Hi all
I’ve tried to build an Esphome bt proxy project adding also a bh1750 sensor. After installing into an esp32, it creates another project to adopt in the esphome page, but the new one does not contain the bh1750 sensor part.
Is there a way to do it?
Or is there a way to create a project that uses the esp32 to extend the bt and also let me use gpio to use one or more sensors?
nickrout
(Nick Rout)
April 20, 2024, 3:49am
2
Yes it course. Just add the bh1750 config to the existing yaml. Install. Job done.
Will this code works both for BT Proxy and for sensor BH1750?
esphome:
friendly_name: bluetooth proxy bh1750
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: “xxxxxxxxxxx”
ota:
password: “xxxxxxx”
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Bluetooth-Proxy-Bh1750"
password: “xxxxxxxx”
captive_portal:
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
switch:
- platform: restart
name: "BT Proxy BH1750 Restart"
i2c:
sda: GPIO2
scl: GPIO4
scan: true
- platform: bh1750
address: 0x23
name: "BH1750 Illuminance"
update_interval: 30s
I tried this code, it shows the sensor values for a couple of seconds, then it become unavailable and it does not come available any more…
Maybe the BT proxy part uses a lot of resources
nickrout
(Nick Rout)
April 20, 2024, 11:20pm
6
Particularly set up that way the bt proxy will take a lot of resources.
Those interval and windows settings are for wired Ethernet. Change them to the defaults.
Thanks!!!
It works this way, I just removed the interval and windows lines
