ESPHome - Blitzwolf BW-SHP6 configuration
Hi everybody,
I just got my Blitzwolf BW-SHP6 working with ESPHome on home assistant and wanted to share the config file so everybody can use it. I flashed my SHP6 using the tutorial for the Tasmota Github and it worked fine. But it was quite a hassle to but the plug back together so maybe using tuya-convert is better method. Intermit.tech has a tutorial on that, but i haven’t tried it, since i don’t have a Linux PC.
I based the config on the tutorial from Intermit.tech who used a SHP2 and changed the pin layout according to this post. Then I did some modifications to best mimic the original working of the device.
substitutions:
  plug_name: YOURNAME
  # Higher value gives lower watt readout
  current_res: "0.00290"
  # Lower value gives lower voltage readout
  voltage_div: "940"
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: "YOURSSID"
  password: "YOURPASSWORD"
# Enable logging
logger:
# Enable Home Assistant API
api:
  password: 'YOURAPIPASSWORD'
ota:
time:
  - platform: homeassistant
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      inverted: True
    on_press:
      - switch.toggle: switch1
output:
  - platform: gpio
    pin: GPIO15
  - platform: gpio
    pin: GPIO00
    inverted: True
status_led:
  pin:
    number: GPIO02
    inverted: True
switch:
  icon: mdi:power-socket-eu
  optimistic: true
  turn_on_action:
    - output.turn_on: relay
    - output.turn_on: led1
  turn_off_action:
    - output.turn_off: relay
    - output.turn_off: led1
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current_resistor: ${current_res}
    voltage_divider: ${voltage_div}
    current:
      unit_of_measurement: A
      accuracy_decimals: 3
      icon: mdi:flash-circle
    voltage:
      unit_of_measurement: V
    power:
      unit_of_measurement: W
    change_mode_every: 4
    update_interval: 10s
  - platform: total_daily_energy
    name: "${plug_name}_Total Daily Energy"
    power_id: "${plug_name}_Wattage"
    filters:
        # Multiplication factor from W to kW is 0.001
        - multiply: 0.001
    unit_of_measurement: kWh
    icon: mdi:clock-alert
# Extra sensor to keep track of plug uptime
  - platform: uptime
    icon: mdi:clock-outline
I set the template switch to optimistic, because i don’t no how to do a lambda template. I’m sure this can be improved, but it works for me at the moment.
I hope this will help somebody,
Greetings,
Tijmen
Thanks for the share, looks to be a really nice product (sort of copy of Fibaro Zwave ones :wink: Would be a good contribution at cookbook on ESPhome website :wink:
My configuration is very similar but I use gpio switch:
substitutions:
  device_name: DEVICE_NAME
  current_res: '0.00290'
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: !secret wifi_ssid
logger:
api:
  password: !secret esphome_api_password
ota:
  password: !secret esphome_ota_password
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
    on_press:
      - switch.toggle: relay
output:
  - platform: gpio
    pin: GPIO00
    inverted: true
switch:
  - platform: gpio
    pin: GPIO15
    on_turn_on:
    on_turn_off:
status_led:
  pin:
    number: GPIO02
    inverted: true
  - platform: uptime
    unit_of_measurement: days
    update_interval: 300s
    filters:
      - multiply: 0.000011574
  - platform: wifi_signal
    name: '${device_name} WiFi Signal'
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: true
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current:
      unit_of_measurement: 'A'
      icon: mdi:flash-outline
    voltage:
      unit_of_measurement: 'V'
    power:
      unit_of_measurement: 'W'
Hi all,
Im quite new to Hass.io.
But like it allot already. :slight_smile:
Question, I hope you can help me.
I have flashed the SHP6 with a 3d printed flasher,
Now if installed Home assistant. Also installed ESPHome. I opend the WEB UI
I added a new device, clickt “edit” and copyed the configuration into the text editor.
added the Wifi credentials. But it is also asking for a API and OTA API.
Where can i find the API`s . Am i missing something or do i working in the wrong direction!?
The SHP-6 is configured with a static ip addres (No DNS configured) How does the ESPHome know the IP address because i cannot reach the device.
Greetings
Palermo
hello Palermo,
i think these questions are more esphome related, so maybe you can ask them in the related topic. if you cant figure it it out there i will look in to it it for you.
i wanted to post a response for a different reason…
My shp-6 actually bunt out, it was quite a show and a bit of a shock.
looking back and examining the burnt out circuit board, i think i put to much stress on it.
so extra recommendation to tuya flash or 3d printed flasher.
Although there is a slight change that my shp6 was faulty from the factory, no way to check. blame disassembly, i think
Oei,Watch out.
You dont want them to start a fire.
I have an 3d Printer so if anyone needs a Flasher. Please let me know.
I printed 4 of them already.
I relation to my problem I think may be the new version 0.100.3 changed a few things.
When I compile the configuration and upload the bin file to the plug. Still showing me that the plug is down. I`m still looking
Greetings
Palermo
For those who would like to use this with the tuya convert; I get the strong impression that these will not work with tuya-convert. The original plug tries downloading a firmware using a non-secure connection. These plugs try to use https, and that fails with tuya convert. I’ll try to see if I can use stunnel to get them to download a firmware, but If they do proper certificate checking, that won’t work. I’ll post my results here later.
A random certificate with a valid certificate from a private root will not work.
Off course the plug does not have an RTC, so cert based authentication will be a challenge. Therefore they seemed to have chosen to use pre shared key authentication.
The SHP6 tries to connect to a3.tuyaeu.com and sugests 2 cipher suites:
TLS_PSK_WITH_AES128_CBC_SHA256 (0x00ae)
TLS_EMPTY_RENEGOTIATION_INFO_SCSV (0x00ff)
So if they use a PSK it’s probably in the original firmware somewhere.
Nevermind, someone has already figured this out and the newest version of tuya-convert supports the new devices perfectly.
Only just received two SHP7, the double version of this. Won’t have time to poke the serial and stuff for a while, but uploaded some pictures if anyone wanna have a look under the hood before ordering these.
(No idea if ESPHome is possible or not at this time; looking closer the green module does say RL_ESP8285_Z0_V2.0 so I guess its just a matter of mapping pins one day I have the time:)
((or just pull the module, read the silkscreen, then probe the board another day https://ibb.co/album/jR0taa))
Done intitial pin mapping:
wifi module
IO1/TX   IO3/RX
IO5      IO4
IO0      IO2
IO13     IO12
IO14     IO16
IOUT*    GND
VDD
mapping
IO0       switch1 (next to wifi module)
IO13      led1
IO15      relay1
IO2       switch2
IO12      led2
IO16      relay2
IO01/TX   blue led
IO03/RX** SEL HLW8012? pin 8
IO5**     CF1 HLW8012? pin 7
IO4**     CF  HLW8012? pin 6
GND           HLW8012? pin 5
VDD           HLW8012? pin 1
*) no idea if correct, seems unused
**) untested
Hope to get it flashed soon:) Flashed, need to get buttons and power meter chip working.
Button shows up in log once, but doesn’t do anything besides show up in log.
[22:32:30][D][binary_sensor:036]: 'button1': Sending state OFF
[22:32:33][D][binary_sensor:036]: 'button2': Sending state OFF
add mode: INPUT_PULLUP fixes button.
config.yaml so far:
substitutions:
  device_name: blitzwolf07
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: !secret iot_ssid
  password: !secret iot_password
  domain: !secret iot_domain
  ap:
    ssid: "ESPhome"
logger:
  baud_rate: 0
  hardware_uart: UART1
api:
ota:
#IO13      led1       ok
#IO12      led2       ok
#IO01/TX   blue led   ok
#IO0       switch1    ok?
#IO2       switch2    ok?
#IO15      relay1     ok
#IO16      relay2     ok
binary_sensor:
  - platform: gpio
    #internal: true
    pin:
      number: GPIO00
      mode: INPUT_PULLUP
    on_press:
      - switch.toggle: relay1
  - platform: gpio
    #internal: true
    pin:
      number: GPIO12
      mode: INPUT_PULLUP
    on_press:
      - switch.toggle: relay2
output:
  - platform: gpio
    pin: GPIO13
    inverted: true
  - platform: gpio
    pin: GPIO02
    inverted: true
switch:
  - platform: gpio
    pin: GPIO14
    name: '${device_name} Relay 1'
    on_turn_on:
    on_turn_off:
  - platform: gpio
    pin: GPIO16
    name: '${device_name} Relay 2'
    on_turn_on:
      - output.turn_on: led2
    on_turn_off:
      - output.turn_off: led2
status_led:
  pin:
    number: GPIO01 #tx
    inverted: true
Tasmota template has some additional info:
GPIO # Component
GPIO00 Button1
GPIO01 LedLinki
GPIO02 Led2i
GPIO03 HLWBL SELi
GPIO04 BL0937 CF
GPIO05 HLWBL CF1
GPIO09 None
GPIO10 None
GPIO12 Button2
GPIO13 Led1i
GPIO14 Relay1
GPIO15 None
GPIO16 Relay2
Here is my Blitzwolf SHP6 ESPHOME configuration file
Functions:
  • Button - ON / OFF
  • When the button on blue LED on
  • When power consumption above 1W red LED on (delayed)
  • after boot turn on the relay
# Blitzwolf SHP6 15A Power Monitoring Plug
# https://templates.blakadder.com/blitzwolf_SHP6-15A.html
substitutions:
  plug_name: blitzwolf_shp6_04
  voltage_div: '760'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    priority: -10
    then:
    # on affter boot
wifi:
logger:
api:
ota:
web_server:
  port: 80
time:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
      inverted: True
    on_press:
switch:
- platform: gpio
  pin: GPIO15
  on_turn_on:
    - switch.turn_on: "${plug_name}_LED_Blue"
  on_turn_off:
    - switch.turn_off: "${plug_name}_LED_Blue"
    - switch.turn_off: "${plug_name}_LED_Red"
- platform: gpio
  internal: true
  pin: GPIO2
  inverted: True
- platform: gpio
  internal: true
  pin: GPIO0
  inverted: True
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO04
    current:
    voltage:
    power:
      on_value_range:
        - above: 2.0
          then:
            - switch.turn_on: "${plug_name}_LED_Red"
        - below: 2.0
          then:
    change_mode_every: 8
    update_interval: 5s
    filters:
        - multiply: 0.001
  - platform: uptime
    filters:
# BlitzWolf BW-SHP6 10A Power Monitoring Plug
# https://templates.blakadder.com/blitzwolf_SHP6.html
substitutions:
  plug_name: blitzwolf_shp6_01
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
  on_boot:
    priority: -10
    then:
    # on affter boot
wifi:
logger:
api:
ota:
web_server:
  port: 80
time:
binary_sensor:
  - platform: gpio
    internal: true
    pin:
      number: GPIO13
      inverted: True
    on_press:
switch:
- platform: gpio
  pin: GPIO15
  on_turn_on:
  on_turn_off:
- platform: gpio
  internal: true
  pin: GPIO2
  inverted: True
- platform: gpio
  internal: true
  pin: GPIO0
  inverted: True
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current:
    voltage:
    power:
      on_value_range:
        - above: 1.0
          then:
        - below: 1.0
          then:
    update_interval: 5s
    filters:
        - multiply: 0.001
  - platform: uptime
    filters:
here is config for Blitzwolf SHP8
substitutions:
  device_name: blitzwolf_shp8_01
  upper_devicename: "BlitzWolf SHP8 01"
  ip: 192.168.xx.xx
  current_res: '0.00221'
  voltage_div: '825'
esphome:
  platform: ESP8266
  board: esp8285
  comment: Blitzwolf SHP8
  on_boot:
    priority: -10
    then:
      - light.turn_on: ${device_name}_blue_led_light
wifi:
  password: !secret wifi_pwd
  fast_connect: true
  manual_ip:
    static_ip: ${ip}
    gateway: 192.168.x.x
    subnet: 255.255.255.0
    dns1: 192.168.x.x
    dns2: 8.8.8.8
  ap:
    ssid: "${upper_devicename} Hotspot"
    password: "!secret wifi_pwd"
captive_portal:
logger:
api:
ota:
web_server:
  port: 80
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO3
      inverted: True
      mode: INPUT_PULLUP
    on_press:
      - switch.toggle: ${device_name}_relay
  - platform: status
output:
  - platform: esp8266_pwm
    pin: GPIO13
    inverted: true
light:
  - platform: monochromatic
    name: "${upper_devicename} Blue LED"
    output: ${device_name}_blue_led
switch:
  - platform: gpio
    pin: GPIO14
    on_turn_on:
      - light.turn_off: ${device_name}_blue_led_light
    on_turn_off:
  - platform: restart
    name: "${upper_devicename} Restart switch"
  - platform: uptime
    update_interval: 60s
    name: "${upper_devicename} WiFi Signal Sensor"
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: true
    cf_pin: GPIO04
    cf1_pin: GPIO05
    current:
    voltage:
      accuracy_decimals: 0
    power:
    update_interval: 5s
text_sensor:
  - platform: wifi_info
    ip_address:
      name: '${upper_devicename} IP Address'
      icon: mdi:ip
  - platform: version
    name: '${upper_devicename} ESPHome Version'
works like a charm, thank you.
how can i tune this values?
current_res: ‘0.00290’
voltage_div: ‘760’
I just received a SHP-7 and a SHP-9 (and some more SHP-6’S) I can’t wait to get the ‘7’ flashed, I have to open the ‘9’ to see if it’s also esp based, I really hope so :slight_smile:
Just try it. If it is not esp based, then it would anyway not accept the flash
It worked, it’s tasmotized now, so tomorrow I’m going to see if I can figure out the pins for it. It’s rather nice, 3 plugs, and two usb ports, and as I read it, they should be individually controllable.
Is there an ‘easy’ path for figuring out the pins?
I’ve made a very rudimentary template for shp9 now, and it’s uploaded to the repository.
It only handles the switches, LED and button, and I still have yet to figure out how to get powermonitoring active on this.
HI,
I have a BW-SHP6 15A. I flashed it first with Tasmota. The reading where ok. But I prefer ESPHome. So I used one of the configs here:
substitutions:
  voltage_div: '940'
esphome:
  platform: ESP8266
  board: esp8285
wifi:
  ssid: !secret ssid
# Enable logging
logger:
web_server:
  port: 80
time:
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO13
      inverted: True
    on_press:
output:
  - platform: gpio
    pin: GPIO15
  - platform: gpio
    pin: GPIO00
    inverted: True
status_led:
  pin:
    number: GPIO02
    inverted: True
switch:
  optimistic: true
  turn_on_action:
  turn_off_action:
  - platform: hlw8012
    sel_pin:
      number: GPIO12
      inverted: True
    cf_pin: GPIO05
    cf1_pin: GPIO14
    current:
    voltage:
    power:
    update_interval: 5s
    filters:
        - multiply: 0.001
  - platform: uptime
    filters:
Unfortunately, the Voltage and Amperage stay 0?? The wattage is correct. Anyone an idea? Or is the latest SHP6 using a different chip? (BL0937 and is not supported?)
I have had the same problem, the problem is wrong configuration.
i used this https://community.home-assistant.io/t/esphome-blitzwolf-bw-shp6-configuration/113938/12
