ESPHome automation causing rebooting of ESP32
Hi everyone,
I am having a simple siren automation on ESP32 Wroom. I want to run the siren for a minute or a little longer. Five seconds after starting the script ESP32 reboots. The logs don’t have much useful information for debugging.
output:
  - platform: ledc
    pin: 13
switch:
  - platform: output
    output: buzzer
script:
  - id: siren
    then:
      - lambda: |-
          auto b = id(buzzer);
          b->turn_on();
          b->set_level(0.1);
          for (int i = 0; i < 10; i++) {
            b->update_frequency(2000);
            delay(500);
            b->update_frequency(2500);
            delay(500);
          b->turn_off();
binary_sensor:
  - platform: gpio
    pin:
      number: 4
    device_class: tamper
    on_state:
      then:
        - script.execute: siren
[20:29:59][V][ledc.output:114]: Setting duty: 65535 on channel 0
[20:29:59][V][ledc.output:114]: Setting duty: 6554 on channel 0
[20:29:59][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2000.000000
[20:29:59][D][ledc.output:060]: Resolution calculated as 15
[20:29:59][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:29:59][V][ledc.output:198]: Trying initialize channel 0 with frequency 2000.0 and bit depth of 15...
[20:29:59][V][ledc.output:203]: Configured frequency: 1996 with bit depth: 15
[20:29:59][V][ledc.output:114]: Setting duty: 3277 on channel 0
[20:30:00][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2500.000000
[20:30:00][D][ledc.output:060]: Resolution calculated as 14
[20:30:00][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:30:00][V][ledc.output:198]: Trying initialize channel 0 with frequency 2500.0 and bit depth of 14...
[20:30:00][V][ledc.output:203]: Configured frequency: 2500 with bit depth: 14
[20:30:00][V][ledc.output:114]: Setting duty: 1638 on channel 0
[20:30:00][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2000.000000
[20:30:00][D][ledc.output:060]: Resolution calculated as 15
[20:30:01][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:30:01][V][ledc.output:198]: Trying initialize channel 0 with frequency 2000.0 and bit depth of 15...
[20:30:01][V][ledc.output:203]: Configured frequency: 1996 with bit depth: 15
[20:30:01][V][ledc.output:114]: Setting duty: 3277 on channel 0
[20:30:01][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2500.000000
[20:30:01][D][ledc.output:060]: Resolution calculated as 14
[20:30:01][V][ledc.output:198]: Trying initialize channel 0 with frequency 2500.0 and bit depth of 14...
[20:30:01][V][ledc.output:203]: Configured frequency: 2500 with bit depth: 14
[20:30:01][V][ledc.output:114]: Setting duty: 1638 on channel 0
[20:30:02][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2000.000000
[20:30:02][D][ledc.output:060]: Resolution calculated as 15
[20:30:02][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:30:02][V][ledc.output:198]: Trying initialize channel 0 with frequency 2000.0 and bit depth of 15...
[20:30:02][V][ledc.output:203]: Configured frequency: 1996 with bit depth: 15
[20:30:02][V][ledc.output:114]: Setting duty: 3277 on channel 0
[20:30:02][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2500.000000
[20:30:02][D][ledc.output:060]: Resolution calculated as 14
[20:30:02][V][ledc.output:198]: Trying initialize channel 0 with frequency 2500.0 and bit depth of 14...
[20:30:02][V][ledc.output:203]: Configured frequency: 2500 with bit depth: 14
[20:30:02][V][ledc.output:114]: Setting duty: 1638 on channel 0
[20:30:03][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2000.000000
[20:30:03][D][ledc.output:060]: Resolution calculated as 15
[20:30:03][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:30:03][V][ledc.output:198]: Trying initialize channel 0 with frequency 2000.0 and bit depth of 15...
[20:30:03][V][ledc.output:203]: Configured frequency: 1996 with bit depth: 15
[20:30:03][V][ledc.output:114]: Setting duty: 3277 on channel 0
[20:30:03][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2500.000000
[20:30:03][D][ledc.output:060]: Resolution calculated as 14
[20:30:03][V][ledc.output:198]: Trying initialize channel 0 with frequency 2500.0 and bit depth of 14...
[20:30:03][V][ledc.output:203]: Configured frequency: 2500 with bit depth: 14
[20:30:03][V][ledc.output:114]: Setting duty: 1638 on channel 0
[20:30:04][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2000.000000
[20:30:04][D][ledc.output:060]: Resolution calculated as 15
[20:30:04][V][ledc.output:191]: Using Arduino API - Trying to define channel, frequency and bit depth...
[20:30:04][V][ledc.output:198]: Trying initialize channel 0 with frequency 2000.0 and bit depth of 15...
[20:30:04][V][ledc.output:203]: Configured frequency: 1996 with bit depth: 15
[20:30:04][V][ledc.output:114]: Setting duty: 3277 on channel 0
[20:30:04][D][ledc.output:055]: Calculating resolution bit-depth for frequency 2500.000000
[20:30:04][D][ledc.output:060]: Resolution calculated as 14
[20:30:04][V][ledc.output:198]: Trying initialize channel 0 with frequency 2500.0 and bit depth of 14...
[20:30:04][V][ledc.output:203]: Configured frequency: 2500 with bit depth: 14
[20:30:04][V][ledc.output:114]: Setting duty: 1638 on channel 0
WARNING door-alarm @ 192.168.4.225: Connection error occurred: [Errno 104] Connection reset by peer
INFO Processing unexpected disconnect from ESPHome API for door-alarm @ 192.168.4.225
WARNING Disconnected from API
INFO Successfully connected to door-alarm @ 192.168.4.225 in 0.009s
INFO Successful handshake with door-alarm @ 192.168.4.225 in 0.111s
What buzzer/siren and how is it connected?
My guess is that it draws so much current that it causes your power supply voltage to sag, resetting the ESP.
But without knowing specifics, this is only a guess.
Yeah - what Tom said.
Switching LEDC at the rates you have done works fine - I tested it using yaml rather that lambda but the result is the exact same (without the crash):
output:
  - platform: ledc
    pin: 13
script:
  - id: siren
    then:
      - output.turn_on: buzzer
      - output.set_level:
          level: "10%"
      - repeat:
          count: 10
          then:
            - output.ledc.set_frequency:
                frequency: "2000Hz"
            - delay: .5s
                frequency: "2500Hz"
            - delay: .5s
      - output.turn_off: buzzer
I don’t understand the lower level stuff but I believe you have to be careful using delays in lambdas too.
So worth trying zoogara’s approach.
You may be right - delays in lambda are blocking, the yaml delay: isn’t. Maybe that’s causing some grief?
Thanks for your reply. It works! I was also suspecting the delays were causing troubles. Was not sure about script execution implementation. Was curious whether scripts called synchronously or async.
