |-
static float previous_energy_value = 0.0;
float current_energy_value = id(energy).state;
id(total_energy) += current_energy_value - previous_energy_value;
previous_energy_value = current_energy_value;
platform: template
device_class: “energy”
state_class: “total_increasing”
icon: “mdi:lightning-bolt”
accuracy_decimals: 3
lambda: |-
return id(total_energy);
platform: total_daily_energy
name: “Total Daily Energy”
restore: true
power_id: power_sensor
filters:
switch:
light:
platform: status_led
disabled_by_default: true
pin:
inverted: true
number: GPIO13
text_sensor:
platform: wifi_info
ip_address:
ssid:
mac_address:
time:
platform: sntp
geidorei
(geidorei)
February 21, 2024, 10:35am
4
Update: after doing a clean build, then an install it has worked. JIC anyone else has gad this issue as it fixed mine.
However, wont be using these anymore. so much faffing - will stay with Tasmota plugs if I need anymore energy monitoring plugs.
