I have ESPHome set up and I’ve added successfully a d1_mini esp8266 device. I can see it in the ESPHome dashboard, it appears online and I can flash code to it.
My problem is that I don’t see a binary_sensor I’am adding in the YAML. This doesn’t only happens with binary_sensors, I’ve tried other components with same luck.
This is the YAML config for my device:
esphome:
friendly_name: ESP 02
esp8266:
board: d1_mini
# Enable logging
logger:
level: DEBUG
# Enable Home Assistant API
api:
encryption:
key: "[redacted]"
ota:
password: "[redacted]"
wifi:
ssid: !secret wifi_ssid
manual_ip:
gateway: 10.10.10.1
subnet: 255.255.255.0
static_ip: 10.10.10.71
ap:
ssid: "Esp-02 Fallback Hotspot"
captive_portal:
binary_sensor:
- platform: status
These are the ESPHome logs, where everything looks correct:
2024-06-06 13:14:54,936 INFO 304 GET /devices (0.0.0.0) 1.89ms
2024-06-06 13:14:59,934 INFO 304 GET /devices (0.0.0.0) 1.24ms
2024-06-06 13:15:00,935 INFO 304 GET /edit?configuration=esp-02.yaml (0.0.0.0) 1.64ms
2024-06-06 13:15:00,953 INFO 101 GET /ace (0.0.0.0) 0.75ms
2024-06-06 13:15:00,955 INFO Running command 'esphome --dashboard -q vscode --ace /config/esphome'
2024-06-06 13:16:23,471 INFO 200 POST /edit?configuration=esp-02.yaml (0.0.0.0) 1.95ms
I can flash the device and see the logs. But binary_sensors or any other components do not appear in HA Overview dashboard or Developer Tools or ESPHome device config.
Note, the HA server is not on the same subnet as the ESP device, I don’t know if this is relevant, since I can see the logs.
Any help is appreciated on how to proceed.
