Hi All,
I’m trying to compile the below code but it fails at the conditions:
for the intervals:
(lines 223 and 224). Any ideas how to fix it would be great. Thanks.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: 'xxx'
password: 'xxx'
manual_ip:
static_ip: 192.168.0.61
gateway: 192.168.0.1
subnet: 255.255.255.0
mqtt:
broker: '192.168.0.13'
username: 'xxx'
password: 'xxx'
discovery: False
api:
# Enable logging
logger:
ota:
password: 'xxx'
time:
- platform: homeassistant
- platform: mqtt_subscribe
name: "Program 1 Start Time 1"
topic: retic/program1/start1
name: "Program 1 Start Time 2"
topic: retic/program1/start2
name: "Program 2 Start Time 1"
topic: retic/program2/start1
name: "Program 2 Start Time 2"
topic: retic/program2/start2
name: "Program 3 Start Time 1"
topic: retic/program3/start1
name: "Program 3 Start Time 2"
topic: retic/program3/start2
name: "Program 1 Station 1 Run Time"
topic: retic/program1/station1runtime
name: "Program 1 Station 2 Run Time"
topic: retic/program1/station2runtime
name: "Program 1 Station 3 Run Time"
topic: retic/program1/station3runtime
name: "Program 1 Station 4 Run Time"
topic: retic/program1/station4runtime
name: "Program 2 Station 1 Run Time"
topic: retic/program2/station1runtime
name: "Program 2 Station 2 Run Time"
topic: retic/program2/station2runtime
name: "Program 2 Station 3 Run Time"
topic: retic/program2/station3runtime
name: "Program 2 Station 4 Run Time"
topic: retic/program2/station4runtime
name: "Program 3 Station 1 Run Time"
topic: retic/program3/station1runtime
name: "Program 3 Station 2 Run Time"
topic: retic/program3/station2runtime
name: "Program 3 Station 3 Run Time"
topic: retic/program3/station3runtime
name: "Program 3 Station 4 Run Time"
topic: retic/program3/station4runtime
name: "Program 1 Watering Day"
topic: retic/program1/wateringday
name: "Program 2 Watering Day"
topic: retic/program2/wateringday
name: "Program 3 Watering Day"
topic: retic/program3/wateringday
binary_sensor:
- platform: gpio
name: "Retic Bore Run"
pin:
number: D5
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- platform: gpio
name: "Retic Bore Stop"
pin:
number: D6
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
switch:
- platform: gpio
name: "Retic Station 1 Valve"
icon: mdi:water-pump
pin:
number: D1
inverted: true
- platform: gpio
name: "Retic Station 2 Valve"
pin:
number: D2
inverted: true
- platform: gpio
name: "Retic Station 3 Valve"
pin:
number: D3
inverted: true
- platform: gpio
name: "Retic Station 4 Valve"
pin:
number: D4
inverted: true
- platform: gpio
name: "Retic Bore Pump Run"
pin:
number: D8
inverted: true
interval:
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program1wateringday).state == True;'
or:
- lambda: 'return id(program1start1).state == homeassistant_time;'
- lambda: 'return id(program1start2).state == homeassistant_time;'
then:
- script.execute: retic_program1_run
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program2wateringday).state == True;'
or:
- lambda: 'return id(program2start1).state == homeassistant_time;'
- lambda: 'return id(program2start2).state == homeassistant_time;'
then:
- script.execute: retic_program2_run
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program3wateringday).state == True;'
or:
- lambda: 'return id(program3start1).state == homeassistant_time;'
- lambda: 'return id(program3start2).state == homeassistant_time;'
then:
- script.execute: retic_program3_run
script:
- id: retic_program1_run
then:
- switch.turn_on: v1
- switch.turn_on: v8
- delay: !lambda 'return id(program1station1runtime).state * 1000'
- switch.turn_on: v2
- delay: 0.5s
- switch.turn_off: v1
- delay: !lambda 'return id(program1station2runtime).state * 1000'
- switch.turn_on: v3
- delay: 0.5s
- switch.turn_off: v2
- delay: !lambda 'return id(program1station3runtime).state * 1000'
- switch.turn_on: v4
- delay: 0.5s
- switch.turn_off: v3
- delay: !lambda 'return id(program1station4runtime).state * 1000'
- switch.turn_off: v8
- switch.turn_off: v4
- id: retic_program2_run
then:
- delay: !lambda 'return id(program2station1runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program2station2runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program2station3runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program2station4runtime).state * 1000'
- id: retic_program3_run
then:
- delay: !lambda 'return id(program3station1runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program3station2runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program3station3runtime).state * 1000'
- delay: 0.5s
- delay: !lambda 'return id(program3station4runtime).state *1000'
bumping this in case someone can help, plus with the help of someone on Discord I have fixed a few issues, but it still wont compile.
new code:
### RETIC CONTROLLER CODE FOR ESP8266 ###
# Pin assignments
# D0 Try not to use
# D1 In / Out
# D2 In / Out
# D3 Out
# D4 Out
# D5 In / Out
# D6 In / Out
# D7 In / Out
# D8 In / Out
# D9 In / Out ?? (tied to USB, cant use with debug)
# D10 In /Out ?? (tied to USB, cant use with debug)
# SD3 In / Out
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: 'xxxx'
password: 'xxxx'
manual_ip:
mqtt:
username: 'xxxx'
password: 'xxxx'
discovery: False
api:
# Enable logging
logger:
ota:
password: 'xxxx'
time:
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
switch:
- platform: gpio
pin:
number: D1
inverted: true
- platform: gpio
pin:
number: D2
inverted: true
- platform: gpio
pin:
number: D3
inverted: true
- platform: gpio
pin:
number: D4
inverted: true
- platform: gpio
pin:
number: D8
inverted: true
interval:
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program1wateringday).state == true;'
then:
- if:
condition:
or:
then:
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program2wateringday).state == true;'
then:
- if:
condition:
or:
then:
- interval: 1min
then:
- if:
condition:
- lambda: 'return id(program3wateringday).state == true;'
then:
- if:
condition:
or:
then:
script:
then:
- switch.turn_on: p1
- delay: !lambda 'return id(program1station1runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program1station2runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program1station3runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program1station4runtime).state * 1000;'
- switch.turn_off: p1
then:
- delay: !lambda 'return id(program2station1runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program2station2runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program2station3runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program2station4runtime).state * 1000;'
then:
- delay: !lambda 'return id(program3station1runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program3station2runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program3station3runtime).state * 1000;'
- delay: 0.5s
- delay: !lambda 'return id(program3station4runtime).state * 1000;'
error:
src/main.cpp: In lambda function:
src/main.cpp:100:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program1start1->state == homeassistant_time;
src/main.cpp:103:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program2start1->state == homeassistant_time;
src/main.cpp:106:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program3start1->state == homeassistant_time;
src/main.cpp:112:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program1start2->state == homeassistant_time;
src/main.cpp:115:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program2start2->state == homeassistant_time;
src/main.cpp:118:39: error: invalid operands of types ‘float’ and ‘esphome::time::HomeAssistantTime* const’ to binary ‘operator==’
return program3start2->state == homeassistant_time;
src/main.cpp:101:3: warning: control reaches end of non-void function [-Wreturn-type]
src/main.cpp:104:3: warning: control reaches end of non-void function [-Wreturn-type]
src/main.cpp:107:3: warning: control reaches end of non-void function [-Wreturn-type]
src/main.cpp:113:3: warning: control reaches end of non-void function [-Wreturn-type]
src/main.cpp:116:3: warning: control reaches end of non-void function [-Wreturn-type]
src/main.cpp:119:3: warning: control reaches end of non-void function [-Wreturn-type]
*** [/data/reticulation_controller/.pioenvs/reticulation_controller/src/main.cpp.o] Error 1
Curious why your using mqtt and api for esphome?
I need to pull data from HA so I was using mqtt to retrieve those values but figured I would use the api for the general integration for the rest of it
updated code, still has the same error though
# Pin assignments
# D0 Try not to use
# D1 In / Out
# D2 In / Out
# D3 Out
# D4 Out
# D5 In / Out
# D6 In / Out
# D7 In / Out
# D8 In / Out
# SD3 In / Out
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: !secret wifi_ssid
manual_ip:
static_ip: 192.168.0.61 # to be confirmed on IP Address Table spreadsheet
mqtt:
username: !secret mqtt_username
password: !secret mqtt_password
discovery: False
api:
# Enable logging
logger:
ota:
password: !secret ota_password
time:
binary_sensor:
- platform: gpio
pin:
number: D5
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
switch:
- platform: gpio
pin:
number: D1
inverted: true
- platform: gpio
pin:
number: D2
inverted: true
- platform: gpio
pin:
number: D3
inverted: true
- platform: gpio
pin:
number: D4
inverted: true
- platform: gpio
pin:
number: D8
inverted: true
interval:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
- lambda: 'return id(program1start1).state == id(homeassistant_time);'
- lambda: 'return id(program1start2).state == id(homeassistant_time);'
then:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
- lambda: 'return id(program2start1).state == id(homeassistant_time);'
- lambda: 'return id(program2start2).state == id(homeassistant_time);'
then:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
- lambda: 'return id(program3start1).state == id(homeassistant_time);'
- lambda: 'return id(program3start2).state == id(homeassistant_time);'
then:
script:
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
I’m getting closer but still need some help with the time comparison function I’m trying to do:
lambda: 'return strftime(0, 0, tmp, "%H:%M:%S", id(program1start1).state) == id(homeassistant_time).now();'
fails to compile. I have put ‘tmp’ in the ‘font’ section of the strftime for now until I can find a solution. Any help would be awesome
I have the below now, but still fails… anyone…?
# Pin assignments
# D0 Try not to use
# D1 In / Out
# D2 In / Out
# D3 Out
# D4 Out
# D5 In / Out
# D6 In / Out
# D7 In / Out
# D8 In / Out
# SD3 In / Out
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
manual_ip:
mqtt:
discovery: False
api:
# Enable logging
logger:
ota:
i2c:
sda: D0
scl: D1
display:
- platform: lcd_pcf8574
dimensions: 18x2
address: 0x3F
font:
- file: 'alpha_romanie_g98.ttf'
time:
binary_sensor:
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
- platform: gpio
pin:
number: D7
mode: INPUT_PULLUP
filters:
- delayed_on: 10ms
switch:
- platform: gpio
pin:
number: D2
inverted: true
- platform: gpio
pin:
number: D3
inverted: true
- platform: gpio
pin:
number: D4
inverted: true
- platform: gpio
pin:
number: D5
inverted: true
- platform: gpio
pin:
number: D8
inverted: true
interval:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
# - lambda: 'return id(homeassistant_time).now() == id(program1start1);'
# - lambda: 'return id(homeassistant_time).now() == id(program1start2);'
- lambda: 'return id(homeassistant_time).now().minute == id(program1start1).minute && id(homeassistant_time).hour == id(program1start1).hour;'
- lambda: 'return id(homeassistant_time).now().minute == id(program1start2).minute && id(homeassistant_time).hour == id(program1start2).hour;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program1start1).state;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program1start2).state;'
then:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
# - lambda: 'return id(homeassistant_time).now() == id(program2start1);'
# - lambda: 'return id(homeassistant_time).now() == id(program2start2);'
- lambda: 'return id(homeassistant_time).now().minute == id(program2start1).minute && id(homeassistant_time).hour == id(program2start1).hour;'
- lambda: 'return id(homeassistant_time).now().minute == id(program2start2).minute && id(homeassistant_time).hour == id(program2start2).hour;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program2start1).state;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program2start2).state;'
then:
- interval: 1min
then:
- if:
condition:
then:
- if:
condition:
or:
# - lambda: 'return id(homeassistant_time).now() == id(program3start1);'
# - lambda: 'return id(homeassistant_time).now() == id(program3start2);'
- lambda: 'return id(homeassistant_time).now().minute == id(program3start1).minute && id(homeassistant_time).hour == id(program3start1).hour;'
- lambda: 'return id(homeassistant_time).now().minute == id(program3start2).minute && id(homeassistant_time).hour == id(program3start2).hour;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program3start1).state;'
# - lambda: 'return strftime(0, 0, id(font1), "%H:%M:%S", id(homeassistant_time).now()) == id(program3start2).state;'
then:
script:
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
then:
- delay: 0.5s
- delay: 0.5s
- delay: 0.5s
Basically everything works except for the interval lambda’s where I’m trying to compare time values. The issue is that these are stored as floating point numbers and comparing them in this way is not good, nor is my syntax correct. Hopefully someone can see what I’m trying to achieve and provide a solution.
It seems the time attributes you’ve used on the MQTT sensor aren’t supported, it’s only valid when used in conjunction with .now()
I’ve been doing a little bit of experimenting, could you tell me what a message from program1start1
looks like?
Alternatively, ESPHome now supported user-defined services allowing you to get data out of HA.
Program 1time1 comes from an input_datetime entity with only a time component. From the ESPhome docs, the mqtt_subscribe sensor is then saving this as a floating point number.
The variables in the link you supplied look interesting but it doesn’t seem apparent how I could use that feature to bring in my input_datetime entities… I hope they can though
