I understand that automations in ESPHome should continue to work even if the WiFi network is down or the MQTT server is not reachable - https://esphome.io/guides/automations.html#do-automations-work-without-a-network-connection
My ESP32 is in a poor WiFi location. When the network doesn’t connect, the automations do not run (in this case, the Close Door or Open Door scripts).
Is there anything missing from my code, that would enable the automations to run when there is no WiFi or MQTT network?
esphome:
platform: ESP32
board: esp32dev
on_boot:
priority: -100
then:
lambda: |-
if (id(deepSleepCycleBool) == false)
id(deepSleepCycleBool) = true;
id(mqtt_client).publish("chicken-coop/ id(deepSleepCycleBool)", "true");
else
id(deepSleepCycleBool) = false;
id(mqtt_client).publish("chicken-coop/ id(deepSleepCycleBool)", "false");
# Enable logging
logger:
# Enable Home Assistant API
#api:
ota:
password: "<removed>"
wifi:
networks:
- ssid: "<removed>"
- ssid: "<removed>"
power_save_mode: none
reboot_timeout: 0s
ap:
ssid: "Chicken-Coop Fallback Hotspot"
deep_sleep:
run_duration: 90s
sleep_duration: 29min
mqtt:
broker: 192.168.1.110
reboot_timeout: 0s
on_message:
- topic: chickens/deepsleepactive
payload: 'DISABLED'
then:
- deep_sleep.prevent: deep_sleep_1
payload: 'FORCE'
then:
- deep_sleep.enter: deep_sleep_1
- topic: chickens/doorMode
payload: 'MANUAL'
then:
- lambda: |-
id(isInManualMode) = true;
payload: 'AUTO'
then:
- lambda: |-
id(isInManualMode) = false;
- topic: chickens/manualDoorRequest
payload: 'CLOSE'
then:
- script.execute: closeDoorScript
payload: 'OPEN'
then:
- script.execute: openDoorScript
globals:
- id: lightSensorReadingsArry
type: int[2]
restore_value: yes
- id: valueIndex
type: int
restore_value: yes
initial_value: '0'
- id: sensorReadingMovingAverage
type: int
restore_value: yes
initial_value: '0'
- id: doorIsClosed
type: bool
restore_value: yes
initial_value: 'true'
- id: isInManualMode
type: bool
restore_value: yes
initial_value: 'false'
- id: deepSleepCycleBool
type: bool
restore_value: yes
- id: deepSleepCycleBoolPreviousValue
type: bool
restore_value: yes
script:
- id: closeDoorScript
then:
- lambda: |-
id(doorIsClosed) = true;
- mqtt.publish:
topic: chicken-coop/doorAction
payload: "Door Closing"
- switch.turn_on: closedoorswitch1
- switch.turn_on: closedoorswitch2
- delay: 30s
- switch.turn_off: closedoorswitch1
- switch.turn_off: closedoorswitch2
- mqtt.publish:
payload: "Door Closed"
- id: openDoorScript
then:
- lambda: |-
id(doorIsClosed) = false;
- mqtt.publish:
payload: "Door Opening"
- switch.turn_on: opendoorswitch1
- switch.turn_on: opendoorswitch2
- delay: 30s
- switch.turn_off: opendoorswitch1
- switch.turn_off: opendoorswitch2
- mqtt.publish:
payload: "Door Open"
switch:
- platform: gpio
pin: GPIO12
- platform: gpio
pin: GPIO13
- platform: gpio
pin:
number: GPIO18
#inverted: true
- platform: gpio
pin:
number: GPIO19
#inverted: true
- platform: adc
pin: GPIO32
name: "TEMT6000 Illuminance"
device_class: illuminance
unit_of_measurement: lx
update_interval: 30s
on_value:
then:
- if:
condition:
lambda: |-
if (id(sensorReadingMovingAverage) < 50)
if (id(doorIsClosed) == false)
if(id(isInManualMode) == false)
return true;
else
return false;
else
return false;
else
return false;
then:
- if:
condition:
lambda: |-
//int newReading = static_cast<int>((x / 10000) * 2000000);
//if (newReading > 100)
if (id(sensorReadingMovingAverage) > 50)
if (id(doorIsClosed) == true)
return true;
else
return false;
else
return false;
else
return false;
then:
- lambda: |-
int windowSize = 2;
bool allowAverageCalcToRun = true;
int sensorReadingInt = static_cast<int>((x / 10000) * 2000000);
std::string sensorReadingStr = to_string(sensorReadingInt);
id(mqtt_client).publish("chicken-coop/newSensorReading", sensorReadingStr);
if (id(deepSleepCycleBoolPreviousValue) == true)
id(deepSleepCycleBoolPreviousValue) = false;
else
allowAverageCalcToRun = false;
else
if (id(deepSleepCycleBoolPreviousValue) == false)
id(deepSleepCycleBoolPreviousValue) = true;
else
if (allowAverageCalcToRun)
id(lightSensorReadingsArry)[id(valueIndex)] = sensorReadingInt;
std::string currentIndexStr = to_string(id(valueIndex));
id(mqtt_client).publish("chicken-coop/valueIndex", currentIndexStr);
if (id(valueIndex) < windowSize)
id(valueIndex) = id(valueIndex) + 1;
else
id(valueIndex) = 0;
id(sensorReadingMovingAverage) = 0;
for (int i = 0; i < windowSize; i++)
id(sensorReadingMovingAverage) = id(sensorReadingMovingAverage) + id(lightSensorReadingsArry)[i];
id(sensorReadingMovingAverage) = id(sensorReadingMovingAverage) / windowSize;
int localReadingAverage = id(sensorReadingMovingAverage);
std::string sensorReadingMovingAverageStr = to_string(localReadingAverage);
id(mqtt_client).publish("chicken-coop/id(sensorReadingMovingAverage)", sensorReadingMovingAverageStr);
