ESPHome: automatic retry for OTA-updates
Hello everyone,
I would wish for a ESPHome OTA retry-function. A counter could be used, which I would set e.g. to “50”, which automatically clicks “retry” for me, if an OTA update fails. By standard, it is set to “1”.
Of course, one solution could be minimizing the ESP32-program, but I would like to have all the currently implemented functionality.
Problem in my scenario: I have some quite packed ESP32 running wih a lot of peripherals. This causes the OTA-update to fail most of the time. After retrying ~15 times the OTA update succeeds. I added a collection of the various error messages I receive in the code section below.
I already implemented Safe Mode Button — ESPHome , but It did not help for having a successful OTA update on the first try (it also takes > 10 trys, until an OTA update succeeds).
The Wifi-connection seems to be good (Fritzbox 6490 Cable 2 m away from ESP32).
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.1.3
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- Wire @ 2.0.0
|-- ArduinoJson @ 6.18.5
|-- Improv @ 1.2.3
|-- FastLED @ 3.3.2
RAM:   [==        ]  16.5% (used 53944 bytes from 327680 bytes)
Flash: [========= ]  92.5% (used 1697605 bytes from 1835008 bytes)
========================= [SUCCESS] Took 10.38 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.122.162
INFO Uploading /data/build/esphome-web-45e2b0/.pioenvs/esphome-web-45e2b0/firmware.bin (1703376 bytes)
Uploading: [                                                            ] 0% ERROR Error receiving acknowledge chunk OK: [Errno 104] Connection reset by peer
or
WARNING esphome-web-45e2b0 @ 192.168.122.162: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for esphome-web-45e2b0 @ 192.168.122.162
WARNING Disconnected from API
or
or
Uploading: [=                                                           ] 1% ERROR Error receiving acknowledge chunk OK: [Errno 104] Connection reset by peer
or
ERROR Error receiving acknowledge version: timed out
or
Uploading: [=========                                                   ] 14% ERROR Error receiving acknowledge chunk OK: timed out
or
ERROR Error binary size: Unknown error from ESP
Just for information, this is the ESPHome-yaml file for the ESP32:
esp32:
  board: wemos_d1_mini32
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
  safe_mode: true
#  password: !secret CO2_pass
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
  # Set up a wifi access point
  ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
  package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
  import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
  authorizer: none
# To have a "next url" for improv serial
web_server:
font:
  - file: "fonts/arial.ttf"
globals:
  - id: TM1637_display_status
    type: bool
    restore_value: no
    initial_value: 'true'
# Example configuration entry
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: true
  frequency: 800kHz
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
#    icon: "mdi:clock-digital"
    reset_pin: D0
    address: 0x3C
    lambda: |-
      it.print(0, 0, id(font_arial), "TEMP:");
      it.printf(128,0, id(font_arial), TextAlign::TOP_RIGHT, "%.2f°C", id(temperature).state);
      it.print(0,16, id(font_arial), "FEUCHTE:");
      it.printf(128,16, id(font_arial), TextAlign::TOP_RIGHT, "%.2f%%", id(humidity).state);
      it.print(0,32, id(font_arial), "DRUCK:");
      it.printf(128,32, id(font_arial), TextAlign::TOP_RIGHT, "%.2fhpa", id(pressure).state);
      it.print(0,48, id(font_arial), "LICHT:");
      it.printf(128,48, id(font_arial), TextAlign::TOP_RIGHT, "%.2flux", id(lux).state);
      it.print(0,48, id(font_arial), "CO2:");
      it.printf(128,48, id(font_arial), TextAlign::TOP_RIGHT, "%.0f ppm", id(sensor_co2).state);
#      if (!id(SSD1306_oled_bc).current_values.get_brightness()) {
    update_interval: 1s
  - platform: tm1637
    clk_pin: GPIO19
    dio_pin: GPIO18
    inverted: false
    update_interval: 1s
    length: 4
    lambda: |-
      if (id(TM1637_display_status) == true) {
        it.printf("%4.0f", id(sensor_co2).state);
        it.set_intensity(7);
      } else {
          printf("    ");
#      it.printf( 0, 0, id(font_arial), "%.0f ppm", id(sensor_co2).state);
#      it.print(0, 0, id(font_arial), "Hello World!");
uart:
  rx_pin: GPIO16
  tx_pin: GPIO17
  baud_rate: 9600
button:
  - platform: safe_mode
    name: "CO2 01 (Safe Mode) for OTA"
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO23
      mode:
          input: true
          pullup: true
    name: "LED button left"
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
  - platform: gpio
    pin:
      number: GPIO5
      mode:
          input: true
          pullup: true
    name: "LED button right"
    filters:
      - delayed_on: 10ms
      - delayed_off: 10ms
  - platform: gpio
    pin: GPIO35
    device_class: motion
  - platform: senseair
    co2:
      name: "SenseAir CO2 Value"
    update_interval: 60s
  - platform: bh1750
    name: "BH1750 Illuminance"
    address: 0x23
  - platform: bme680
    temperature:
      name: "BME680 Temperature"
      oversampling: 16x
      filters:
        offset: -4
    pressure:
      name: "BME680 Pressure"
    humidity:
      name: "BME680 Humidity"
    gas_resistance:
      name: "BME680 Gas Resistance"
    address: 0x77
    name: "BME680 Indoor Air Quality"
    unit_of_measurement: 'AQI'
    icon: "mdi:gauge"
    # caulculation: comp_gas = log(R_gas[ohm]) + 0.04 log(Ohm)/%rh * hum[%rh]
    lambda: |-
      return log(id(gas_resistance).state) + 0.04 *  id(humidity).state;
  - platform: adc
    pin: 32
    name: "Mic Voltage out MAX9814"
    attenuation: auto
  - platform: ct_clamp
    sensor: adc_mic_reading
    name: "Mic Sound level out MAX9814"
    sample_duration: 500ms
    update_interval: 1000ms
output:
    type: float
    write_action:
      then:
      - lambda: id(SSD1306_display).set_contrast(state);
    type: float
    write_action:
      then:
      - lambda: id(TM1637_display).set_intensity(state);
  - id: LED_button_left_output
    platform: gpio
    pin: GPIO4
  - id: LED_button_right_output
    platform: gpio
    pin: GPIO2
  - id: USB_output
    platform: gpio
    pin: GPIO27
switch:
  - platform: output
    output: USB_output
light:
  - platform: monochromatic
    name: "Display SSD1306 "
    output: SSD1306_oled_bc
    on_turn_on:
      then:
      - lambda: id(SSD1306_display).turn_on();
    on_turn_off:
      then:
      - lambda: id(SSD1306_display).turn_off();
    name: "Display TM1637 "
    output: TM1637_bc
    on_turn_on:
      then:
      - lambda: id(TM1637_display_status) = 1; #id(TM1637_display).set_intensity(7);
    on_turn_off:
      then:
      - lambda: id(TM1637_display_status) = 0; #id(TM1637_display).set_intensity(0);
  - platform: partition
    name: "Indicator bottom right"
    default_transition_length: 0s
    icon: "mdi:arrow-bottom-right-bold-outline"
    segments:
      - id: led_Taster_5mm_LED_Lights
        to: 0
    name: "Indicator bottom middle"
    icon: "mdi:arrow-down-bold-outline"
    segments:
        to: 1
    name: "Indicator bottom left"
    icon: "mdi:arrow-bottom-left-bold-outline"
    segments:
        to: 2
    name: "Indicator top left"
    icon: "mdi:arrow-top-left-bold-outline"
    segments:
        to: 3
    name: "Indicator top middle"
    icon: "mdi:arrow-up-bold-outline"
    segments:
        to: 4
    name: "Indicator top right"
    icon: "mdi:arrow-top-right-bold-outline"
    segments:
        to: 5
  - platform: fastled_clockless
    chipset: WS2812B
    pin: GPIO33
    num_leds: 6
    rgb_order: RGB
    color_correct: [50%, 50%, 50%]
    restore_mode: ALWAYS_ON
  - platform: binary
    output: LED_button_left_output
  - platform: binary
    output: LED_button_right_output
ESPHome feature requests should be made here: Issues · esphome/feature-requests · GitHub
