ESPHome: Cannot have two actions in one item. Key 'servo.write' overrides 'id'!
Hello, I’m very new to ESPHome but liking it so far. I’m working to make a Time Based Cover with a continuous rotation servo. I think I’m having a bit of trouble either with my YAML formatting or with understanding how Actions are supposed to work in the first place with ESPHome.
The error I’m recieving is:
INFO Reading configuration...
Failed config
cover.time_based: [source /config/esphome/test111.yaml:39]
  platform: time_based
  open_action:
    Cannot have two actions in one item. Key 'servo.write' overrides 'id'! Did you forget to indent the block inside the action?.
    - [source /config/esphome/test111.yaml:43]
      servo.write:
      level: 100.0%
  open_duration: 30sec
  close_action:
    - [source /config/esphome/test111.yaml:49]
      servo.write:
      level: -100.0%
  close_duration: 30sec
  stop_action:
    - [source /config/esphome/test111.yaml:55]
      servo.write:
      level: 0.0%
My code is as follows:
esphome:
  platform: ESP8266
  board: d1_mini
wifi:
  ssid: "XXXXXXXX"
  password: "XXXXXXXX"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
  - platform: gpio
    name: "Test Status Light"
    pin: 2
    inverted: True
servo:
  - id: my_servo
    output: pwm_output
# Example output platform
# On ESP32, use ledc output
output:
  - platform: esp8266_pwm
    pin: D1
    frequency: 50 Hz
cover:
  - platform: time_based
    open_action:
      - servo.write:
        level: 100.0%
    close_action:
      - servo.write:
        level: -100.0%
    stop_action:
      - servo.detach: my_servo
Thanks for any input on formatting or my lack of understanding.
Ok so I’ve gotten a bit further. Now I can compile.
I’ve got no sign of life on the servo though. Strange.
servo:
  - id: my_servo
    output: pwm_output
output:
    pin: D5
    frequency: 50 Hz
cover:
    open_action:
#      then:
      - servo.write:
          level: 30.0%
    open_duration: 5sec
    close_action:
#      then:
      - servo.write:
          level: -30.0%
    close_duration: 5sec
    stop_action:
#      then:
I’ll keep playing around with it.
Are you sure 30% works for your servo? Try other values: 2 5 10 80
Thanks I’ll try that tonight.
It’s a continuous rotation servo.
I thought all that affected was speed.
In fairness I don’t think I said it was.
Ok so I think this is pretty much fixed now.
I put in some code to close the cover on boot. I would prefer to “stop” it but it doesn’t seem to be working… I’ll update again if I get that fixed…
Faux Wood Blind devices incoming…
Here’s the code:
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: 800.0
    then:
      - cover.close: cover1
wifi:
  ssid: "APSSID"
  password: "APPASS"
# Enable logging
logger:
api:
  password: "APIPASS"
ota:
  password: "OTAPASS"
switch:
  - platform: gpio
    pin: 2
    inverted: True
servo:
  - id: my_servo
    output: pwm_output
output:
    pin: D5
    frequency: 50 Hz
cover:
    open_action:
#      then:
      - servo.write:
          level: 20.0%
    open_duration: 2sec
    close_action:
#      then:
      - servo.write:
          level: -20.0%
    close_duration: 2sec
    stop_action:
#      then:
      - servo.write:
          level: 0%
Stop does not work because esphome doesn’t execute the stop action if the cover is already in stop position
However this will be changed for the next version and stop action will be executed every time.
Awesome!
I look forward to implementing it!
@keithcroshaw Would you mind sharing your home assistant configuration? I’ve been trying to control a servo but haven’t had any luck
What specifically?
My config isn’t as !Secret’d up as I’d like.
If you set up the ESPHome code as Covers properly there’s no code to be shared. They just appear as devices in Home Assistant after adding them with the API Password.
I used the code you posted for the esphome part now I’m not sure how the setup the rest in home assistant. What else did you have setup and can you post that part? input_number? automation? cover? I appreciate your help
Not sure what the part is. They’re HiTec Continuous Rotation Servos.
One on Pin 5 and one on Pin 6.
Here’s the code:
esphome:
  platform: ESP8266
  board: d1_mini
  on_boot:
    priority: 800.0
    then:
      - delay: 2s
      - delay: 3s
      - cover.close: cover2
      - delay: 2s
      - servo.detach: my_servo2
wifi:
  ssid: "REDACTED"
  password: "REDACTED"
  manual_ip:
    static_ip: 192.168.1.230
    gateway: 192.168.1.1
    subnet: 255.255.255.0
# Enable logging
logger:
api:
ota:
switch:
  - platform: gpio
    name: "Living Room Front Blinds Status Light"
    pin: 2
    inverted: True
servo:
  - id: my_servo
    output: pwm_output
  - id: my_servo2
    output: pwm_output2
output:
    pin: D5
    frequency: 50 Hz
    pin: D6
    frequency: 50 Hz
cover:
    name: "Living Room Front Blinds Left"
    open_action:
#      then:
      - servo.write:
          level: -2.0%
    open_duration: 1.2sec
    close_action:
#      then:
      - servo.write:
          level: 20.0%
    close_duration: 2.3sec
    stop_action:
#      then:
      - servo.write:
          level: 0%
    name: "Living Room Front Blinds Right"
    open_action:
#      then:
      - servo.write:
          level: -2.0%
    open_duration: 3.5sec
    close_action:
#      then:
      - servo.write:
          level: 20.0%
    close_duration: 1sec
    stop_action:
#      then:
      - servo.write:
          level: 0%
The automation is in Node-Red
I don’t know what this question means. If you create the cover device in the ESPHome software, when you add the ESPHome device into Home Assistant it should come in as a cover automatically.
