Esphome Builder cannot take control of ESP32-S3-BOX
I’m having an issue with a brand new ESP32-S3-BOX-3B. I have followed the instructions on the voice assistants tutorial, and the box gets flashed and added to home assistant just fine. I am able to control my devices by speaking to it without a problem. Now, the issue is when I want to customize the wake word (or anything else for that matter). In the Esphome Builder add-on, the device is discovered. When I attempt to “take control” of the device, however, the build breaks and I cannot get it to complete no matter what I do. The device gets added to the Esphome Builder dashboard and it shows online, but I cannot install a new configuration hence I cannot customize it. Here are the logs from the build. Please help :slight_smile:
INFO ESPHome 2024.12.2
INFO Reading configuration /config/esphome/esp32-s3-box-3-52bb44.yaml...
INFO Updating https://github.com/esphome/esphome.git@pull/5230/head
INFO Updating https://github.com/jesserockz/esphome-components.git@None
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Updating https://github.com/jesserockz/esp32-s3-box-3-board.git@main
INFO Updating submodules (components/esp-sr, components/esp-adf-libs) for https://github.com/espressif/[email protected]
INFO Compiling app...
Processing esp32-s3-box-3-52bb44 (board: esp32s3box; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 16MB Flash
 - framework-espidf @ 3.50105.0 (5.1.5)
 - tool-cmake @ 3.21.3
 - tool-esptoolpy @ 4.8.1
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.7.1
 - tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
 - tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-riscv32-esp @ 12.2.0+20230208
 - toolchain-xtensa-esp32s3 @ 12.2.0+20230208
Reading CMake configuration...
-- git rev-parse returned 'fatal: not a git repository (or any parent up to mount point /)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).'
-- Building ESP-IDF components for target esp32s3
Processing 1 dependencies:
[1/1] idf (5.1.5)
-- Configuring incomplete, errors occurred!
See also "/data/build/esp32-s3-box-3-52bb44/.pioenvs/esp32-s3-box-3-52bb44/CMakeFiles/CMakeOutput.log".
CMake Error at /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:266 (message):
  Failed to resolve component 'jsmn'.
Call Stack (most recent call first):
  /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:308 (__build_resolve_and_add_req)
  /data/cache/platformio/packages/framework-espidf/tools/cmake/build.cmake:603 (__build_expand_requirements)
  /data/cache/platformio/packages/framework-espidf/tools/cmake/project.cmake:604 (idf_build_process)
  CMakeLists.txt:3 (project)
========================== [FAILED] Took 2.25 seconds ==========================
Exactly the same problem here…but with an M5Stack Atom Echo :frowning:
INFO Reading configuration /config/esphome/m5stack-atom-echo-31192c.yaml...
INFO Core config, version or integrations changed, cleaning build files...
INFO Deleting /data/build/m5stack-atom-echo-31192c/.pioenvs
INFO Deleting /data/build/m5stack-atom-echo-31192c/.piolibdeps
Processing m5stack-atom-echo-31192c (board: m5stack-atom; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
Library Manager: Installing esphome/noise-c @ 0.1.6
INFO Installing esphome/noise-c @ 0.1.6
Unpacking  [####################################]  100%
Library Manager: [email protected] has been installed!
INFO [email protected] has been installed!
Library Manager: Resolving dependencies...
INFO Resolving dependencies...
Library Manager: Installing esphome/libsodium @ 1.10018.4
INFO Installing esphome/libsodium @ 1.10018.4
Library Manager: Installing kahrendt/ESPMicroSpeechFeatures @ 1.1.0
INFO Installing kahrendt/ESPMicroSpeechFeatures @ 1.1.0
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
 - toolchain-xtensa-esp32 @ 12.2.0+20230208
-- Found Git: /usr/bin/git (found version "2.39.5")
-- The C compiler identification is GNU 12.2.0
-- The CXX compiler identification is GNU 12.2.0
-- The ASM compiler identification is GNU
-- Found assembler: /data/cache/platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /data/cache/platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Check for working CXX compiler: /data/cache/platformio/packages/toolchain-xtensa-esp32/bin/xtensa-esp32-elf-g++ - skipped
-- Detecting CXX compile features
-- Detecting CXX compile features - done
NOTICE: Current idf-component-manager default lock file version is 2.0.0, but found 1.0.0 in /data/build/m5stack-atom-echo-31192c/dependencies.lock. Recreating lock file with the current version.
Manifest files have changed, solving dependencies.
.....NOTICE: Updating lock file at /data/build/m5stack-atom-echo-31192c/dependencies.lock
[1/1] idf (5.1.5)
See also "/data/build/m5stack-atom-echo-31192c/.pioenvs/m5stack-atom-echo-31192c/CMakeFiles/CMakeOutput.log".
CMake Error at /data/cache/platformio/packages/framework-espidf@src-6e6cd5244a43bdfe453daac50cfe73b6/tools/cmake/build.cmake:266 (message):
  /data/cache/platformio/packages/framework-espidf@src-6e6cd5244a43bdfe453daac50cfe73b6/tools/cmake/build.cmake:308 (__build_resolve_and_add_req)
  /data/cache/platformio/packages/framework-espidf@src-6e6cd5244a43bdfe453daac50cfe73b6/tools/cmake/build.cmake:603 (__build_expand_requirements)
  /data/cache/platformio/packages/framework-espidf@src-6e6cd5244a43bdfe453daac50cfe73b6/tools/cmake/project.cmake:604 (idf_build_process)
========================= [FAILED] Took 10.19 seconds =========================
Same errors here on both types of devices that I just got (one box-3 and one echo). Did I pick a really bad time to try these?
Yes, I have the same problem. Where to report this error to be included in the next fix?
Check here, im still testing for myself, but they seem to have fixed it
Ok so that did not work, so what i did is install a older ESPhome
esphome-legacy-addons
  • I turned off the main add-on
  • disabled auto start just in case
  • installed 2024.11 from the Legacy add-on
  • turned it on
  • then on its own webpage i was able to setup the device correctly
  • i had to reconfigure it from scratch from the ESPhome readymade projects page.
Now i have this issue:
What is this “not a git repository” about? What repository is it expecting, and where is it expecting to find it? This is an m5Stack Atom which has been updated using esphome command line in Linux until now when I’m trying to let HA ESPHome Builder ‘Take Control’ of it.
Processing livingroommic (board: m5stack-atom; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
[1/1] idf (5.1.5)
See also "/data/build/livingroommic/.pioenvs/livingroommic/CMakeFiles/CMakeOutput.log".
========================== [FAILED] Took 2.32 seconds ==========================
For anyone experiencing the same issue, check out this thread:
A workaround seems to be using an older version of esp-idf.
This worked for me on an ESP32-S3 DevKitC-1:
  framework:
    type: esp-idf
    version: 4.4.8
    platform_version: 5.4.0
This resolved that particular problem. Further issues were resolved by something a little further down in the thread you reference, using wake-word-voice-assistant/m5stack-atom-echo.adopted.yaml@main.
