I just reflashed my proxy with a new config based on the original one from webflasher. It might not be the “officially recommended” version - I’m not entirely sure - but hey, it works for me!
For reference, here’s the config I used to flash the bluetooth-proxy (side note: I’ve it now in my ESPHome dashboard too😉).
Hope this helps someone!
substitutions:
devicename: "ble-proxy-schlafzimmer-1"
esphome:
comment: "ESP32 C3 - Bluetooth-Proxy"
esp32:
board: esp32-c3-devkitm-1
framework:
type: esp-idf
sdkconfig_options:
CONFIG_BT_BLE_42_FEATURES_SUPPORTED: y
CONFIG_BT_BLE_50_FEATURES_SUPPORTED: n
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: !secret encryption_key
ota:
- platform: esphome
password: !secret ota_password
wifi:
ssid: !secret wifi_ssid
ap:
ssid: $devicename
captive_portal:
time:
- platform: homeassistant
esp32_ble_tracker:
scan_parameters:
# We currently use the defaults to ensure Bluetooth
# can co-exist with WiFi In the future we may be able to
# enable the built-in coexistence logic in ESP-IDF
active: true
bluetooth_proxy:
active: true
button:
- platform: safe_mode
name: Safe Mode Boot
- platform: factory_reset
Hallo,
ich verzweifle daran diese Meldung weg zu bekommen.
Alle Versuche in HA mit “take control” über den Bluetooth Proxy in ESP Device Builder führen zum Verlust der Verbindung und Nichts geht mehr,
Einzig per Webflasher Webseite kpl. neu aufsetzen funktioniert, aber dann natürlich wieder die Meldung, es sollte Upgedated werden.
Was für eine Quälerei… wo und wie update ich den Atom-Lite Bluetooth Proxy, damit diese Meldung in HA verschwindet?
I’m desperate to get rid of this message.
All attempts in HA with “take control” via the Bluetooth proxy in ESP Device Builder lead to the loss of the connection and nothing works anymore.
Only reinstalling the website completely using Webflasher works, but then of course the message appears again that it needs to be updated.
What torture… where and how do I update the Atom-Lite Bluetooth proxy so that this message disappears in HA?
Here an other screen showing no Update available/possible, as 2025.2.2 = stated as newest… but warning about update ESPHome to 2025.2.2 shows up always.
Any solution ?
