The ESP devices don’t go offline, I can see their logs via the ESPHome panel in the Home Assistant UI, etc.
But the BLE devices that I use them to connect to often become unavailable (several different ones, e.g., a Xioami plant sensor, a Tuya BLE irrigation timer).
Often, they will only work a couple of hours before stopping. I don’t need to move them (they are within range), I don’t need to change anything in config or on the actual BLE device (they work fine, I don’t ever need to touch them). It’s almost as if the ESPHome just can’t function for more than a few hours without a restart.
Has anyone experienced anything like this? And more importantly, have an idea of how to fix?
I've tried both of these configs for the ESP with the same result
esphome:
friendly_name: ble-proxy-01
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: REDACTED
ota:
password: REDACTED
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Ble-Proxy-01 Fallback Hotspot"
password: REDACTED
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
captive_portal:
substitutions:
packages:
esphome.bluetooth-proxy: github://esphome/firmware/bluetooth-proxy/esp32-generic.yaml@main
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: REDACTED
wifi:
This is the log output when it stops working ...
INFO ESPHome 2024.5.1
INFO Reading configuration /config/esphome/ble-proxy-01.yaml...
INFO Starting log output from 10.0.21.78 using esphome API
INFO Successfully connected to ble-proxy-01 @ 10.0.21.78 in 0.083s
INFO Successful handshake with ble-proxy-01 @ 10.0.21.78 in 0.120s
[13:07:30][I][app:100]: ESPHome version 2024.5.1 compiled on May 20 2024, 11:32:26
[13:07:30][C][wifi:580]: WiFi:
[13:07:30][C][wifi:408]: Local MAC: REDACTED
[13:07:30][C][wifi:413]: SSID: [redacted]
[13:07:30][C][wifi:416]: IP Address: 10.0.21.78
[13:07:30][C][wifi:420]: BSSID: [redacted]
[13:07:30][C][wifi:421]: Hostname: 'ble-proxy-01'
[13:07:30][C][wifi:423]: Signal strength: -61 dB ▂▄▆█
[13:07:30][C][wifi:427]: Channel: 6
[13:07:30][C][wifi:428]: Subnet: 255.255.254.0
[13:07:30][C][wifi:429]: Gateway: 10.0.20.1
[13:07:30][C][wifi:430]: DNS1: 10.0.30.43
[13:07:30][C][wifi:431]: DNS2: 1.1.1.1
[13:07:30][C][logger:185]: Logger:
[13:07:30][C][logger:186]: Level: DEBUG
[13:07:30][C][logger:188]: Log Baud Rate: 115200
[13:07:30][C][logger:189]: Hardware UART: UART0
[13:07:30][C][bluetooth_proxy:088]: Bluetooth Proxy:
[13:07:30][C][bluetooth_proxy:089]: Active: YES
[13:07:30][C][esp32_ble:374]: ESP32 BLE:
[13:07:30][C][esp32_ble:376]: MAC address: EC:94:CB:4B:33:AA
[13:07:30][C][esp32_ble:377]: IO Capability: none
[13:07:30][C][esp32_ble_tracker:649]: BLE Tracker:
[13:07:30][C][esp32_ble_tracker:650]: Scan Duration: 300 s
[13:07:30][C][esp32_ble_tracker:651]: Scan Interval: 1100.0 ms
[13:07:30][C][esp32_ble_tracker:652]: Scan Window: 1100.0 ms
[13:07:30][C][esp32_ble_tracker:653]: Scan Type: ACTIVE
[13:07:30][C][esp32_ble_tracker:654]: Continuous Scanning: True
[13:07:30][C][captive_portal:088]: Captive Portal:
[13:07:30][C][mdns:115]: mDNS:
[13:07:30][C][mdns:116]: Hostname: ble-proxy-01
[13:07:30][C][ota:096]: Over-The-Air Updates:
[13:07:30][C][ota:097]: Address: ble-proxy-01.local:3232
[13:07:30][C][ota:100]: Using Password.
[13:07:30][C][ota:103]: OTA version: 2.
[13:07:30][C][api:139]: API Server:
[13:07:30][C][api:140]: Address: ble-proxy-01.local:6053
[13:07:30][C][api:142]: Using noise encryption: YES
[13:08:19][D][esp32_ble_tracker:266]: Starting scan...
but nothing happens for a few minutes after the “Staring scan…”
and this is the log output after a power cycle
INFO Starting log output from ble-proxy-01.local using esphome API
WARNING Can't connect to ESPHome API for ble-proxy-01.local: Error resolving IP address: [Errno -5] No address associated with hostname (APIConnectionError)
INFO Trying to connect to ble-proxy-01.local in the background
INFO Successfully connected to ble-proxy-01 @ 10.0.21.78 in 0.029s
[13:11:03][I][app:100]: ESPHome version 2024.5.1 compiled on May 20 2024, 11:32:26
[13:11:03][C][wifi:580]: WiFi:
[13:11:03][C][wifi:408]: Local MAC: EC:94:CB:4B:33:A8
[13:11:03][C][wifi:413]: SSID: [redacted]
[13:11:03][C][wifi:416]: IP Address: 10.0.21.78
[13:11:03][C][wifi:420]: BSSID: [redacted]
[13:11:03][C][wifi:421]: Hostname: 'ble-proxy-01'
[13:11:03][C][wifi:423]: Signal strength: -89 dB ▂▄▆█
[13:11:03][C][wifi:427]: Channel: 6
[13:11:03][C][wifi:428]: Subnet: 255.255.254.0
[13:11:03][C][wifi:429]: Gateway: 10.0.20.1
[13:11:03][C][wifi:430]: DNS1: 10.0.30.43
[13:11:03][C][wifi:431]: DNS2: 1.1.1.1
[13:11:03][C][logger:185]: Logger:
[13:11:03][C][logger:186]: Level: DEBUG
[13:11:03][C][logger:188]: Log Baud Rate: 115200
[13:11:03][C][logger:189]: Hardware UART: UART0
[13:11:03][C][bluetooth_proxy:088]: Bluetooth Proxy:
[13:11:03][C][bluetooth_proxy:089]: Active: YES
[13:11:03][C][esp32_ble:374]: ESP32 BLE:
[13:11:03][C][esp32_ble:377]: IO Capability: none
[13:11:03][C][esp32_ble_tracker:649]: BLE Tracker:
[13:11:03][C][esp32_ble_tracker:650]: Scan Duration: 300 s
[13:11:03][C][mdns:115]: mDNS:
[13:11:03][C][mdns:116]: Hostname: ble-proxy-01
[13:11:03][C][ota:096]: Over-The-Air Updates:
[13:11:03][C][ota:097]: Address: ble-proxy-01.local:3232
[13:11:03][C][ota:100]: Using Password.
[13:11:03][C][ota:103]: OTA version: 2.
[13:11:03][C][api:139]: API Server:
[13:11:03][C][api:140]: Address: ble-proxy-01.local:6053
[13:11:03][C][api:142]: Using noise encryption: YES
[13:11:06][I][bluetooth_proxy:278]: [0] [DC:23:50:2A:2C:AB] Connecting v3 with cache
[13:11:07][D][esp32_ble_tracker:215]: Pausing scan to make connection...
[13:11:07][I][esp32_ble_client:067]: [0] [DC:23:50:2A:2C:AB] 0x00 Attempting BLE connection
[13:11:08][I][bluetooth_proxy:278]: [1] [80:6F:B0:5A:2B:1B] Connecting v3 with cache
[13:11:08][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_CONNECT_EVT
[13:11:08][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_OPEN_EVT
[13:11:08][I][esp32_ble_client:154]: [0] [DC:23:50:2A:2C:AB] Connected
[13:11:08][I][esp32_ble_client:067]: [1] [80:6F:B0:5A:2B:1B] 0x00 Attempting BLE connection
[13:11:08][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[13:11:09][D][esp32_ble_client:306]: [0] [DC:23:50:2A:2C:AB] Event 46
[13:11:09][D][esp32_ble_client:188]: [0] [DC:23:50:2A:2C:AB] cfg_mtu status 0, mtu 23
[13:11:09][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_WRITE_DESCR_EVT
[13:11:09][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_WRITE_CHAR_EVT
[13:11:09][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_NOTIFY_EVT
[13:11:10][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_NOTIFY_EVT
[13:11:10][D][esp32_ble_client:110]: [0] [DC:23:50:2A:2C:AB] ESP_GATTC_WRITE_CHAR_EVT
[13:11:15][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_CONNECT_EVT
[13:11:15][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_OPEN_EVT
[13:11:15][I][esp32_ble_client:154]: [1] [80:6F:B0:5A:2B:1B] Connected
[13:11:15][D][esp32_ble_tracker:266]: Starting scan...
[13:11:17][D][esp32_ble_client:306]: [1] [80:6F:B0:5A:2B:1B] Event 46
[13:11:17][D][esp32_ble_client:188]: [1] [80:6F:B0:5A:2B:1B] cfg_mtu status 0, mtu 247
[13:11:17][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_READ_CHAR_EVT
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_READ_CHAR_EVT
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_REG_FOR_NOTIFY_EVT
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_WRITE_DESCR_EVT
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_WRITE_CHAR_EVT
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_NOTIFY_EVT
[13:11:18][D][esp32_ble_client:306]: [1] [80:6F:B0:5A:2B:1B] Event 39
[13:11:18][I][esp32_ble_client:084]: [1] [80:6F:B0:5A:2B:1B] Disconnecting.
[13:11:18][D][esp32_ble_client:110]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_CLOSE_EVT
[13:15:48][I][ota:117]: Boot seems successful, resetting boot loop counter.
[13:15:48][D][esp32.preferences:114]: Saving 1 preferences to flash...
[13:15:48][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
[13:16:15][D][esp32_ble_tracker:266]: Starting scan...
[13:16:18][I][bluetooth_proxy:278]: [1] [80:6F:B0:5A:2B:1B] Connecting v3 with cache
[13:16:18][D][esp32_ble_tracker:215]: Pausing scan to make connection...
[13:16:18][I][esp32_ble_client:067]: [1] [80:6F:B0:5A:2B:1B] 0x00 Attempting BLE connection
[13:16:38][I][esp32_ble_client:084]: [1] [80:6F:B0:5A:2B:1B] Disconnecting.
[13:16:48][D][esp32_ble_client:172]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_DISCONNECT_EVT, reason 256
[13:16:48][D][esp32_ble_tracker:266]: Starting scan...
[13:16:48][I][bluetooth_proxy:278]: [1] [80:6F:B0:5A:2B:1B] Connecting v3 with cache
[13:16:48][D][esp32_ble_tracker:215]: Pausing scan to make connection...
[13:16:48][I][esp32_ble_client:067]: [1] [80:6F:B0:5A:2B:1B] 0x00 Attempting BLE connection
[13:17:08][I][esp32_ble_client:084]: [1] [80:6F:B0:5A:2B:1B] Disconnecting.
[13:17:18][D][esp32_ble_client:172]: [1] [80:6F:B0:5A:2B:1B] ESP_GATTC_DISCONNECT_EVT, reason 256
[13:17:18][D][esp32_ble_tracker:266]: Starting scan...
[13:17:18][I][bluetooth_proxy:278]: [1] [80:6F:B0:5A:2B:1B] Connecting v3 with cache
[13:17:18][D][esp32_ble_tracker:215]: Pausing scan to make connection...
[13:17:18][I][esp32_ble_client:067]: [1] [80:6F:B0:5A:2B:1B] 0x00 Attempting BLE connection
where it starts reporting values for the BLE devices nearby.
