I finally figured it out. I had been trying to find an ESPhome project to copy for a while the would allow me to create my own automated shades. I wanted to use the cheap spring-loaded cut-to-fit shades you can buy for about $10 a piece. Without a complete step-by-step tutorial online, I figured why not piece together parts of other projects. So i did.
I took the basic physical design from this Instrctables post: https://www.instructables.com/DIY-Motorized-WiFi-Roller-Blind-ESP8266-Blynk/ . The ESPhome code I used and modified was from:
DIY Motorised Smart Blinds .
Each of these projects used a D1 mini to control one window covering. Blinds in the case of everythingsmarthome and shades in the instructables post but I wanted to controlled two windows, two shades with one D1. So I did, and I gave them manual controls. I also made it battery powered and give it a LUX sensor to detect the level of light outside. The batteries are 18650s and I’m charging them with a solar panel suction-cupped to the window.
Don’t get me wrong it has its issues. The batteries only last three days, so I ordered a 30 watt solar panel to take the place of my 1.5 watt panel. Hopefully that will help when it eventually gets here.
I’m using almost every pin of this D1. If anyone wants my ESPhome code or more information let me know. I’m even toying with the idea of creating my own custom PCB for the project.
Edit ESPhome code below:
esphome:
esp8266:
board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key:
ota:
password:
wifi:
ssid: !secret wifi_ssid
ap:
ssid:
password:
captive_portal:
cover:
name: "My Blind 0"
device_class: blind
open_action:
- stepper.set_target:
target: 60000
- sensor.template.publish:
state: !lambda return id(my_stepper0).target_position;
close_action:
target: 0
stop_action:
target: !lambda return id(my_stepper0).current_position;
state: !lambda return id(my_stepper0).current_position;
optimistic: true
assumed_state: true
name: "My Blind 1"
device_class: blind
open_action:
target: -60000
state: !lambda return id(my_stepper1).target_position;
close_action:
target: 0
stop_action:
target: !lambda return id(my_stepper1).current_position;
state: !lambda return id(my_stepper1).current_position;
optimistic: true
assumed_state: true
name: "My Blind 0 Position"
name: "My Blind 1 Position"
- platform: adc
pin: VCC
internal: true
unit_of_measurement: '%'
update_interval: 60s
lambda: |-
return ((id(VCC).state /3.30) * 100.00);
- platform: adc
pin: A0
unit_of_measurement: lux
filters:
- lambda: |-
return (x / 10000.0) * 2000000.0;
binary_sensor:
- platform: gpio
pin: TX
on_press:
then:
on_release:
then:
target: 60000
target: -60000
on_double_click:
min_length: 50ms
max_length: 350ms
then:
target: 60000
target: -60000
- platform: gpio
pin: RX
on_press:
then:
on_release:
then:
target: 0
target: 0
on_double_click:
min_length: 50ms
max_length: 350ms
then:
target: 0
target: 0
stepper:
- platform: uln2003
pin_a: D1
pin_b: D2
pin_c: D3
pin_d: D4
max_speed: 725 steps/s
sleep_when_done: True
acceleration: inf
deceleration: inf
- platform: uln2003
pin_a: D5
pin_b: D6
pin_c: D7
pin_d: TX
acceleration: inf
deceleration: inf
