Joshua
(SERGIO NUVOLONI)
September 12, 2020, 2:28pm
1
Hi everyone,
with a nextion display I am making a control to turn on the lights and close the terrace curtains. I am using, for shelly 1 lights and 2.5 for shelly curtains. I connected the nextion display with a NODE MCU and everything seems to work. Checking the ESPhome logs in HA I get the following error message when using shelly 2.5: Can’t convert ‘opening’ to binary state! the curtain opens and closes but I cannot change the image in the display.
Any idea ???
Thanks for your help.
Regards.
Following part of the script:
display:
platform: nextion
lambda: |-
it.set_wait_for_ack(false);
if (id(Luce_Terrazzo).state) {
it.send_command_printf("%s.pic=5", “luce”);
else {
it.send_command_printf("%s.pic=4", “luce”);
if (id(Tenda_Terrazzo_Grande).state) {
it.send_command_printf("%s.pic=8", “tenda1”);
else {
it.send_command_printf("%s.pic=7", “tenda1”);
tom_l
September 12, 2020, 6:57pm
2
Please format your pasted code.
Binary states are ‘off’ and ‘on’ only. Your shelly is sending ‘opening’ when it should send ‘on’.
If you want three or more states (e.g. open, closed, opening) use a sensor rather than a binary_sensor.
Joshua
(SERGIO NUVOLONI)
September 13, 2020, 8:43am
3
Hi Tom,
thanks for your help.
I try to set sensor but unfortunately without success.
How can I format the code properly?
Thanks in advance for your help.
Ciao .
Sergio.
Following the code.
esphome:
platform: ESP8266
board: nodemcuv2
wifi:
ssid: "xxxxx"
password: "xxxxxx"
ap:
ssid: "Display One Fallback Hotspot"
password: "xxxxxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "xxxxx"
ota:
password: "xxxxx"
uart:
rx_pin: D3
tx_pin: D1
baud_rate: 9600
binary_sensor:
- platform: homeassistant
name: "Switch Luce terrazzo"
entity_id: switch.shelly_shsw_1_e0eba8
name: "Switch Tenda Terrazzo Grande"
entity_id: cover.shelly_shsw_25_73677f
#Luce Terrazzo
- platform: nextion
page_id: 0
component_id: 2
name: Luce Terrazzo switch_on
on_press:
then:
- homeassistant.service:
service: homeassistant.turn_on
- platform: nextion
page_id: 0
component_id: 3
name : Luce Terrazzo Switch_off
on_press:
then:
service: homeassistant.turn_off
# Tenda Terrazzo Grande
- platform: nextion
page_id: 0
component_id: 5
name: Tenda Grande Open
on_press:
then:
service: cover.open_cover
- platform: nextion
page_id: 0
component_id: 7
name: Tenda Grande Closed
on_press:
then:
service: cover.close_cover
- platform: nextion
page_id: 0
component_id: 6
name: Tenda Grande Stop
on_press:
then:
service: cover.stop_cover
display:
- platform: nextion
lambda: |-
it.send_command_printf("%s.pic=5", "luce");
else {
it.send_command_printf("%s.pic=4", "luce");
if (id(Tenda_Grande).state) {
it.send_command_printf("%s.pic=7", "tenda1");
else {
it.send_command_printf("%s.pic=8", "tenda1");
