I would really like to use ESP Home BT Proxy to determine my room presence and I am pretty sure it can be done easily but I am not that good at coding yet, looking for your support!
This is my plan:
When my iBeacon is connected to a BT proxy, the iBeaconās attribute āSourceā show me which BT Proxy I am connected to. As I know the area of the proxy, then I know which room I am in.
Ideally, Iād like to create a sensor that if my iBeacon distance is >0 (or not null) thus I am connected, will show the area of the BT Proxy I am connected to.
Those are some rudimental checks I made:
{{ state_attr('device_tracker.ibeacon_simone', 'source') }} {## This is the ESP Proxy I am connected to ##}
{{ integration_entities(state_attr('device_tracker.ibeacon_simone', 'source')) }} {## This is the list of entities of the BT Proxy I am connected to ##}
{{ area_name('esp32-bluetooth-proxy-sala ') }} {## Trying to get the area of the device do not work ##}
{{ area_name('button.safe_mode_boot_3') }} {## The area of the entity of that device works ##}
This is the ourput:
['button.safe_mode_boot_3']
Sala
As you can see, if I try to get the area of the BT Proxy device, it doesnāt work but I found a workaround, as every BT Proxy has an entity ābutton safe modeā, if I try to get the area of that entity it works!
So I managed to return the list of entities of the connected BT Proxy but I cannot use a list in the area_name
So close but so far.
I am pretty sure that you smart guys here can help me making ESPHome BT proxy also a room presence tool!
