ESPHome Automation using sun as condition
Hi guys,
I am trying to add a “if condition” to my yaml file in esphome, but keep getting a error, "Unable to find condition with the name ‘sun.is_above_horizon’.
I’m following esphome docs as in the following link: https://esphome.io/components/sun.html#sun-is-above-below-horizon-condition
See code attached.
esphome:
  platform: ESP32
  board: esp32doit-devkit-v1
wifi:
  ssid: "ssid"
  password: "password"
  ap:
    ssid: "Master Bedroom Cupboard"
    password: "Iw0MTmL1zWsW"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
  - platform: gpio
    pin: 36
    device_class: door
    on_press:
      - if:
          condition:
            - sun.is_above_horizon:
          then:
            - light.turn_on:
                brightness: 30%
    on_release:
      then:
        - light.turn_off:
  - platform: gpio
    pin: 39
    device_class: door
    on_press:
      then:
        - light.turn_on:
            brightness: 100%
    on_release:
      then:
        - light.turn_off:
  - platform: gpio
    pin: 34
    device_class: door
    on_press:
      then:
        - light.turn_on:
            brightness: 100%
    on_release:
      then:
        - light.turn_off:
  - platform: gpio
    pin: 35
    device_class: door
    on_press:
      then:
        - light.turn_on:
            brightness: 100%
            red: 100%
            green: 0%
            blue: 0%
    on_release:
      then:
        - light.turn_off:
output:
  - platform: ledc
    pin: 15
  - platform: ledc
    pin: 2
  - platform: ledc
    pin: 4
  - platform: ledc
    pin: 1
  - platform: ledc
    pin: 22
  - platform: ledc
    pin: 3
  - platform: ledc
    pin: 18
  - platform: ledc
    pin: 19
  - platform: ledc
    pin: 17
light:
  - platform: monochromatic
    output: nathan
    name: "Nathan Cupboard"
    output: mariska
    name: "Mariska Cupboard"
    output: mirror
  - platform: rgb
    red: red1
    green: green1
    blue: blue1
  - platform: rgb
    red: red2
    green: green2
    blue: blue2
See error attached.
I just can’t seem to get this to work.
hi there, look at the very first requirements under the docs you linked to! You need to set up the location for sun and you need a time platform, like this:
sun:
  latitude: -34.000000
  longitude: 138.000000
time:
  - platform: homeassistant
interval:
  interval: 10sec
  then:
    - if:
        condition:
        then:
          - logger.log: Sun is above horizon!
hope that helps!
PS you need to insert a then: after on_press: and before the - if:
Thank alot Patrick, I got it to work doing the following:
sun:
  latitude: xx.xxxxx
  longitude: xx.xxxxx
time:
binary_sensor:
  - platform: gpio
    pin: 36
    device_class: door
    on_press:
      - if:
          condition:
          then:
            - light.turn_on:
                brightness: 100%
      - if:
          condition:
            - sun.is_below_horizon:
          then:
            - light.turn_on:
                brightness: 30%
    on_release:
      then:
        - light.turn_off:
