ESPHOME Bluetooth Proxy area coverage
Hi, I set up an BT proxy using esphome and esp32 board.
Everything it’s working.
What I’ve not found clearly is how far coverage can be. I mean, how many meters, for instance, a iBeacon device can be recognize from ESPHOME BT Proxy?
Regards
Much depends on what ESP32 board you are using
I’m using ESP32 WROOM 32.
Chip: Model=ESP32, Features=WIFI_BGN,BLE,BT, Cores=2, Revision=3
Is that enough to know?
U.fl to sma attachment with external antenna improves signal considerably.
