ESPHome - Blitzwolf BW-SHP6 configuration
Here is my Blitzwolf SHP6 ESPHOME configuration file
Functions:
  • Button - ON / OFF
  • When the button on blue LED on
  • When power consumption above 1W red LED on (delayed)
  • after boot turn on the relay
# Blitzwolf SHP6 15A Power Monitoring Plug
# https://templates.blakadder.com/blitzwolf_SHP6-15A.html
substitutions:
  plug_name: blitzwolf_shp6_04
  # Higher value gives lower watt readout
  current_res: '0.00290'
  # Lower value gives lower voltage readout
  voltage_div: '760'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    priority: -10
    then:
    # on affter boot
    - switch.toggle: relay
wifi:
  ssid: !secret wifi_ssid
logger:
api:
ota:
web_server:
  port: 80
time:
  - platform: homeassistant
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
      inverted: True
    on_press:
switch:
- platform: gpio
  pin: GPIO15
  on_turn_on:
    - switch.turn_on: "${plug_name}_LED_Blue"
  on_turn_off:
    - switch.turn_off: "${plug_name}_LED_Blue"
    - switch.turn_off: "${plug_name}_LED_Red"
- platform: gpio
  internal: true
  pin: GPIO2
  inverted: True
- platform: gpio
  internal: true
  pin: GPIO0
  inverted: True
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO04
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    current:
      unit_of_measurement: 'A'
      accuracy_decimals: 3
    voltage:
      unit_of_measurement: 'V'
    power:
      unit_of_measurement: 'W'
      on_value_range:
        - above: 2.0
          then:
            - switch.turn_on: "${plug_name}_LED_Red"
        - below: 2.0
          then:
    change_mode_every: 8
    update_interval: 5s
  - platform: total_daily_energy
    name: "${plug_name}_Total Daily Energy"
    power_id: "${plug_name}_Wattage"
    filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
    unit_of_measurement: kWh
# Extra sensor to keep track of plug uptime
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    filters:
      - multiply: 0.000011574
# BlitzWolf BW-SHP6 10A Power Monitoring Plug
# https://templates.blakadder.com/blitzwolf_SHP6.html
substitutions:
  plug_name: blitzwolf_shp6_01
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    priority: -10
    then:
    # on affter boot
wifi:
logger:
api:
ota:
web_server:
  port: 80
time:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
      inverted: True
    on_press:
switch:
- platform: gpio
  pin: GPIO15
  on_turn_on:
  on_turn_off:
- platform: gpio
  internal: true
  pin: GPIO2
  inverted: True
- platform: gpio
  internal: true
  pin: GPIO0
  inverted: True
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current:
    voltage:
    power:
      on_value_range:
        - above: 1.0
          then:
        - below: 1.0
          then:
    update_interval: 5s
    filters:
        - multiply: 0.001
  - platform: uptime
    filters:
